Thermoblok spacers and traction control throttle body
Never had a clean run
So got everything installed and all seems great. The intake manifold is cool and the TB is even cooler. But the traction control TB is hot! Isn't that kind of working against the point of having a cool IM and TB if the TCTB is feeding the IM and TB hot air? Shall I just create a TCTB coolant bypass myself or is there a reason this is still running the coolant through and getting hot?
Originally Posted by RUF87
I saw that there was a coolant by-pass in the kit, but I thought that was for the TB?
Ruf
Originally Posted by typeR
im saying get rid of the vsa traction contorl unit
Ruf
I am getting codes following approximately 1/2 hour to an hour of driving since installing the thermoblock. Also when the codes are thrown I am not getting good partial throttle response.
It is as if I need a tune up or timing adjustment. When I reset the computer and the car is cool. If anyone has a clue to a fix, please help
it runs great again.
AEMCAI
Comptech headers&exhaust
Springs&sways
VoltageKit(sun systems)&ground kit
17x8" light wheels(10.4lbs ea)
235x45 KDW's
AEMCAI
Springs&sways
235x45 KDW's
Like he says above, wouldn't there be a large gap between the intake sleeve and TB? Also, wouldn't I get CELs by removing that since there are sensors on the traction control unit? If not, then adios traction control! Thanks TypeR
Originally Posted by mrsteve
Swap to a 6MT intake and bye bye traction control! No you won't have CELs however you'd have to find a way to keep the VSA lights from coming on.
AEMCAI
Springs&sways
235x45 KDW's
AEMCAI
Springs&sways
235x45 KDW's
I have Motega Lights
you wont have a CEL but you would have both VSA lights on all the time unless you put a resistor on the harness...and then you will have to use the VSA disable button ,because if you get spin the ecu will then throw both VSA lights if it cant stop the wheel spin ...anyway ive done it and its no problem but you can easily bypass the coolant from the VSA
I was always interested in these types of items like TB and Intake manifold spacers. I'm very curious if it actually works or not. Does anyone know of a intake manifold for the cl type s? Maybe a composite plastic piece that wont heat soak and is much lighter, it seems like these motors have a lot of potential.
cycdaniel
12-17-2019 10:58 AM
joflewbyu2
10-08-2015 11:16 AM
Charlespsu
09-02-2015 09:54 AM
