Throwing code P0141 O2 sensor heater circuit
Old Dec 10, 2007 | 07:41 PM
ScottyNorq's Avatar
2003 Satin Silver CL-S
Can any one help me with some info. I installed xs headers this summer.
Old Dec 10, 2007 | 08:34 PM
fuzzy02CLS's Avatar
Well, either you have a bad 02 sensor, or the wires going to it are loose.
Old Dec 10, 2007 | 11:10 PM
ScottyNorq's Avatar
can i just buy the o2 sensor they sell at checker auto (Kragen to you Cali guys) or should I buy one from the dealer?
Old Dec 10, 2007 | 11:12 PM
artbran's Avatar
666 Speed
well you can do whichever you want. If you are good/ok with soldering, then get the cheaper universal one. While if you want a plug and play job, then go dealer but be prepared to pay...
Old Dec 10, 2007 | 11:23 PM
fuzzy02CLS's Avatar
I would only buy an Acura 02 sensor., Order from dealer online & it's not that much $.(links in FAQ)
Old Dec 11, 2007 | 09:13 AM
fsttyms1's Avatar
Old Dec 11, 2007 | 12:21 PM
SkillOBskilled's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Get it from there, its a bit cheaper then from a dealer.
I would see if you see a voltage drop across the O2 heater connections. Its very likely that the coil that heats the O2 sensor has failed, resulting in an open circuit and the code. It is unlikely, but possible, that you lost connectivity somewhere upstream. Its worth checking out.
Good Luck
Old Dec 12, 2007 | 12:21 AM
ScottyNorq's Avatar
Good Luck
Thanks but dont really follow. i took a few years of auto shop in high school and i can change my spark plugs and install some headers but thats about it.. the check engine light stopped coming on.
Old Dec 12, 2007 | 08:24 AM
"Testing and diagnosis of the O2 sensor heater and circuit is a relatively simple task. Most heaters are a positive temperature coefficient element, meaning the resistance will go up as the element heats up. In normal operation, the increased resistance of a hot sensor will naturally limit current flow in the circuit. Use a digital multimeter to check the sensor heater element for continuity. Exact heater resistance specifications may vary depending on the vehicle and sensor location. Heater element resistance should be about 4 to 7 ohms for a sensor at ambient temperature. Expect somewhat lower resistance values for FLO type sensors.
Another fundamental diagnostic test is checking the vehicle's wiring harness for power and ground to the O2 sensor heater. Take into account that PCM-controlled heater circuits may require the engine running before the circuit will be powered up. Connecting a 12-volt test light between the power supply and ground can determine if the heater circuit is operational. Some technicians prefer to check heater circuit current flow using an ammeter. To measure current flow, connect a digital multimeter in series between the vehicle wiring harness and the sensor heater. This testing method ensures proper heater and circuit performance throughout the temperature range of the sensor. Amperage values can be from approximately 1.5 amps at ambient temperature to 200 milliamps at full operating temperature. "
http://www.asashop.org/autoinc/dec2002/mech.htm
This way you can figure out if its the O2 sensor or the circuit thats at fault.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
07Acuradude
Sep 29, 2015 03:01 PM
