thought some of you would like this NEW mod
so i was cruising ebay and came across these new red gauges and thought of all you US based CLers..
I was going to buy them but they are in miles per hour and that won't work with mine which is in km/h because the speedo actually travels more on the km/h than the mph. cause my speedo only goes to 240kms and the US one goes to 160 mph which is more than mine thus it would not show the correct speed i think.
otherwise i would have ordered it by now.
http://cgi.ebay.ca/RED-GLOW-2001-200...item3a6516c069
hopefully someone will get these.. I would just love to see them in person. :-(
You had me at JDM and "Type-R".
Unregistered Member
Here's a link for the Non Type S!!!
http://cgi.ebay.ca/Type-R-RED-GLOW-2...item5198c2ad8c
So, these gauges won't fit 6 speed clusters?
These guys are good! They made some gauges for the Si that match the car's stock gauges perfectly!
Actually, I think the gauges look pretty good.. just sort of out of place. Maybe it'd flow well with someone who has done LEDs for the rest of their dash
Whats up with RDX owners?
Unregistered Member
You crimp a connector to the end of a positive wire. That wire goes to some pin made specifically for it. That way, it only lights up when you switch your headlight dial to middle or fully on.
Negative terminal gets a crimp to connect to this screw that is in contact with electrons.
Easy job, no soldering. Takes 10 minutes. Hardest part is staying upside down for ~10 mins without throwing up.
I remember there being a reverse glow gauges install guide somewhere around here. I guess I could make one if someone needs it.
mrkingstonvi
02-22-2016 01:53 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
