Torque and Horsepower. What is the relation?
Moderator Alumnus
There's been a certain amount of discussion, in this and other files, about the concepts of horsepower and torque, how they relate to each other, and how they apply in terms of automobile performance. I have observed that, although nearly everyone participating has a passion for automobiles, there is a huge variance in knowledge. It's clear that a bunch of folks have strong opinions (about this topic, and other things), but that has generally led to more heat than light.
Force, Work and Time
If you have a one pound weight bolted to the floor, and try to lift it with one pound of force (or 10, or 50 pounds), you will have applied force and exerted energy, but no work will have been done. If you unbolt the weight, and apply a force sufficient to lift the weight one foot, then one foot pound of work will have been done. If that event takes a minute to accomplish, then you will be doing work at the rate of one foot pound per minute. If it takes one second to accomplish the task, then work will be done at the rate of 60 foot pounds per minute, and so on.
In order to apply these measurements to automobiles and their performance (whether you're speaking of torque, horsepower, newton meters, watts, or any other terms), you need to address the three variables of force, work and time.
Awhile back, a gentleman by the name of Watt (the same gent who did all that neat stuff with steam engines) made some observations, and concluded that the average horse of the time could lift a 550 pound weight one foot in one second, thereby performing work at the rate of 550 foot pounds per second, or 33,000 foot pounds per minute, for an eight hour shift, more or less. He then published those observations, and stated that 33,000 foot pounds per minute of work was equivalent to the power of one horse, or, one horsepower.
Everybody else said OK. :-)
For purposes of this discussion, we need to measure units of force from rotating objects such as crankshafts, so we'll use terms which define a *twisting* force, such as foot pounds of torque. A foot pound of torque is the twisting force necessary to support a one pound weight on a weightless horizontal bar, one foot from the fulcrum.
Now, it's important to understand that nobody on the planet ever actually measures horsepower from a running engine. What we actually measure (on a dynomometer) is torque, expressed in foot pounds (in the U.S.), and then we *calculate* actual horsepower by converting the twisting force of torque into the work units of horsepower.
Visualize that one pound weight we mentioned, one foot from the fulcrum on its weightless bar. If we rotate that weight for one full revolution against a one pound resistance, we have moved it a total of 6.2832 feet (Pi * a two foot circle), and, incidently, we have done 6.2832 foot pounds of work.
OK. Remember Watt? He said that 33,000 foot pounds of work per minute was equivalent to one horsepower. If we divide the 6.2832 foot pounds of work we've done per revolution of that weight into 33,000 foot pounds, we come up with the fact that one foot pound of torque at 5252 rpm is equal to 33,000 foot pounds per minute of work, and is the equivalent of one horsepower. If we only move that weight at the rate of 2626 rpm, it's the equivalent of 1/2 horsepower (16,500 foot pounds per minute), and so on. Therefore, the following formula applies for calculating horsepower from a torque measurement:
HP = (Torque*RPM)/5252
This is not a debatable item. It's the way it's done. Period.
The Case For Torque
Now, what does all this mean in carland?
First of all, from a driver's perspective, torque, to use the vernacular, RULES :-). Any given car, in any given gear, will accelerate at a rate that *exactly* matches its torque curve (allowing for increased air and rolling resistance as speeds climb). Another way of saying this is that a car will accelerate hardest at its torque peak in any given gear, and will not accelerate as hard below that peak, or above it. Torque is the only thing that a driver feels, and horsepower is just sort of an esoteric measurement in that context. 300 foot pounds of torque will accelerate you just as hard at 2000 rpm as it would if you were making that torque at 4000 rpm in the same gear, yet, per the formula, the horsepower would be *double* at 4000 rpm. Therefore, horsepower isn't particularly meaningful from a driver's perspective, and the two numbers only get friendly at 5252 rpm, where horsepower and torque always come out the same.
In contrast to a torque curve (and the matching pushback into your seat), horsepower rises rapidly with rpm, especially when torque values are also climbing. Horsepower will continue to climb, however, until well past the torque peak, and will continue to rise as engine speed climbs, until the torque curve really begins to plummet, faster than engine rpm is rising. However, as I said, horsepower has nothing to do with what a driver *feels*.
The Case For Horsepower
OK. If torque is so all-fired important, why do we care about horsepower?
Because:
"It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*.
For an extreme example of this, I'll leave carland for a moment, and describe a waterwheel I got to watch awhile ago. This was a pretty massive wheel (built a couple of hundred years ago), rotating lazily on a shaft which was connected to the works inside a flour mill. Working some things out from what the people in the mill said, I was able to determine that the wheel typically generated about 2600(!) foot pounds of torque. I had clocked its speed, and determined that it was rotating at about 12 rpm. If we hooked that wheel to, say, the drivewheels of a car, that car would go from zero to twelve rpm in a flash, and the waterwheel would hardly notice :-).
On the other hand, twelve rpm of the drivewheels is around one mph for the average car, and, in order to go faster, we'd need to gear it up. To get to 60 mph would require gearing the wheel up enough so that it would be effectively making a little over 43 foot pounds of torque at the output, which is not only a relatively small amount, it's less than what the average car would need in order to actually get to 60. Applying the conversion formula gives us the facts on this. Twelve times twenty six hundred, over five thousand two hundred fifty two gives us:
6 HP.
Oops. Now we see the rest of the story. While it's clearly true that the water wheel can exert a *bunch* of force, its *power* (ability to do work over time) is severely limited.
At The Dragstrip
OK. Back to carland, and some examples of how horsepower makes a major difference in how fast a car can accelerate, in spite of what torque on your backside tells you :-).
A very good example would be to compare the LT1 Corvette with the last of the L98 Vettes, built in 1991. Figures as follows:
L98: 250 HP @ 4000rpm 340 lb-ft @ 3200 rpm
LT1: 300 HP @ 5000 340 lb-ft @ 3600 rpm
The cars are geared identically, and car weights are within a few pounds, so it's a good comparison.
First, each car will push you back in the seat (the fun factor) with the same authority - at least at or near peak torque in each gear. One will tend to *feel* about as fast as the other to the driver, but the LT1 will actually be significantly faster than the L98, even though it won't pull any harder. If we mess about with the formula, we can begin to discover exactly *why* the LT1 is faster. Here's another slice at that formula:
Torque = (HP*5252)/RPM
If we plug some numbers in, we can see that the L98 is making 328 foot pounds of torque at its power peak (250 hp @ 4000), and we can infer that it cannot be making any more than 263 pound feet of torque at 5000 rpm, or it would be making more than 250 hp at that engine speed, and would be so rated. In actuality, the L98 is probably making no more than around 210 pound feet or so at 5000 rpm, and anybody who owns one would shift it at around 46-4700 rpm, because more torque is available at the drive wheels in the next gear at that point.
On the other hand, the LT1 is fairly happy making 315 pound feet at 5000 rpm, and is happy right up to its mid 5s redline.
So, in a drag race, the cars would launch more or less together. The L98 might have a slight advantage due to its peak torque occuring a little earlier in the rev range, but that is debatable, since the LT1 has a wider, flatter curve (again pretty much by definition, looking at the figures). From somewhere in the mid range and up, however, the LT1 would begin to pull away. Where the L98 has to shift to second (and throw away torque multiplication for speed), the LT1 still has around another 1000 rpm to go in first, and thus begins to widen its lead, more and more as the speeds climb. As long as the revs are high, the LT1, by definition, has an advantage.
Another example would be the LT1 against the ZR-1. Same deal, only in reverse. The ZR-1 actually pulls a little harder than the LT1, although its torque advantage is softened somewhat by its extra weight. The real advantage, however, is that the ZR-1 has another 1500 rpm in hand at the point where the LT1 has to shift.
There are numerous examples of this phenomenon. The Integra GS-R, for instance, is faster than the garden variety Integra, not because it pulls particularly harder (it doesn't), but because it pulls *longer*. It doesn't feel particularly faster, but it is.
A final example of this requires your imagination. Figure that we can tweak an LT1 engine so that it still makes peak torque of 340 foot pounds at 3600 rpm, but, instead of the curve dropping off to 315 pound feet at 5000, we extend the torque curve so much that it doesn't fall off to 315 pound feet until 15000 rpm. OK, so we'd need to have virtually all the moving parts made out of unobtanium :-), and some sort of turbocharging on demand that would make enough high-rpm boost to keep the curve from falling, but hey, bear with me.
If you raced a stock LT1 with this car, they would launch together, but, somewhere around the 60 foot point, the stocker would begin to fade, and would have to grab second gear shortly thereafter. Not long after that, you'd see in your mirror that the stocker has grabbed third, and not too long after that, it would get fourth, but you'd wouldn't be able to see that due to the distance between you as you crossed the line, *still in first gear*, and pulling like crazy.
I've got a computer simulation that models an LT1 Vette in a quarter mile pass, and it predicts a 13.38 second ET, at 104.5 mph. That's pretty close (actually a tiny bit conservative) to what a stock LT1 can do at 100% air density at a high traction drag strip, being powershifted. However, our modified car, while belting the driver in the back no harder than the stocker (at peak torque) does an 11.96, at 135.1 mph, all in first gear, of course. It doesn't pull any harder, but it sure as hell pulls longer :-). It's also making *900* hp, at 15,000 rpm.
Of course, folks who are knowledgeable about drag racing are now openly snickering, because they've read the preceeding paragraph, and it occurs to them that any self respecting car that can get to 135 mph in a quarter mile will just naturally be doing this in less than ten seconds. Of course that's true, but I remind these same folks that any self-respecting engine that propels a Vette into the nines is also making a whole bunch more than 340 foot pounds of torque.
That does bring up another point, though. Essentially, a more "real" Corvette running 135 mph in a quarter mile (maybe a mega big block) might be making 700-800 foot pounds of torque, and thus it would pull a whole bunch harder than my paper tiger would. It would need slicks and other modifications in order to turn that torque into forward motion, but it would also get from here to way over there a bunch quicker.
On the other hand, as long as we're making quarter mile passes with fantasy engines, if we put a 10.35:1 final-drive gear (3.45 is stock) in our fantasy LT1, with slicks and other chassis mods, we'd be in the nines just as easily as the big block would, and thus save face :-). The mechanical advantage of such a nonsensical rear gear would allow our combination to pull just as hard as the big block, plus we'd get to do all that gear banging and such that real racers do, and finish in fourth gear, as God intends. :-)
The only modification to the preceeding paragraph would be the polar moments of inertia (flywheel effect) argument brought about by such a stiff rear gear, and that argument is outside of the scope of this already massive document. Another time, maybe, if you can stand it :-).
At The Bonneville Salt Flats
Looking at top speed, horsepower wins again, in the sense that making more torque at high rpm means you can use a stiffer gear for any given car speed, and thus have more effective torque *at the drive wheels*.
Finally, operating at the power peak means you are doing the absolute best you can at any given car speed, measuring torque at the drive wheels. I know I said that acceleration follows the torque curve in any given gear, but if you factor in gearing vs car speed, the power peak is *it*. An example, yet again, of the LT1 Vette will illustrate this. If you take it up to its torque peak (3600 rpm) in a gear, it will generate some level of torque (340 foot pounds times whatever overall gearing) at the drive wheels, which is the best it will do in that gear (meaning, that's where it is pulling hardest in that gear).
However, if you re-gear the car so it is operating at the power peak (5000 rpm) *at the same car speed*, it will deliver more torque to the drive wheels, because you'll need to gear it up by nearly 39% (5000/3600), while engine torque has only dropped by a little over 7% (315/340). You'll net a 29% gain in drive wheel torque at the power peak vs the torque peak, at a given car speed.
Any other rpm (other than the power peak) at a given car speed will net you a lower torque value at the drive wheels. This would be true of any car on the planet, so, theoretical "best" top speed will always occur when a given vehicle is operating at its power peak.
The Only Thing You Really Need to Know
Repeat after me. "It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*." :-)
Thanks for your time.
Gabriel
CL Type S
[This message has been edited by gavriil (edited 04-26-2001).]
The Case For Torque
Because:
6 HP.
At The Dragstrip
Gabriel
CL Type S
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by scalbert:
How much copying and pasting did you do??</font>
Gabriel
CL Type S
<font face="Verdana, Arial" size="2">Originally posted by gavriil:
</font>
</font>
Only if you don't want to tow or move something large. Making torque down low is great when you need to move an object. Having it up high will break an engine if too much is demanded of it.
Analogy time:
If you have a photo strobe and it emits 1 watt-second per pulse?
What is better 10 pulses per second or 1000 pulses per second?
Silver 2001 CL-S with NAVI
- Mud guards
- Wheel locks
- Toyo T1S 235/45ZR17-97W* Proxies on 17x8" SSR Competition wheels (48lbs less than stock)
- Kevlar/SS Brake lines ordered
- Comptech headers & sways ready
- Silver AEM CAI ready
- 8 coats of Zaino magic
Read the post.
</font>
Read the post.
</font>
BTW, I was joking and trying to have a light attitude.
Moderator Alumnus
I didn't feel like taking the time to go through it considering it isn't news.
BTW, I was joking and trying to have a light attitude.</font>
I know you were joking...relax. I am sure though that if you read this post you will understand why the confussion between T and HP from all these so called...super experts who go to the track and have seen it all.
Gabriel
CL Type S
</font>
</font>
uh!HUH HUH!huh-huh..uh huh hu uh ha ha he said torque!!!ya !ya! torque!!!huh hu ha ah...torque!torque!torque!!!!!
'01 3.2 CL typeS
satin silver metalic
Llumar platinum plus
tint 20% all around
'98 ACCORD V-6 sedan
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
'01 3.2 CL typeS
tint 20% all around
16" coupe wheels
215/55/16 nitto's
20% smoke titanium
black chrome kit
Gavrill --
That's was VERY informative -- thanks for posting that. I was flipping through my buddies UTI manuals (United Technical Institute) a while ago and in his engines and transmission manual -- i read something nearly verbatim to what you've posted. It was a good read, but back then I wasn't too interested b/c I didn't appreciate the real-time application consequences of such interesting information -- now that I have my TL-S -- it's more appropriate to reconsider all of what you've stated. It's nice to know that behind the sometimes cocky, testosterone catalyzing sport of drag racing (street or track) .. there really is some interesting physics behind it all!
2002 TL-S
2002 TL-S
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by TL_Type_S:
Gavrill --
</font>
Gavrill --
</font>
I am glad you liked it. Thanks for the good words.
Gabriel
CL Type S
Community Architect
robb m.
robb m.
thanks gavriil, I enjoyed reading and learning from what you posted too ![](http://www.acura-cl.com/ubb/biggrin.gif)
Astroboy out...
2001 Acura CL Type S: Comptech: Headers, filter, sways, springs, koni shocks, Volk Racing SE37's in 18", goodridge braided brake lines, AEM CAI (blue), APEXi V-AFC, full kicker system, 13" Brembo's on the way with slotted discs for the rear
1996 Porsche 911 Twin Turbo: H&R Springs and sways, Bilstein shocks, ported and polished, crillo rods, new valvetrain
1995 VW Golf: 1999 VR6 Swap, H&R Coil Overs, neuspeed strut bars, neuspeed sway bars, 2.5" Stainless TT exhaust w/ Borla, 13" AP Racing big brakes
Astroboy out...
Torque part and gears:
BTW -- the NHRA shift point calculator does what you described above. It compares the speeds between adjacent gears and chooses a shift point based on the minimum loss of effective torque (The effective torque in this case being directly correlated with the gearing)
Gavrill, you might enjoy this as well:
http://www.prestage.com/carmath/dynochart.asp
A quote from the results page:
"The table below shows your results based on the information you provided on the previous page. Your best shift point will be the RPM where there is the least change in torque between shifts."
HP for top speed:
ALL of the equations that I found doing top speed calcs for the CL-S USED POWER (HP) NOT Torque to arrive at the "best" gear for maximum top speed. The process is iterative and depends on gearing and HP at each measured speed (not torque).
[This message has been edited by EricL (edited 04-27-2001).]
HP for top speed:
- Mud guards
- Wheel locks
- Kevlar/SS Brake lines w/Brembos?
- Silver AEM CAI
- 9 coats of Zaino magic
So, high HP extends the use torque, contributing to the top speed, but does little or nothing to acelerate the car... I think.
I not so sure on why torque at high RPM is better though. Supposedly you get the least power loss by getting the torque at 5000rpm, or at least closely matching the peak HP rpm. Good for racing, but is it good for a daily driver? Won't a car with a low torque RPM peak accelerate harder, faster--but sacrificing top speed?
I always did wonder why the S2000 was fast, but had such ridiculously high peak HP and torque figures; which would lead me to belive that it would actually be fairly slow.
My head hurts.![](http://www.acura-cl.com/ubb/confused.gif)
I am a cute fuzzy squirrel.
My head hurts.
Cost Drivers!!!!
Thanks for the informative post!! So applying the knowledge to our cars. I'd say shift right when we do 232 ft-lbs @ 3500 rpm.....but then the car has the whole vtec thing going on after 5000.....so then wouldn't our power peak be at a higher rpm? Some clarification would be great!
Thanks in advance.
'01 Silver CL-Type S
!BEWARE THE SILVER SWORD!
![](http://www.acura-cl.com/ubb/smile.gif)
MP Video Extraordinaire
The Doctor is IN!
01 CL-S San Marino Red/Black, K&N drop in, no nav, rear wing, otherwise stock thus far, has an appetite for Bavarian cars.
Midnight Marauder
Thanks a lot for the great post.
Physics was always greek to me and chemistry was always just math and... er, nevermind.
But you make it clear enough for me.
Will this go in the FAQ?
Peace
'97 2.2CL
White
Cleared bumpers
Clean trunk look
Mods to come...need $$$!
Peace
'97 2.2CL
White
Cleared bumpers
Clean trunk look
Gavril,
great job on the info. You really know your stuff.!
2001 SAAB 9-3SE HOT
"All things, therefore, that you want men to do to you, you also must likewise do to them."
Matthew 7:12
2001 SAAB 9-3SE HOT
Matthew 7:12
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by Zapata:
Thanks in advance.
</font>
</font>
Gabriel
CL Type S
[This message has been edited by gavriil (edited 04-27-2001).]
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by EricL:
HP for top speed:
</font>
HP for top speed:
</font>
Gabriel
CL Type S
Moderator Alumnus
Thanks for the good words folks. There is more to come.
AND AS YOU SEE HERE...THERE IS NO NEED TO LIVE AT THE TRACK IN ORDER FOR ONE TO ENJOY THEIR CAR, LEARN HOW THINGS WORK AND ENJOY THE RIDE.
Gabriel
CL Type S
Gabriel
CL Type S
A little long, but good info.
I see HP and torque as this...Torque is the measure of accelerating force and HP is the measure of how fast you can access your available torque.
correct me if i am wrong.
By the way, did you major in mechanical engineering? If so, where? I am graduating this semester from The University of Texas at Austin with a BSME.
<font face="Verdana, Arial" size="2">Originally posted by DragonTL:
By the way, did you major in mechanical engineering? If so, where? I am graduating this semester from The University of Texas at Austin with a BSME.</font>
HP is like more pushes per unti time. The piston has an explosion, and depending on engine configuration, these individual explosions determine the "kick"/"push". If you have more of them, you are making more "Power".
Hence, the analogy of a strobe light:
Torque is like a 1 watt-second pulse of light
At mid rpms, you would have the equivalent of 60 pulses/second. To your eye, it would appear to be constant due to persistence of vision and you would be putting out 60 watts of light (60 watt bulb equivalent).
At high rpms, you would have the equivalent of 300 pulses/second. To your eye, it would appear constant (as before), but much brighter, and would be equivalent to 300 watts of light (300 watt light bulb).
Put it this way -- what would you rather have a 60 watt light bulb glowing or a 300 watt light bulb glowing?
- Mud guards
- Wheel locks
- Silver AEM CAI
Unregistered Member
gavriil,
You're pathetic. If you're gonna use someone else's story then let that be known.
You didn't write any of that post. You merely copied it from the original author.
I read that exact post a long time ago on LS1.com
Good job, bookboy.
By the way, you still have a lot to learn about acceleration and the relationship between torque and HP. The post does NOTHING to prove anything.
If you have any reading comprehension, you'd see that the author's main point was that GEARING is all important in drag racing. He wasn't pro-horsepower or pro-torque.
dead CL-S and M3
[This message has been edited by Tom2 (edited 04-27-2001).]
Good job, bookboy.
dead CL-S and M3
Moderator Alumnus
Gabriel
CL Type S
Moderator Alumnus
<font face="Verdana, Arial" size="2">Originally posted by Tom2:
gavriil,
You're pathetic.
</font>
gavriil,
You're pathetic.
</font>
How about that expressed in a formula?
Whatever you say hicko. Keep going to the track and keep telling us about it. By the way, do not forget to shift hard and push those pedals all the way down to the...ah...what do you call that...OH the "metal". Cos it makes a difference you know. You go to make sure that you push the gas pedal too, not the other one...whatever its name is.
Gabriel
CL Type S
Moderator Alumnus
Yes, torque is like a moment. When a piston fires, it pushes.
</font>
</font>
Gabriel
CL Type S
Unregistered Member
Notice that gavriil still won't admit that he didn't write any of that original post.
COME ON, BUD, LET'S BE A MAN AND ADMIT THAT IT WAS WRITTEN BY SOMEONE ELSE!!
dead CL-S and M3
dead CL-S and M3
Moderator Alumnus
</font>
</font>
But I forgot. You were not at school and the library because you had to go to the track and run 13.9s and have a party after it cos you were so happy to see that your M3 broke the times that the mags ran. Oh!
Gabriel
CL Type S
Unregistered Member
</font>
</font>
I rest my case, bookboy.
You are once again proven to be an idiot.
dead CL-S and M3
(Um, the fine line between research and plaigerism is crossed if proper credit isn't given to the original source.)
051/LP/SR/LD/HH
[This message has been edited by DtEW (edited 04-28-2001).]
051/LP/SR/LD/HH
Moderator Alumnus
Yeah, did you ever stop and think about the way that magazines get their performance numbers? Do they use the gavriil method of calculations? Nope, they test the cars in the real world- meaning they drive 'em and time 'em.
</font>
</font>
Look at this people. I made Tom, the guy who despises anyone who talks about what magazines have recorded cars run on the track, to actually TAKE THE MAGAZINES' side. And this is not the first time he did it.
He is defending what mags are doing when they report times. He tries to prove me wrong by defending magazines. Haha!
So Tommy boy, are mags right or not right or what now? Is the 6.0 seconds for 0-60mph they recorded on that E36 M3 OK now? Haha!
See one of the things that they teach you at school is a little philosophy where they teach you what a falacy is and how do debate with people. It does have to do a little with becoming a lawyer. Bottom line, it helps you present premises and help you prove your case by trapping your opponent. You were the easiest case I have ever dealt with. Which proves that you probably do not even have a high school degree which is probably not so relevant here but I feel for you not having the opportunity to actually sit in the classroom and take lessons from people with PHds. You missed a great experience which by comparison to going to the track with your M3 and running time splips is...at best...insulting to you.
Nothing wrong with not going to school. But to come out and pretend it was the right choice...ah...well...you diserve my "cruelty" and this forum's pitty.
But...oh...I forgot...you go the track with the Camaro boys. Who needs to read books when they actually can go to the track and run for 1320 feet straight. I am so glad you give me the opportunity to do this to you man.
In front of the whole forum here...Tom the "know-it-all" with the F60 M3 has fallen hard. Booohooo...
Gabriel
CL Type S
Unregistered Member
<font face="Verdana, Arial" size="2">Originally posted by DtEW:
</font>
</font>
Obviously, gavriil has some serious issues.....
Yet he still won't give credit to the original author. What a dickhead.
dead CL-S and M3
6 speed...
so I did a little more research (and resurrected this thread
the original article was written by one bruce augenstein of the boston bmwcca.
it originally appeared in bimmer online in march of 1999.
you can see the original article here.
to avoid any appearance of plagarism (
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Moderator Alumnus
Mabye just post the URL by itself next time....
I've read that same article online before, it's very good. And actually where I found the (torque*RPM)/5252 equation. Lot's of good info in there. Just kinda seems like plagiarism
when you don't post where you got it from and or the fact it's not your words...
But nice that someone took the time to look it up for everyone else
Moderator Alumnus
Thanks. Exactly what I'm trying to point out.
dead CL-S and M3
dead CL-S and M3
YA, after reading all of thise thread...
Someone smack gavrill off his soap box.
Sad, very sad....
Moderator Alumnus
Borrowing other people's knowledge is called RESEARCH of which you would know nothing about. That is what people that go to good schools are asked to do
Agreed, and that's fine...
So why didn't you correct anyone and tell them those are not your words when they gave you credit for it?
You accepted credit for someone elses work, thats just pathetic in my book. I thought a lot more of you until now...
