Supercharge fuel pressure
I would like to know if the Comptech Supercharge fuel pressure regulator is adjustable. My fuel pressure is at 27psi at idle with vacuum hose connected and 59psi with it disconnected. I would like to raise the fuel pressure at idle because my check engine light is on. Code p0171 and P0170 system too lean. Acura recommend 40-46psi at idle with vacuum hose connected and 50-54 with it disconnected. I know this numbers are for a stock N/A CL.
Originally posted by Ogolden1
yes, it is... the set screw at the end if the diaphram.
Are you sure your adjusting it correctly?... You need to loosen the nut with a box wrench then turn the adjustment with an Allen wrench while you have the box wrench on the nut.....After you adjust it, you then need to shut the car off and turn it back on..restart the car after every adjustment then tighten the nut back down while holding the allen wrench in place.
Why do you have to restart the car after every adjustment? It's not like when there is boost you restart the car at every psi!!
The fuel-pressure is increased by restricting the return to the gas-tank - no reason to restart.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
Joe Avesyan
09-29-2015 03:57 PM
