Ticking sound?
Old Aug 22, 2007 | 08:38 PM
turbo_911's Avatar
Ticking sound?
oh and does anyone knows what's that ticking sound is?
here is the video...
http://smg.photobucket.com/albums/v...=Movie_0001.flv
after like 10 mins it goes away...
Old Aug 22, 2007 | 09:32 PM
TommySalami's Avatar
E92
"page not found" --fix the link so it doesn't have the "..." in it
but, if its from the engine it could be knock or sound from the fuel injectors
Old Aug 23, 2007 | 09:04 AM
turbo_911's Avatar
hmm, that's weird yesterday i checked the link and it worked
well here is the new one
http://smg.photobucket.com/albums/v3...Movie_0001.flv
Old Aug 23, 2007 | 01:26 PM
fuzzy02CLS's Avatar
Normal Acura valve tick noise. All 3 of my CL's did it to some degree. A valve adjustment may help with it but that's like $600-$800.
Old Aug 23, 2007 | 01:39 PM
turbo_911's Avatar
oh ic, what a relief, cool thanks for the heads up
Old Aug 23, 2007 | 07:14 PM
djarovsky's Avatar
Everything sounds the same as my car....all normal.
Old Aug 24, 2007 | 12:15 AM
3.5-6Speeder's Avatar
yea thats normal, means your motor is Honda strong
Old Dec 9, 2007 | 11:21 PM
horsepowercrzy18's Avatar
hey
i have the sameee problem. time to get valve adjustment and replace pcv
Old Dec 9, 2007 | 11:23 PM
srehmat02's Avatar
Thanks to Nick, I know how to do valve adjustments now I can't believe they can charge over $600, thats pretty insane!!
Old Dec 9, 2007 | 11:33 PM
02type-s's Avatar
-Arsenic-
The purge solenoid would also cause a clicking sound near the drivers side by the firewall. 50 bucks, install it yourself. Very common with the 3.2.
Old Dec 10, 2007 | 02:53 AM
MADMAN187's Avatar
LOL I opened my hood the other day and realized the same thing. I thought it was normal? So how do you replace it? What will the difference be one it is replaced..
Old Dec 10, 2007 | 05:54 AM
Harrisonk531616's Avatar
CL-SEXY SIX (=
i replaced the purge solenoid valve before; swapped it from a 01 cl-s fro mthe used car dept that came down to the shop...don't even know what it does lol
Old Dec 10, 2007 | 08:50 AM
shredoption's Avatar
I have a ticking noise too. I noticed it got a little louder in the month I've had my car and I thought it must be leaking oil or something but I got it changed and it didn't decrease the ticking at all. It sounds like lifters, right? Anyways, will it hurt anything to leave it?
Old Dec 10, 2007 | 10:32 AM
turbo_911's Avatar
how do you guys adjust valves without going to the mechanic? is it any easy procedure or not really?
well, i still didn't change my purge solenoid valve but i noticed it started ticking a lot louder now, maybe cuz of the cold weather? planning to change it next week, see if its gonna help or not....
Old Dec 10, 2007 | 10:35 AM
fsttyms1's Avatar
If you have a manual or know what your doinf with tools its not too hard. You have to take the upper im off and take the valve covers off to get to them. Then its a matter of turning the crank to a certain position and adjusting from there (there is a lil more to it than that though)
Old Dec 10, 2007 | 02:07 PM
aznboi2424's Avatar
any benefits to changing out a ticking purge solenoid? cause i think thats what is ticking on my car and i dont want to change it out just to take the noise away
Old Dec 10, 2007 | 02:40 PM
LukeaTron's Avatar
I'm not familiar with your specific engine but if it's like every other Honda VTEC engine I've had my hands on, there's a thing called a "Lost Motion Assembly". Essentially it's a spring that keeps the center common (high lift) rocker against the cam when the VTEC is not engaged. When the VTEC is engaged the center rocker is physically connected to the other rockers so the pressure from the valves and their springs keeps the rocker up against the cam. When it's not engaged, the rocker can flop around freely. The lost motion assembly, which is built into the top part of the cam retainer, just keeps pressure on the center rocker so it stays against the cam and doesn't make a bunch of racket.
After about 50,000 miles the springs start getting progressively weaker and the engine starts getting clattery. For my Civic which only had VTEC on the intake cam, it was something like $40 for new springs. That and valve adjustment made the engine purr with a lot less chatter. It's probably kind of pain to do on the rear cylinder bank of your cars, but I don't have any experience there.
Old Dec 10, 2007 | 04:49 PM
aznboi2424's Avatar
just saw the video on the third post. exact same 2 spots i hear my ticks. not real intrested in doing a valve adjustment. but still looking for any benefits to replacing the purge solenoid.
Old Dec 10, 2007 | 08:49 PM
fuzzy02CLS's Avatar
My damn purge valve is ticking again Time to replace for a 2nd time.
Old Dec 10, 2007 | 10:28 PM
turbo_911's Avatar
how long was it quiet before it started ticking again?
i'm just looking if its really worth it or not, lol to change it
Old Dec 10, 2007 | 11:29 PM
fuzzy02CLS's Avatar
It's been 2 years. I just noticed it last week.
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
TL14
Sep 24, 2015 04:37 PM
