Throttle Wire...can anyone explain this???
'Cooter
anyone explain y the gold tab next to the throttle wire moves about half an inch???
Before...
Before...
Originally posted by bnavarro
i belive that wire is for the cruse control. i don't think it will make a difference.
You are suppose to have slack in the throttle and cruise control cables. Look in the service manual and it tells you to have 10~12mm of slack as mr. tl said. If you adjust it too tight, the cable will pull on the throttle plate even though you are not pressing on the gas. This results in high idle and a potentially dangerous situation when you are in gear. It might lunge forward by accident when you are on your brakes while in gear.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
