Suspension Question
Suspension Question
After having the dealer install my CT springs I have been experiencing a clunking noise on the rear right shock area/pillar/rear deck. I have not taken the car back to the dealer because I am 2.5 hrs drive from the dealer. I was wondering if any one can help with specifics regarding parts that are normally losen and unbolted during the process of instaling the shocks and springs. I have gone under car and retighten the CT swaybars, but what else do I need too look for. Please help.
Also the stock springs had a black rubber guard on the bottom coils closes to the perch, should i have to place these on the CT springs for any reason.
Thanks for the info guys.
I have used the search but cant fing anything
teh Senior Instigator
it may be the springs rubbing against each other. Did the springs come w/ a little rubber insulator to put around the spring?
Originally posted by dfv3.2CL-S
no, the springs did not have any rubber insulators.
CT wraps the first few rows of springs with a black foam/rubber.
Where did they come from?
Guys,
I purchased the spring on the blackmarket and they are CT springs. Also my dealer installed with no problems at all, but the only issue that I have is that I hear a clunk sound once in a while depending on road surface. My problem is not squeaking springs. I need to know what other parts of the suspension I could tigthen up to help resolved this annoying sound in the right rear. All other corners seem to be fine with no noise.
BoricuaTL
04-08-2016 01:08 PM
