Thermometer Temperature Offset
Old Nov 5, 2003 | 05:48 AM
philgates's Avatar
If you hold the Select and Reset buttion on the tripodometer at the same time for 10 seconds or so you can adjust the offset for you thermometer.
Anyone know what this should be set at? Mine is set to 0 right now but it can be adjusted +/- 3 Degress.
Old Nov 5, 2003 | 06:03 AM
Jens H.'s Avatar
retired
The adjustment exists for those people who are convinced the bank has a better or more accurate method of determining outside air temps .The factory setting is for 0 you can set it to suit your needs .
Jens
Old Nov 5, 2003 | 06:19 AM
philgates's Avatar
Thanx Jens!
Old Nov 5, 2003 | 06:21 AM
BEETROOT's Avatar
Yeehaw
My thermometer is always 8-10 degrees higher than the real temperature. This morning it said 52, on the radio they said 41 at the airport, which was less than a mile away from me. Last night it said 67, my buddys car said 57 and I know his was right. It was definitely not 67. Think I can get this fixed or get the thermometer replaced or something?
Old Nov 5, 2003 | 06:31 AM
mc222's Avatar
I hate the Mets
Just do what philgates suggested . Choose -3....Do it three times and then do a -1 , That will adjust your thermometer 10 degrees
Old Nov 5, 2003 | 06:32 AM
fuzzy02CLS's Avatar
Cool feature, Never knew that was there.
Old Nov 5, 2003 | 06:47 AM
BEETROOT's Avatar
Yeehaw
oh I thought it could only be adjusted 3 degrees total, didn't know I could keep doing it.
thanks.
Old Nov 5, 2003 | 06:58 AM
Smitty's Avatar
thanks.
Yeah, WTF?... you can keep doing it???????!!!!!!!!... I thought you could only go + or - 3 degrees....
SMITTY
Old Nov 5, 2003 | 07:44 AM
Sly Raskal's Avatar
i think u can only adjust it once, it's a +/- 3 degrees of what the thermometer reads. you can't repeat it to adjust it.
Old Nov 5, 2003 | 08:14 AM
philgates's Avatar
I think you can only change it 3 degress. Jens would probably know more about it. I stumbled across this feature trying to reset my mainenence light off. I was holding down the select and reset and then it beeped and i saw that i could set the offset for the thermometer.
Old Nov 5, 2003 | 08:31 AM
Jens H.'s Avatar
retired
I think it is 3 degrees as stated earlier .
Jens
Old Nov 5, 2003 | 08:47 AM
philgates's Avatar
Yeah i agree with jens. If you temp is really off you should try to make sure the temp sensor is clean.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Feb 25, 2020 09:57 AM
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
