Thermostat along with timing belt change?
Should I replace the thermostat when having the timing belt (and accessory belts, water pump, etc) changed?
Or is it something that can be "reached" without removing belts, etc in case I have a problem in the future??
asahrts
09-04-2015 05:55 PM
2001, acura, acurazine, belt, change, changing, cl, diy, generation, replace, thermostat, thermostate, timing, tl, type
