Sways ??
Old Nov 14, 2002 | 10:27 AM
DHRJDMBA's Avatar
XSESIVE
Sways ??
Thinking about sways for my car. How big are stock sways? How big are aftermarket - comptech/eibach?
Local shop told me just to do the rear as the front stock is 28mm and there is no need for upgrade. Is this true?
Thanks,
David
Old Nov 14, 2002 | 11:00 AM
CLS2001_97124's Avatar
Revving at 9K...
Sorry I don't know the answers to your question, but I say get it!! The handling is like night and day when you put it on. I;m sure it will be a very nice setup with the springs.
Old Nov 14, 2002 | 11:03 AM
DHRJDMBA's Avatar
XSESIVE
I just want to make sure I am getting the right parts - that is the best part about being on the list - instant product reviews.
Old Nov 14, 2002 | 11:10 AM
Scooter's Avatar
'Cooter
stock sways: 27.2 front/19 back (18 back for NON Type S)
u can just put in the rear sway bar from CT, but if u buy the set, y not just install both...the front CT sway is 27, so it's not all that much different...back CT is 22
Old Nov 14, 2002 | 11:33 AM
DHRJDMBA's Avatar
XSESIVE
Sounds like the front CT sway is no big deal, but the back is worth it. Can I buy just the back? The local guy also mentioned the Eibach sway...
Old Nov 14, 2002 | 11:41 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
buy a set either CT or Eibach
Old Nov 14, 2002 | 11:49 AM
DHRJDMBA's Avatar
XSESIVE
I take it Dean is the man to buy it from???
Old Nov 14, 2002 | 02:07 PM
beerknurd's Avatar
Busy Living
good thread...
on acp.com, they have a neuspeed race only sway(just rear). It's 25mm and states you need to reinforce the frame.
anyone install this? and how do you reinforce the frame?
Old Nov 14, 2002 | 02:19 PM
Titand19's Avatar
East Coast Boost.!
To my knowledge, the Stock and Comptech front sway are almost idential in diameter. The difference comes from the fact that both bars are hollow, but the Comptech has less hollow space than the stock therefore making it more rigid.
Old Nov 14, 2002 | 02:35 PM
Titand19's Avatar
East Coast Boost.!
Old Nov 14, 2002 | 02:53 PM
Fabvsix's Avatar
Cajun Gumbo Man
DHRHDMBA:
I'm NO gear head, can barely put a nail in the wall.....however, don't second guess the bars ! The CT sways are THE BEST MOD you can do. NIGHT AND DAY ! The negative is you'll need to GET RID OF THE PIG FACTORY TIRES ! THEY SQUEAL LIKE A PIGS...... !!!
GOOD LUCK !
P.S. Your dealership service guys is a complete MORON !
Old Nov 14, 2002 | 03:06 PM
sgriffin's Avatar
Please excuse my lack of suspension knowledge.
Any downside at all to the stiffer, larger sways ?
Old Nov 14, 2002 | 03:12 PM
Fabvsix's Avatar
Cajun Gumbo Man
NOT really ! It really address' the understeer and oversteer of this HEAVY car ! Tires SUCK big time. Don't you hear them squeal if you do some quick turns ? As I said, I'm no gear head, I don't hang at the race track, but I do have fun from time to time. SWAYS are a MUST ! I'm still not sold on the headers and certainly have NO interest in springs which do alter the ride.
Get the Sways and some good tires, I got S03's and you'll say to yourself......"Why didn't this car come this way from the factory" ???????
Old Nov 14, 2002 | 03:43 PM
edgalang's Avatar
Purchased: April 28, 2001
Originally posted by beerknurd
good thread...
If you are going to go for Neuspeed I strongly suggest to get both front and back. Matching the rear sway with the stock front will drastically improve understeer, but will most likely kick your rear end out too much. I have both.
The front Neuspeed bar is also 27mm...but let me tell you, it weighs twice as much. Both bars are completely solid, and combined, offers the most agressive sway bar setup. I offer rides to members in local meets strictly because I believe action are louder than words, but I honestly believe that the Neuspeed RACE bars (front and back) are the best bars for our cars bar NONE.
Unfortunately rumor has it that they no longer sell the Neuspeed race to the general public. As for stonger brackets...mind you...all bars were specifically made for the Accord. A CLS/TLS going from 19mm to a 25mm is not as bad as an 98+ accord 4cylinder sedan going from 15mm to 25mm (2003 models are now 13mm). Mind you, the Neuspeed race bars come with beefier brackets and bolts, whereas the Comptech only ships you replacement bushings. I have had my Neuspeed bars for over a year now and has lasted through all the abuse...even after 2 accidents with one involving major suspension damage and the only 2 parts to come out alive were both my Neuspeed race bars and the strut mounted tie bar (oh the OEM springs too).
The only bars I would ever consider to put on my ride is Neuspeed (F:S27/R:S25), Eibach (F:?27/R:S23), and Comptech(F:H27/R:H22), with Comptech being the last choice. But like I said before...Neither the Neuspeed or Eibach are available and the only choice for the moment is Comptech. Sways are probably the best mod you can buy, but you've chosen the wrong time to buy them.
P.S.
I'm not knocking Comptech...they are still good bars (or I wouldnt even consider it)...but there is no point asking "which bars should I get" because you don't really have a choice in the matter. (Except for suspention Techniques...which shouldn't even be an option because they are basically identical to our OEM ones. The market share for Suspention Techniques is for Accords who do not wish for an overly agressive setup)
Old Nov 14, 2002 | 06:10 PM
vuduvida's Avatar
The wall thickness on the stock front sway bar is 4.5mm and with an overall diameter of 27.2mm, that leaves 18.2mm of nothing but air in the center. Those solid Neuspeed bars probably make a huge difference compared to stock.
Is the ride significantly harsher with those bars?
Old Nov 14, 2002 | 08:01 PM
edgalang's Avatar
Obviously you cant satisfy everyone, but for those seeking the ultimate mod in reducing body roll, then these bars are it. The only side effect is when I go up speed bumps and 1 tire goes up and the other side does not. It shakes the car more violently then if you had NO sways to begin with since you semi-remove the independant suspention. If streets were made of glass then you wouldn't even need suspention, but from a practical standpoint...I'm happy with this setup. Honestly, you wouldnt even know they are there until you make your first right turn on a red light.
Old Nov 14, 2002 | 09:29 PM
Wires's Avatar
Change the front as well. The OEM bar is hollow 28 mm, the Comptech one is solid. It makes a world of difference.
Old Nov 14, 2002 | 09:36 PM
edgalang's Avatar
:sqnteek: :shakehd: I'm not going to flame...but please check your facts before posting. Opinions are one thing...but posting wrong information...
Old Nov 14, 2002 | 09:52 PM
Wires's Avatar
Ok, what's the problem? As far as I knew, the Comptech bar was solid. Isn't it?
Old Nov 14, 2002 | 09:55 PM
edgalang's Avatar
Nope. Comptech has yet to publish exact measurements...perhaps maybe they are too similar to stocks for them to do so ...but at least they'll admit that they are NOT solid.
P.S.
We are talking about the front ones only.
Old Nov 15, 2002 | 01:47 AM
bkknight369's Avatar
how much do the sway bars cost (comptech)? Also, if I get them, will the dealership give me any shit when I am getting something fixed (in other words, what are the possible downsides of having the sway bars? faster tire wear? suspension damage? etc).
Sorry if my questions are...ignorant...but thats what questions are for =D
Old Nov 15, 2002 | 01:58 AM
edgalang's Avatar
go here...
http://www.acura-cl.com/forums/showt...=comptech+sway
Downside?
Rougher ride on uneven surfaces
Read the thread...do a search...if you plan of going off road then sways and lowering springs are not for you. Of all the suspention mods (except for tie bars), sways has the LEAST # of possible downsides.
Faster tire where?
No
Suspention Damage?
No
Old Nov 15, 2002 | 06:06 AM
AFitchTLS's Avatar
Get the Comptech Titanium Series Shock Tower Brace.
Old Nov 15, 2002 | 10:09 AM
go here...
Downside?
Faster tire where?
No
Suspention Damage?
No
cool thx for the info
Old Nov 15, 2002 | 05:37 PM
Wires's Avatar
P.S.
Ahhh Really..... Good to know. I'm not super happy with the Comptech bars (They are way better than stock, but could be more stiff).
At least I know that I can replace them and get better!
Thanks for the correction.
Old Nov 15, 2002 | 05:45 PM
edgalang's Avatar
Get the Comptech Super charger WTF is the point of this post? Stick to the topic.
Old Nov 15, 2002 | 06:40 PM
EricL's Avatar
P.S.
Even after I talked to an engineer there about the complete specs, they changed the data after I talked to them.
The front was supposed to be a thicker wall and the calc is more involved than just doing a solid bar calc (solid change: just use ratio of forth power of diameter if steel has same modulus and are solid).
Who knows what the real story is. I've seen the "specs"/"info" change twice (my oldest posts are long gone) with the same bars.
The do seem to work. They seem to have a slight bias towards oversteer (more increase in rear roll stiffness).
YMMV
Old Nov 19, 2002 | 09:23 PM
beerknurd's Avatar
Busy Living
if you could only get one, would it be the front or the rear sway bar?
Old Nov 19, 2002 | 11:40 PM
edgalang's Avatar
The rear...but with comptech's you dont really have a choice. it's both or nothing.
Old Nov 20, 2002 | 10:17 AM
typeR's Avatar
did a search after someone else was talking about sways...i think i would go neuspeed race when i add sways...correct me if im wrong but might sways also add to off the line traction...as we launch theres probablly some torquing of the suspension and i m thinking the sways might make the rear suspension take the weight shift on more evenly and reduce the transfer???
also all these sways are made for the accord as previously stated, so what might be a nice increase for them, is modest for our heavier more powerfull car, and what might be very stiff (race)for the accord, ends up being just right for the enthusiast..
Old Nov 20, 2002 | 10:37 AM
DHRJDMBA's Avatar
XSESIVE
I ordered my Comptech sways last week and will post any improvments once I get them installed. Should be late next week. I hope...
Old Nov 21, 2002 | 12:01 PM
beerknurd's Avatar
Busy Living
DHRJDMBA
hey, can you take a test run after you install either the front or rear? then let us know if there was any difference with both of them installed? I don't think it'll matter which one.
This could determine the affect of the front sway. I still cannot see how much diffence it could make, even if it has slightly thicker walls.
Old Nov 21, 2002 | 12:52 PM
Collective27's Avatar
Certified Lurker
Just had my comptech sways installed, going to pick my car up in like an hour or 2, will give a review when i get it.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
steve
Sep 30, 2015 09:23 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
