Temp sensor in cabin?
Old Jun 28, 2007 | 04:42 PM
gsrblack's Avatar
Who knows what this is?
On the dash all the near the windshield are some vents. Directly in the center is a plastic square/rectangle. Apparantly, mine is loose and I can pull it up (looks like it was just glued down and the glue wore out). Anyways, what is the device underneath that cap? Could it be a temp sensor for the inside? What does this thing do? Any ideas to put this cap back down or just glue it?
Thanks.....BTW, this is an '03 CL-S 6MT.
Old Jun 28, 2007 | 05:37 PM
ML03CLS's Avatar
Temp sensor for the climate control.. I'd just glue it down.
Old Jun 28, 2007 | 06:01 PM
aznboi2424's Avatar
actually its the sunlight sensor for the temp control (AC). the actual interior temp sensor the located near your right knee when you sit. it has a little grate on it.
Old Jul 1, 2007 | 01:41 AM
gsrblack's Avatar
What is a sunlight sensor? What would both these sensors be used for?
Old Jul 1, 2007 | 08:50 AM
03sixer's Avatar
2014 TL SH-AWD Advance
Sunlight sensor compensates for the heat of the sun by turning up the AC a little more. If the sun isn't beaming in, then the system assumes that it's not as hot and simply uses the temperature sensors. Someone tell me if I'm wrong.
Old Jul 1, 2007 | 09:49 AM
cltypeSLOW's Avatar
Don't Mess With Texas
no need for correction
Old Jul 1, 2007 | 05:00 PM
fuzzy02CLS's Avatar
Yeah sunlight sensor.
LeVeL
Oct 18, 2015 04:19 PM
RobbDizzle
Oct 15, 2015 11:16 AM
merc009
Sep 29, 2015 03:06 PM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
