To SuperCharge or TurboCharge?
Old Mar 21, 2002 | 07:51 PM
kevp913's Avatar
Hey guys. I have been thinking for the past couple of months whether to put a turbocharger on my CL-S or a supercharger (waiting of course for one to be released!). I have heard that turbocharging engines in Honda/Acuras can be really bad for them and that i should ONLY supercharge. Have you guys heard anything about it? Cus a turbo on a CL-S would be sweeeet!
Old Mar 21, 2002 | 08:24 PM
JRock's Avatar
Old timer
Save your money and buy a car meant to tolerate charging.
This car is the antithesis to such a car: We are FWD, weak auto tranny, small brakes, and front heavy.
You really want to do this with a different car.
Old Mar 22, 2002 | 12:21 AM
kHmER Co's Avatar
mister D
yeah but it would be cool to see a turbo setup on a CL-s... i say go turbo!! sc uses engine power to produce power... while turbo's use exhaust pressure to make power!!... go TURBO
Old Mar 22, 2002 | 09:03 AM
mistacanyon's Avatar
Mr. PC
I'm not real familiar with turboing a NA engine but I know you're gonna run into a lot more problems than you think. Not with the tranny but with enigine components. I'm sure there's someone here that knows specifics...
Old Mar 22, 2002 | 09:11 AM
Type S's Avatar
Powered By HONDA
it is totally up to u..i prefer supercharger ....no need to worry about over heat..or cooling system....turbo got a lot of boost power..but u need to worry about turbo lag and over heating..cooling system..upgrade a bigger fuel injectors...etc....
Old Mar 22, 2002 | 09:14 AM
spiroh's Avatar
I fI had to choose between the 2 for our cars, it would be the supercharger.
Old Mar 22, 2002 | 09:19 AM
4pumpedCL's Avatar
Honkey
I think a turbo would be cooler, gotta love the sound of a blowoff valve. However, a supercharger would be a heck of a lot easier considering comptech should be selling one any day now.
Old Mar 22, 2002 | 09:46 AM
Zapata's Avatar
Cost Drivers!!!!
A turbo setup won't work on our cars without some MAJOR and i mean MAJOR engine work. The compression is too high. It would need to be lowered and this you'd have to lower compression pistons, which means you probably have to do some work on the head or block etc., etc., It would cost you atleast 10k for a custom setup since nobody currently procduces it. Rick case and 4.1L TT setup but something in the transmission kept breaking. Also remember that w/ a turbo setup the fuel mappings in the ECU would need to be reworked.
A supercharger is the best bet for the current CLS.
Old Mar 22, 2002 | 12:32 PM
BNut's Avatar
S/C'd Accord Coming Soon!
Here's how *I* see it.
Do I want a daily driver with a lot of power, or a balls to the wall 1/4 mile monster?
If your answer is Daily Driver with a lot power, then think Super Charger.
If you answer is balls to the wall 1/4 mile monster, think Turbo Charger.
Unless you use a twin turbo sequential setup (I think that's the right term), you will have to makes sacrifices with a turbo setup for either quick spool up good low end, but poorer top end, or more turbo lag down low, but awesome top end power.
A roots/eaton SuperCharger will give you the AWESOME low end power, put your top end will be limited unless you go with a centrifugal type (ie Vortex) super charger.
I believe most super charger setups are load based, so that they ONLY provide boost when you need it. The parasitic effect of the SC shouldn't be much worse than running your AC compressor.
Joe Avesyan
Sep 29, 2015 03:57 PM
k6biv
Sep 22, 2015 02:06 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
