switching the heated pads from different seats
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
can i switch the heated pad from another cl which works? i saw the threads on this forum on how to repair it, but can i just open the seats up and swap out the pads easily? thanks in advanced... btw, my back heater doesnt work, so im planning to swap it off my other cl if possible.
'03 ABP YA4-S 6MT
CL only has back heater in the driver seat. having a back heater in the passenger side would interfere with the OPDS unit. even the TSX's don't heat up.
You can pull a pad, but the wires are probably burned up in that pad anyway. it's better to spend 5-10mins to solder in 12awg wires and have a permanent fix.
is it more simple to switch out the pad instead of soldering it? i have a working back pad for the driver seat from my old cl-s...i think it would beat havnig to solder it...
btw, yesterday i tried to unhook the leather..it seems that the leather wouldnt come off and is attached to the pad??..any ideas? i read the tl forums regarding the fix..but it doesnt takl about the pad being attached and how to remove the leather completely...i dont want to rip anything im not suppose to
'03 ABP YA4-S 6MT
there's upholstery hooks on every edge of the leather, held on by hog rings. you have to open all the hog rings and unhook them from the long metal bars.
and sure you can replace the pad, but the pad itself is not the problem. it's the thin gauge wire that spans the seat connecting the pads together (not the heating elements themselves) that burns up. so you could very well have this problem next year with brand new pads installed
yea i took the hog rings out and removed the long plastic pieces on those bars along the side.... how do i pull that pad out'?? there is still that piece on the chair which u can move against your back....do i have to unscrew anything else? im just going to replace the working ones from my old cl-s to my new one. so im trying to figure out how to just remove the pad and swap them....... do i need to unplug anything as well? thanks
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
09-17-2015 09:01 PM
