Synthetic Oil Question
What weight should I use in synthetic oil for my 03 CLS. The owner's manual recommends 5W20 but I can't seem to find that in Mobil 1's line. Any alternative suggestions?
Re: Synthetic Oil Question
in the summer I run thicker weight oils like 10w30 and in the winter I run lighter weight oils like 5w30.
the owners manual reccomends the 5w20 because it improves fuel economy or allows for better emmisions or something like that...
Thanks for the advice - anybody else care to offer their suggestions?
FWIW, I have read during my research on which oil to use that you want to keep the viscosity span from low to high to 20 or so, since a larger viscosity span means more polymerized molecules to burn and form deposits, so 5W30 would be best, but...
Best
Jim
My ’01 CLS owner’s manual recommended 5w-30 (not 5w-20). It's the same basic engine that’s in the TLS and later CLS (2002 and 2003).
IMO, you would be fine with 5w-20, 5w-30, 0w-20, and 0w-30.
Do yourself a favor and change the oil more often than the factory recommendation, if you are not doing oil testing (once again -- my opinion).
Try some of the good synthetics:
Mobil 1, Amsoil, Redline, etc, etc
Here is a link to Mobil 1 0W-20 (if you want to stick with the low viscosity):
http://www.mobil.com/USA-English/Lub...bil1_0W-20.asp
YMMV
YMMV
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
asahrts
09-04-2015 05:55 PM
