supercharged peeps need some help!!!
i have a major issue with my tension pulley on the supercharger. well to make a long story short it disintergrated! ask me how and i tell know lie i have no idea! has this happened to any one else here. PLEASE HELP
I had mine wear down a little which caused a wobble and the belt to keep hopping off the pulley. Mrsteve also had a problem with his, almost exactly the same as your's if I remember correctly. Either way, gotta replace it...
As per Shad at CT, to check the sc belt tension, using the following technique:
Twist the sc belt between your fingers at mid point between pulleys:
1) More than a 90 degree twist is too loose
2) Less than a 45 degree twist is too tight
Please note: this was for a TL/CL sc kit.
Joe Avesyan
09-29-2015 03:57 PM
Medinak12
09-23-2015 07:11 PM
