Supercharger and Unichip
Old Feb 18, 2005 | 12:07 PM
Seattle Cl-S's Avatar
Blown LS6!!
I just pulled this off the Unichip website... I called Jack and he said it wasn't a misprint. Does this car belong to anyone here? Must be since the CL Unichip was a limited run. The dyno looks a bit generous but some benefits are there. Jack said they kept it conservative so as not to run too lean...which the test car was running with the HBP. My Unichip is collecting dust anyway so maybe I'll drive down to Oregon.
2001 CL w/ SC, HBP, Catback, 4th gear dyno
Old Feb 18, 2005 | 12:22 PM
Smitty's Avatar
I find it hard to believe that chip makes 50WHP.
Old Feb 18, 2005 | 12:29 PM
mattg's Avatar
where do you see 50whp?
Old Feb 18, 2005 | 12:39 PM
Smitty's Avatar
showing peak HP at 340ish on auto S/C Cl-S with HBP.
we know 298 is S/C Auto S/C CL-S w/ HBP.
So I guess-stimated....
am i reading that wrong?
Old Feb 18, 2005 | 12:47 PM
Blown LS6!!
You're reading it correctly except you should only be looking at the difference between non-chip and chipped. Max gains are 12hp somewhere up in the 6k range.
I'm not taking the exact numbers to heart, just the net gains.
Old Feb 18, 2005 | 12:54 PM
phipark's Avatar
Not Asian
the pre-unichip dyno is overrated too. It's all relative.
I say it's worth it to go have it tuned. I know the Accord guys were getting it tuned with the S/C as well.
Old Feb 18, 2005 | 05:22 PM
av6ent's Avatar
Well, with Unichip you'll have to keep ESM while with E-manage you dont . And based on E-manage, tuned boosted cars seem gain enough with good fuel delivery. I heard ESM is bad for tuning
Old Feb 18, 2005 | 05:46 PM
Blown LS6!!
True, but I bought the Unichip before I got the S/C. Now that I'm stuck with it I might as well use it if it gives me gains. I a few more peeps get in on the Intercooler then I'll get that and the emanage.
Old Feb 18, 2005 | 05:47 PM
mattg's Avatar
their graphs are shown in crank horsepower
Old Feb 18, 2005 | 06:57 PM
johntypes's Avatar
3rd gear is your setting not 4th gear
Old Feb 18, 2005 | 07:06 PM
scalbert's Avatar
It is entirely possible. All they are doing is lowering the MAP signal some to lean the mixture out a bit. But that relys upon excessive fuel pressure to be rich in the first place. And I beleive most have seen how high the pressures go and are aware of the long term potential issues. That FPR is not known to be the best item in the SC kit.
I can see two potential issue. The first one would be if the kit were tuned in warmer weather. Once winter rolls around you will be running lean. This was seen on the NA Unichip application and it would be worse with the blower in place. Plus, you have no way to adjust the tune without going to someone to get it done.
Secondly and possibly worse, if the FPR starts going out and the MAP signal is lowered you go leaner and sooner. You would be leaner than what just would occur without moddifying the MAP signal and that alone was enough to potentially cause damage. IMO, it would be engine damaging lean quickly.
Old Feb 20, 2005 | 04:57 PM
darrinb's Avatar
///M POWER
with the s/c, i'd go with the e-man
Old Feb 20, 2005 | 05:15 PM
Ant7701's Avatar
Sweet as Gold
stay far away from the uni-chip man....far far away
BoricuaTL
Apr 8, 2016 01:08 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
