Torque damper ?
Old May 26, 2010 | 11:42 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Torque damper ?
Are torque dampers only for manual tranny's ?
Do they really do anything or are they just a waste of money ?
Old May 26, 2010 | 01:08 PM
civicdrivr's Avatar
The manuals have the brackets for them. I dont know if the autos do. And yes they help as long as the bracket system is strong.
Old May 26, 2010 | 01:23 PM
tnobori1's Avatar
Missing my
Read the threads in the FAQ section. I actually ordered two and then read that they come loose easily and often and some members have had theirs fall off completely. From what I've read new mounts will eliminate the wheel hop without dampers. To me they seemed like a waste of cash, but I don't even know if they apply to autos...
Old May 26, 2010 | 01:51 PM
civicdrivr's Avatar
Use some plumbing thread tape on the bolts, the dampeners wont come apart.
Old May 26, 2010 | 02:20 PM
This style is what I was wondering about.
This look to be a very good spot to help the engine movement.
Old May 26, 2010 | 04:11 PM
civicdrivr's Avatar
Thats a K series motor. It would be difficult to do that sort of setup in the CL. To do it off the front valve cover would be pointless as the radiator support will flex. The geometry would be all wrong if you do it off the rear valve cover to the firewall, unless to bolt it straight back, but good luck getting a drill and tap set in there to do it. IIRC the Ingalls setup that Fries was trying to get going came off the power steering pump area and attached to the strut tower. Thats a good spot for it, and the Accord guys definitely notice a difference.
Old May 26, 2010 | 06:28 PM
Probally not the best place for me to put it.
Old May 26, 2010 | 06:57 PM
civicdrivr's Avatar
Wrong side.
Old May 26, 2010 | 07:10 PM
Their both the same. Upper arm clearance for the drop.
Old May 26, 2010 | 08:16 PM
civicdrivr's Avatar
No, I meant wrong side of the strut tower. Youre mounting it to the inside of the strut tower, in line with the ps pump.
Old May 26, 2010 | 08:56 PM
phee's Avatar
I got the Shifts
ive got mine mounted from the rear of th eengine to the bottom of the k frame. i also have one in front bolted from the tranny to the k frame. made a world of a difference.
tire smoke replaced tire hop
Old May 26, 2010 | 09:15 PM
Pics ?
Old May 26, 2010 | 10:19 PM
civicdrivr's Avatar
The autos dont have the mount points from the factory on the K-frame IIRC.
6MT:
Auto:
Check the k-frame and see if the bolts are there. If so, you can use the factory mount locations and you can use the stock brackets to mount an Ingalls dampener. I doubt it though because the part numbers on the front crossmember(where the front mount is) between the auto and manuals are different.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
