Summer project help
Old Feb 2, 2014 | 10:02 PM
dutchez cl type s's Avatar
Summer project help
Ok people i'm new to here so bare with me . I have a 01 Acura cl types i'm trying to 6speed swap and build a 3.7 in the summer. So what parts and tips to make that 3.7 possible?
Old Feb 3, 2014 | 02:03 AM
or can i go 3.6 with a custom turbo kit which will have more gains.
Old Feb 3, 2014 | 02:39 AM
Karanx7's Avatar
Unregistered Member
Realistically, you're not going to go turbo if you have to ask those questions. It's a lot of custom work that you'd have to figure out yourself.
The six speed swap is definitely something to do before going turbo. Just search for the part list and start scavenging the pieces.
Old Feb 3, 2014 | 10:26 PM
Cocoa's Avatar
2600lb CL
Honestly if you have the cash, you really don't need to know much of anything, just so long as the goals are feasible. Based on both his replies, either is doable already without much headaches to go through.
The question to the OP would be, how much bs usually flows from your mouth (how honest are you really with yourself)? Depending on the answer, would determine if you can handle the $6k project, or the $10k project.
There are countless threads like this one that never make it to the beginning stage of the damn project. So with that said, use the "Search" feature located on the upper right side of the homepage to the 2nd Generation CL section of the forums.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
tsx_boy
Dec 13, 2019 08:33 PM
RobbDizzle
Oct 15, 2015 11:16 AM
lanechanger
Oct 13, 2015 10:56 AM
Sep 14, 2015 03:16 PM
