supercharged peeps need some help!!!
Old Sep 22, 2005 | 09:17 AM
superchargedcls's Avatar
i have a major issue with my tension pulley on the supercharger. well to make a long story short it disintergrated! ask me how and i tell know lie i have no idea! has this happened to any one else here. PLEASE HELP
Old Sep 22, 2005 | 09:27 AM
derelict's Avatar
I had mine wear down a little which caused a wobble and the belt to keep hopping off the pulley. Mrsteve also had a problem with his, almost exactly the same as your's if I remember correctly. Either way, gotta replace it...
Old Sep 22, 2005 | 09:29 AM
Yeah I Know But My Problem Was It Did Not Wear Down It Looks Like It Totaly Disintergrated. I Am Going To Call Comptec Now
Old Sep 22, 2005 | 11:45 AM
BlackV62K2's Avatar
Post some pics.
Old Sep 22, 2005 | 12:36 PM
NSX-Tuner's Avatar
boosted is best
Maybe the belt was over-tightened? Ask Shad at CT about how to check belt tension properly.
Old Sep 22, 2005 | 01:10 PM
02AV6's Avatar
563hp daily
Sounds like belt was too tight and you might need a replacement. Call CT.
Old Sep 22, 2005 | 01:26 PM
brianlin87's Avatar
ASM I.S. Design FTW.
^ Good to see a higher quality pic of your car on your avatar Serge.
Old Sep 22, 2005 | 01:28 PM
NSX-Tuner's Avatar
boosted is best
As per Shad at CT, to check the sc belt tension, using the following technique:
Twist the sc belt between your fingers at mid point between pulleys:
1) More than a 90 degree twist is too loose
2) Less than a 45 degree twist is too tight
Please note: this was for a TL/CL sc kit.
Old Sep 22, 2005 | 01:48 PM
Thanxs Guys I Am Ordering A New One Today. I WILL POST SOME PICS WHEN I TAKE IT OUT
Old Sep 22, 2005 | 04:09 PM
Smitty's Avatar
24 FT/LBS of tension..
Joe Avesyan
Sep 29, 2015 03:57 PM
Medinak12
Sep 23, 2015 07:11 PM
k6biv
Sep 22, 2015 02:06 PM
Redsand353
Sep 6, 2015 01:03 PM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
