Tire Size and Speedo
Okay, don't want to think, but can someone tell me how the speedometer and odometer are affected by different tires?
Say you have tire A with 800 revolutions and tire B with 820 revolutions and comparing that with our stock CLS tires (I think it's like 816 revolutions).
If you are at 60 mph, on our stock tires, we should be going 60 mph. What about tire A and B? If speedo says 60mph, are they slower or faster than what it says?
Also, if you drive 1 mile on the stocks, you go 1 mile. How about A and B...which one would be less?
Originally posted by JasonT
Also the stock tires are only "fast" on some cars. My were dead on, as are many. Might just be a few that have been off.
I believe the tire companies will tell you that +or- 2% off from standard is ok. I believe that standard is 819 revs per mile. On the minus side, your speedo mileage would not register as many miles as standard and on the plus side, your speedo would be adding more miles than the calibration.
So, if 819 revs per mile is considered the standard, does a tire that specs at 800 revs per mile basically mean that our odometer will read more miles than it should? (bad thing)....and our speedometer would read slower?
Or was it the other way around?
Or am I still screwed up?
The reason stock CLS/TLS tires are "fast" is because the original CL/TL were calibrated for a tire that is 25.68 inches in diameter whereas the type s tires are 25.5 inches.
In general:
smaller tire = more revolutions per mile = going slower than speedo says = going less distance than speedo says
all of these relationships are linear so you can take the ratio of size or revolutions to determine what percentage your speed or distance will be out.
In general:
Originally posted by CO-CL-S
How did you determine that yours were on? I checked mine on a lot of interstate runs (200-400 miles segments), and found them to be off app. 1 1/2%.. And then confirmed that with comparing the speedo with my GPS.. YMMV
Doesn't matter now anyway since I have the Toyos I'm know I'm a little fast.
nuldabz
Sep 3, 2015 05:49 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
