Supercharge fuel pressure
Old Feb 14, 2004 | 08:09 PM
sgmotoring's Avatar
Bleed Honda Blue
I would like to know if the Comptech Supercharge fuel pressure regulator is adjustable. My fuel pressure is at 27psi at idle with vacuum hose connected and 59psi with it disconnected. I would like to raise the fuel pressure at idle because my check engine light is on. Code p0171 and P0170 system too lean. Acura recommend 40-46psi at idle with vacuum hose connected and 50-54 with it disconnected. I know this numbers are for a stock N/A CL.
Old Feb 14, 2004 | 08:46 PM
Ogolden1's Avatar
Oh...Behave!
yes, it is... the set screw at the end if the diaphram.
Old Feb 14, 2004 | 09:58 PM
allmotor_2000's Avatar
My pressure (NA) is 56psi at idle with the vacuum connected and 62psi without the vacuum connected.
Old Feb 14, 2004 | 10:47 PM
sgmotoring's Avatar
Bleed Honda Blue
I tried that but the fuel pressure stayed the same. I turned the screw one complete turn both ways (clockwise and counter clockwise). The fuel pressure didn't move.
Old Feb 14, 2004 | 10:55 PM
Then your FPR is probably broken and you should NOT boost until it is fixed!!
Old Feb 14, 2004 | 11:12 PM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
it may need a rebuild?
I know my fpr came with a couple different springs for higher/lower ratios
Old Feb 14, 2004 | 11:21 PM
Ant7701's Avatar
Sweet as Gold
yeah...prolly busted or maybe installed wrong. Allmotor is right...no boost til u fix it or your gonna blow a head gasket!!
You probably should run the spring/diaphragm for the highest rate-of-gain.
Old Feb 15, 2004 | 10:41 AM
ModAddict's Avatar
Old Feb 15, 2004 | 11:55 AM
Smitty's Avatar
Are you sure your adjusting it correctly?... You need to loosen the nut with a box wrench then turn the adjustment with an Allen wrench while you have the box wrench on the nut.....After you adjust it, you then need to shut the car off and turn it back on..restart the car after every adjustment then tighten the nut back down while holding the allen wrench in place.
Old Feb 15, 2004 | 04:58 PM
Why do you have to restart the car after every adjustment? It's not like when there is boost you restart the car at every psi!!
The fuel-pressure is increased by restricting the return to the gas-tank - no reason to restart.
Old Feb 15, 2004 | 06:54 PM
Smitty's Avatar
.... I did, I did not notice any difference with the car running... when I shut it off and started it back up I noticed the change in Fuel pressure... I only had to bump it alittle.
Old Feb 15, 2004 | 08:33 PM
Probably the idle-level (or warm-up vs warmED-up) has the biggest effect on fuel pressure (other than the regulator itself).
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
