throttle body compatible?
Old Dec 2, 2008 | 02:05 PM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
would a cls6 tb fit a cl-p? if so would there be any gains or advantages? im s/c by the way.
Old Dec 3, 2008 | 12:15 AM
nobody?
Old Dec 3, 2008 | 06:55 AM
nbennettksu's Avatar
i heart latin chicks
i got a cls6 TB on my CLP. maybe a little hp/tq, biggest thing I saw was throttle response. its a good bit bigger than the clp, and you having the SC will prolly see more gains than me.
Old Dec 3, 2008 | 08:13 AM
02CLNOS's Avatar
all you did was take off yours and put the cls6 TB on ... no problems
Old Dec 3, 2008 | 08:29 AM
NSXNEXT's Avatar
Gains? It's all in your head.
If you're not replacing anything on either side of the TB, there is no gain.
Think about it, if you had a straw that had a bulge in the middle of it, would you be able to suck more through the straw? You're still restricted at the front and back of the straw.
In order to really see any worthwhile gains to justify the price, you'd need to swap the intake manifold and the air box and piping on the other side of the throttle body. You'll also need to purchase the bypass valve acutator and hook up an rpm switch to activate the bypass valve.
I did it a while back and here's a thread on it.
https://acurazine.com/forums/showthr...anifold+intake
Keep in mind, mine is a 99TL which required a lot more parts, fuel rails, injectors, lower IM, etc.
Old Dec 3, 2008 | 08:35 AM
poisx7's Avatar
GrandeInter10 in my Humble Opinion.
I say dish the idea. just increase ur boost & ir find a after cooler= lower ur temps.
i dont think its worth the trouble.
take advantage of ur lower compression. booost boosssssst booossssst
Old Dec 3, 2008 | 08:37 AM
poisx7's Avatar
i beleieve they was a 9 lbs pulley. either it was custom or not i can remenber but hey......
Old Dec 3, 2008 | 11:06 AM
yea straight bolt up
Old Dec 3, 2008 | 11:07 AM
thanks for the thread
Old Dec 3, 2008 | 03:52 PM
i have it. the max blower pulley and the CT HBP make 9lbs. i just don't have any cooling system. im looking into a few meth/injection systems for some good prices and i also need to get hold of an emanage and boomslang harness and get a tune. lots of $$$ there tho so i'm going slow and doing some of the other things i can do to get a little more hp.
Old Dec 3, 2008 | 04:13 PM
oh and thanks guys. nsxnext thats a crazy thread.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
