Topspeed for each gear before and after mod?
Website that shows top speeds in each gear???
Hey guys,
DO any of you guys know of a web site that states the top speed for the 2001 CL-p Top speeds in SS mode??? I heard it was 105, but i wanted to show it to somebody. THanks
Re: Website that shows top speeds in each gear???
Originally posted by ktgumbo
Hey guys,
Hey guys,
heres teh top speed for a typeS
1st 45mph
2nd 65mph
3rd 110
4th 145
5th 145
w/ headers
1st 47mph
2nd 68mph
3rd 113mph
4th 146-gov.
5th 146-gov
well atleast thats what it was for my car
Re: Re: Website that shows top speeds in each gear???
1st 45mph
2nd 65mph
3rd 110
4th 145
5th 145
w/ headers
1st 47mph
2nd 68mph
3rd 113mph
4th 146-gov.
5th 146-gov
1st 45mph
2nd 65mph
3rd 110
4th 145
5th 145
w/ headers
1st 47mph
2nd 68mph
3rd 113mph
4th 146-gov.
5th 146-gov
The rev-limiter will "hit" at the same RPM regardless of "setup"/mods".
The speeds (at least according to my speedo) look pretty close with the exception of 2nd gear. I know my speedo has hit 71-72MPH in 2nd gear (that's the speed where the rev-limiter kills it)..
I also don't know of a "dead accurate" calc site. The loaded radius of the tires will make the "true speed" -- not to be confused with the indicated speed -- change with tire size/profile/make variations...
check in the manual it should show you top speed for each gear.
and also you WILL be able to go a little faster in each gear w/ mods like cai,headers.
Hey guys,
Hey guys,
Top speed for each gear is a function of the gear ratio , tires ( non-stock sizes) , Redline and it is independent of any performace mod.
Any performance mod will add to the acceleration of the car... i.e. time to get to a certain speed would be less....
(Yes, you can you faster in 4th and 5th with the headers and CAI. The other gears don't care.)
Maybe its just my speedo, but it does "shows" 71-72 MPH before the fuel limiter cuts in. (I did the calcs too, and they seem to match...)
Totally..
Only way to change what speed you go in each gear is modifying the transmission. Or changing the rev limiter.
Speed per gear is calculated by taking your crank shaft revolutions and multiplying that by your transmissions gear ratio, then to your final differential ratio.
Even if you add NOS/HEADERS/CAI/SUPERCHARGER your still going to be at 7100 RPMS peak in all gears. Now if you remove the rev limiter and rev past 7100 rpms you'll get more speed out of each gear.
Good example. Is a bicycle (dirt bike with only 1 set of gears, very simple transmission) Lets say you have a pedal pumping limiter at only 1 pedal pump per second. So with this limiter no matter what you do your only going to be able to pump it 60 times in 1 minute.
Now you have a superstar athlete and person in avg. shape.
The athlete is capable of pumping the bicycle 200 times in 60 seconds. The avg. person is capable of pumping the bike 120 times in 60 seconds.
Even though the athlete may be able to pump that bike faster than the avg. person he is still limited to one pump per second. So no matter what, both people will only accomplish 60 pumps in 1 minute. As such both of their speeds will be the same, however the athlete will most likely not get tired
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
guyvelella
Sep 30, 2015 11:02 PM
