Supercharger belt size Comptech
Old Mar 20, 2007 | 06:45 PM
jproy's Avatar
MP90 uninstalled
Does anyone know what size the Gatorback belt supplied with the Comptech supercharger for the CLS 6-speed is? I think it is 4040252. Can someone verify this please. There is a thread floating around here that says it is a 4040245 and I am pretty sure it is wrong and should be deleted.
Old Mar 20, 2007 | 07:44 PM
Allout's Avatar
Blown is Best
Mine was a 4040252.
Old Mar 20, 2007 | 08:22 PM
mrsteve's Avatar
There's two different sizes of belts that will work. The larger of the two is sometimes required for the high boost pulley.
The 4040245 is a 24.5" belt. The 4040252 is a 25.2" belt.
Both belts will work with either pulley it just is a pain in the ass at times to squeeze on the 24.5" belt over the larger high boost pulley.
Old Mar 20, 2007 | 08:50 PM
JBlueCLS6's Avatar
Also do not run the Underdrive pulley. I noticed it in your sig just in case you didn't know.
Old Mar 20, 2007 | 11:37 PM
jproy's Avatar
MP90 uninstalled
Ah, Thanks for the input guys. I have already removed the UR underdrive pulley and replaced it with the stock unit. I have the regular and the high boost pulley and noticed that the used belt I have is the 25.2" belt. Well now we have a good supercharger belt thread that talks about both belt sizes for the HBP and regular boost pulley. I will be using the regular pulley as I do not want a single problem down the road. I have a plethora of supercharger parts. I really got hooked up. I now have a new 24.5" belt I will be using with the regular 4.5 psi pulley. I got it from Summit Racing for $17.
http://store.summitracing.com/egnsea...+115&x=29&y=11
It says its $7.## but they hit you with a $10 service fee or some crap. My belt came for m them with a catalog, a Summit Racing hat, a bunch of NHRA stickers, and an assortment of other promotional nonsense.
Old Mar 21, 2007 | 09:08 AM
JBlueCLS6's Avatar
You won't have a problem running the HBP. Just disconnect your IMRC
Old Mar 21, 2007 | 01:01 PM
jproy's Avatar
MP90 uninstalled
So you are saying I can run the HBP without any fuel managment or tweak to the FPR. I was told by Comptech that I would have to adjust the FPR to use it. I have no access to a dyno nor would I trust my baby to anyone around here. What should I do? Like I said before, I want tho have this car for a while. Its in perfect condition. How much more power would it make?
Old Mar 21, 2007 | 02:17 PM
mrsteve's Avatar
You'll pick up around 25-35whp with it.
Just adjust the fuel pressure slightly on the FPR. Should be easy to do with your gauge.
Old Mar 21, 2007 | 02:39 PM
R J Poseidon 6's Avatar
~HondaF1~
Why is this anyway?
Old Mar 21, 2007 | 04:43 PM
JBlueCLS6's Avatar
Originally Posted by R J Poseidon 6
Why is this anyway?
You'll lose boost.
Old Mar 21, 2007 | 04:47 PM
mrsteve's Avatar
Why is this anyway?
Smaller pulley on the crank will reduce the amount of rotations on the alternator pulley in relation to engine RPM. Slower alternator speed = slower supercharger speed = less boost.
Old Mar 21, 2007 | 04:49 PM
mrsteve's Avatar
UR does make a stock size crank pulley that is lightweight. Although I'm not sure you'd experience any noticeable power gains.
I'd much rather keep the stock crank pulley and add a lightweight flywheel.
Old Mar 21, 2007 | 04:52 PM
~HondaF1~
Ah .....
Thanx!
Old Mar 22, 2007 | 12:24 AM
jproy's Avatar
MP90 uninstalled
I dont have a Fuel Pressure guage. What do they cost? Where to get and where would I install it? I will admit that I am a bit of a rookie when it comes to the actual install of the supercharger. I will do some searching and see what I come up with. I am sure this has all been covered before.
Old Mar 22, 2007 | 02:38 AM
Allout's Avatar
Blown is Best
I don't have one installed yet but this is what I've got. I bought a 1.5" mechanical gauge that I need to install. I picked up this Marshall Industries one for less than $25 from these guys:
http://cgi.ebay.com/ebaymotors/0-100...spagenameZWDVW
I picked up a No. 6AN male to -6AN female fitting that has a 1/8" NPT port. This should go right inline at the fitting that replaced the stock FPR.
Take a look at page 10 of the install instructions for the SC and you'll see where I mean on fitting "D".
http://www.comptechusa.com/store/med...ons/ins104.pdf
This won't help me monitor the fuel pressure as I'm driving but will help me set the base fuel pressure if I need to adjust the FPR.
Old Mar 22, 2007 | 10:53 AM
jproy's Avatar
MP90 uninstalled
Great. I know the part of the instructions you speak of and that seems simple enough. I guess I need to find a dyno where it can be adjusted. Anyone know of one around here? I would be willing ot go to Houston or Austin if I had to.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
