Supercharger owners
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
Supercharger owners
Question - if you had the opportunity to get a complete Turbo system (incl. blow off valve, s-afc, etc.) installed for $4k, would you still have gotten the supercharger? I ask because I found a tuner shop that has already installed a complete turbo kit on a 3.2L and will do it for that price.
Re: Supercharger owners
MORE INFO PLEASE!!!!
Oh...Behave!
But, you know what they say, "If it's too good to be true, it probably is!"
Censored User
Re: Re: Supercharger owners
I didn't get nitty gritty details as to the install other than it taking about 2 weeks. But I'll go back there tomorrow and get them to write down everything thats included.
Happy CL-S Pilot
I want a complete system:
Somthing liket the one was done by All_motor. Including the thermal wraps (or swain coating). 3 Gauges, Boosting, Tranny Fluid Temp, and digital Wideband O2 sensor that tracks lean/rich conditions.. Oh... yeah a digital boost controller witha turbo timer!
Cool.
Cool.
Censored User
I'll get them to write it down then we can compare notes tomorrow. To be quite honest I don't know all of the componets of a complete turbo system. They say its complete but we'll see.
They would be supplying a used turbo, rubber oil hoses and no intercooler...
Every time I hear about a VAFC being used on this type of car with forced induction I know they are full of it!!!
But to answer the question, it depends on who is supplying the kit. If it is from some shop that has no real customer support, no detailed instructions, no warranty support, etc. then no. If it is from someone who will stand behind the product no matter what, has their own test vehicle which has many miles on the system, etc. then yes.
If I wanted a chop job I would make a custom system myself.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
SHIFT_over.so.I.can.see
If I were to choose I would stiock with Comptech. They have been more than helpful support wise and will warranty their parts. They have a big name to support and will not leave any owner high and dry. As an example, look at Allmotor2000's experience with them about the clutch issue. Even though it wasn't their fault they wanted to make sure so they went through the motions and followed up. They could have just told him to fuck off. When it comes to something as important as forced induction I wouldn't go with anyone but a real pro. Any idiot who knows how to turn a few bolts can open up a shop. Very few though have a following of customers and build a name for themselve and actually stick around.
BTW: a custom fabricated manifold itself will generally cost between 800 to 1200. That combined with the fact that a brand new high quality turbo will generally cost near the same price range of 1000-1500, there is no way a quality kit with all parts necessary could cost 4 grand. You've gotta have R&D money, isntallation money, tuning time, and just other labors themselves at average shop price would make things topple over 6.5K or so.
If you were to do all the work and research yourself then MAYBE you could shave it under 5K
(1) Using a remanufactured turbo
(2) Mild-steel piping (cracks easily and isn't strong)
(3) Not-upto-snuff fuel control mods
(4) No guages, boost control, temperature-control stuff
I could be wrong... but then again I'd like to see the HP output. If they claim to boost > 6psi... they are full of it because this car will detonate like crazy even with an IC on 91-93 octane.
Censored User
okay I've got some answers
I went back to the shop. The manager says it'll cost over $5k now. I have a pic of the work order. He says the Turbo is tunable up to 20 PSI. He also said I should run it up to 10 PSI, (for 100 whp) but I told him that CT only set their supercharger at 4.5 PSI. He'd also put the battery in the trunk. He only suggested the injectors for more than 10 PSI, but I told I wouldn't go over 10. 10 days work. If someone will host the pic we can all see the work order.
Censored User
Originally posted by fuzzy02CLS
What's the shop's name? It's in Miami?
Re: okay I've got some answers
20 PSI on a 10.5:1 CR motor on pump gas...
![Nervous](https://acurazine.com/forums/images/smilies/nervous.gif)
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
So how would he propose to control the larger injectors??
Censored User
scalbert I should have come to see you last week. I was in Marietta for an entire week. Didn't know woodstock was so close.
You should have dropped me a note. My office is in Kennesaw so I was just around the corner. Where at in Marietta?? And yes, Woodstock is just a few miles up I-575.
Censored User
just off of roswell rd. (east cobb) parents live on old canton rd. I'm not too familiar with the area, but they're about 5 min from the east cobb Ymca. BTW do you think you could host the pic?
I see a problem which is alerting. The VAFC can't be used with our cars and forced induction. It alters the MAP signal to do its thing. However our MAP cannot see positive manifold pressures which eliminates the VAFC function.
Not knowing this is cause for serious alarm.
![](http://www.flwse.com/images/steve/Misc/sm0093.jpg)
lover and fighter
I'd run too...There's a shop here in Jax that would make a custom kit running 6psi, but it would take 4 days to do and cost over $7k...Granted they'll push the turbo for total performance, and I've seen many examples of their work, but it is comforting when the same guy looks and says: I would rather talk you into getting the Comptech s/c which I'll install in two days for a total of $4700 o/t/d...
Censored User
Censored User
by the way I should have given you a holler too, 'cause I was in Jax over the weekend. But I had to see my best friend.
08_UA7_Gr33k
02-11-2016 02:17 PM
Joe Avesyan
09-29-2015 03:57 PM
