ThermoBlok
Old Feb 16, 2004 | 12:57 PM
car_lost's Avatar
ThermoBlok
anyone know anything about this? does it really work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460601031
Old Feb 16, 2004 | 10:09 PM
car_lost's Avatar
anyone?
Old Feb 16, 2004 | 10:28 PM
NSXNEXT's Avatar
What year is your car? This will only fit on the 99 TL.
Old Feb 17, 2004 | 07:43 AM
withoutcomp1's Avatar
I actually e mail them two days ago here is the e-mail they sent me- Steve,
Thank you for your continued interest in ThermoBlok spacers. We have completed the design of some different pieces that will work for the later Acura TL and CL. We are now in the process of getting some prototype pieces machined for installation and testing.
Best regards,
Sean Morgan
Outlaw Engineering
Old Feb 17, 2004 | 08:44 AM
car_lost's Avatar
i have an '03 Type-S. i kow it says it will only fit the 99 but whats so different between the engine in the '99 and the '01-'03 (non S). if anything, im pretty sure the manifold one would work with the type s as wel.
Old Feb 17, 2004 | 11:05 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
someone should make a before and after dyno!
Old Feb 17, 2004 | 11:35 AM
Happy CL-S Pilot
It might be worth it for $80 if it can add 4-5 WHP!
Old Feb 17, 2004 | 11:46 AM
NSXNEXT's Avatar
I am going to order mine this week. Not sure when I'll be able to install it.
Old Feb 17, 2004 | 11:58 AM
suXor's Avatar
Still trolling
http://www.acura-cl.com/forums/showt...hreadid=130960
Old Feb 17, 2004 | 12:42 PM
ChadT's Avatar
Spectacular Aroma About
It has the potential to increase power especially if you are driving in a lot of slow traffic. Doesn't make power so much as it prevents power loss from the intake heating up. Here is another thread on it.
http://www.acura-cl.com/forums/showt...ght=thermoblok
Old Feb 17, 2004 | 12:48 PM
Happy CL-S Pilot
so what is the outcome for those who order it?
Old Feb 17, 2004 | 01:13 PM
suXor's Avatar
Still trolling
You guys have got to be kidding, you are not honestly thinking this is worth the pastic it's made out of do you?
How can you believe that the intake manifold imposses it's heat onto the incoming air on it's way to the heads, and into the cylinders? The rate of speed that the air is traveling on it's way in does not provide time to heat it up in the manifold. If the air temp changes by more than +1-2 degrees during that transfer, I would be surprised. The air spends as much time in the manifold as it does in the cylinder awaiting detonation.
If you want to reduce the temp of the air coming into the engine, a CAI is all that is needed. The only way beyond that would be very cold cooling elements in the intake pipe that the air flows over on it's way in. THe cooling elements would have to be plentiful and take up at least 4-5" in length of the intake. You could do it like NoS, and have a freon tank feeding a coil element in the intake, that flows through and is collected ina vacumed collection tank (helping force the freon flow). You could have it on a switch to engage it. I know that is a bit far fetched, and would take more thought then would I just blerted out, but that has much more potentional then this crap spacer thing.
Old Feb 17, 2004 | 01:20 PM
NSXNEXT's Avatar
Like this?
Old Feb 17, 2004 | 01:26 PM
suXor's Avatar
Still trolling
Looks good to me. I would expect more coils though? Perhaps a winding coil element that would be inserted into the intake pipe?
suXor's Avatar
Still trolling
We need a working NA intercooler.
Old Feb 17, 2004 | 01:31 PM
scalbert's Avatar
How can you believe that the intake manifold imposses it's heat onto the incoming air on it's way to the heads, and into the cylinders?...The air spends as much time in the manifold as it does in the cylinder awaiting detonation.
Although I agree that it is probably not worth messing with, I disagree with the heating of the manifold. The IAT, which is located in the manifold, will see temperatures as high as 150F. This is due to the heating from the manifold even when used with the best CAI.
Now, I am sure that not all of the air ingested is not at this temperature. But the IAT is slow to respond so even when going from stop and go traffic to WOT (or sitting at the staging lanes, etc.) the reading will take some time to drop. This means there will be less timing thrown at the engine thus realizing slightly reduced power.
This is merely meant to delay the onset of heat soak. How effective it is would need to be explored further and as I stated, probably not worth it. But the concept is sound, the application may not be.
Old Feb 17, 2004 | 01:57 PM
suXor's Avatar
Still trolling
Would relocating the IAT to the TB be more accurate? Perhaps modifing a TB spacer to install the IAT? Or would that be more trouble then it's worth? Or even worse performance?
OPn one hand, it's noce to have all this computer controlled fuel injection, on the other, they make it damn difficult to improve performance and get the CPU to play nice.
Old Feb 17, 2004 | 02:02 PM
scalbert's Avatar
Probably more trouble...
It isn't just the sensor, it is the filtering in the ECU to smooth the signal which reduces it's response time.
Old Feb 17, 2004 | 02:25 PM
Didn't you people read, it is not out for our car yet i tried to order it 2 months ago and they refunded my money because our motor is different, they are coming out with one soon. there was another thread on this subject do a search!
Old Feb 17, 2004 | 02:34 PM
NSXNEXT's Avatar
Um it is available if you have a 99 TL.... like me.
Old Feb 17, 2004 | 02:43 PM
Yeah, guess your right let us now how it is.
Old Feb 17, 2004 | 02:54 PM
vinarnold's Avatar
i think for the money its a good buy....
Old Feb 17, 2004 | 03:36 PM
suXor's Avatar
Still trolling
Hey newb, we are not talking about availability, we are talking about bullshitability.
Old Feb 17, 2004 | 05:17 PM
Hey loser,
BLOW ME!!!!!! :sqntfawk:
Old Feb 17, 2004 | 09:42 PM
suXor's Avatar
Still trolling
um, ok
Juliet
37
Nov 8, 2007 01:03 PM
CleanCL
Apr 12, 2007 09:26 PM
cadesigns02
Mar 9, 2007 11:02 AM
ghost_masterCL
Feb 5, 2006 03:11 AM
