Stripped lug nut. Please help.
That's hot...
I have acorn style tuner lug nuts like the ones below, and some how I managed to strip one. Does anyone know of a way i could get it off?
Thanks let me know
Thanks let me know
Find beauty in dissonance
Is the lug nut still on the stud?
To replace studs, take the wheel off, spay some liquid wrench on the stud (if lots of rust) and wait, tap out the stud and replace.
Masshole
This happened to me on my SSR GT1's on my CLS. My rim lock stripped and I took it to a welding shop, they tack welded a nut on the rim lock and took it off that way. Problem is, the tack welding destroyed the clearcoat on the rim.
Craftsman 10 pc. Impact Grade Bolt-Out™ Damaged Bolt/Nut Remover
http://www.sears.com/sr/javasr/produ...id=00952165000
Masshole
As for locks, if you have clearance, vice grips work ... I don't think you would have clearance unless you had the old steal wheels (that the last car I had to do that on).
B A N N E D
Originally posted by GEB
This is what I would try ... if it doesn't work, take it to your local tire shop. They might have a few tools you don't. I know they make a socket that hugs the sides of a bolt. If you take it to a shop, they will most likely be able to get it off without a big issue. In fact, I would take it to a local shop before spending the money on the bolt remover.
That happened to 2 of mine and doing it myself I ended up breaking one of my studs, the Dealer charged 90 bucks to replace that. I took it to a rim shop and they found a socket similar to the one that I had and they hammered it in so that it was nice and snug, and that’s how they ended up taking that out.
I don't go to the dealer for anything except warranty work. They charge for everything! I have a nice local shop that works only on Honda and Acura cars. It's not that I couldn't do it my self, it's just that those guys are so much better at it them me. What takes me 4 hours, they do in 1. It pays to find a good local shop ... and they are very hard to find!
DAMN
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
registered pw
if it is stripped, i have already used a metric socket on the lugnut.
you may have to tap it on with a hammer, make sure it one that is tight. you will prob have to use some sort of lever to break it loose.
then you will have to figure out how to get the nut out of the socket.
but at least the wheel will be off
Originally posted by JaySyn77
Shawn, have you ever used the gator grip? I've thought about getting it, but I've always wondered if it really works. Let me know
THEY WORK.
And I heard that it’s the tool of choice for wheel thieves.
It’s quite easy to bypass OEM wheel locks with one of them and a big hammer.
B A N N E D
You live in the Bronx, go to Webster AVE, there are like 50 tire shops there they will remove those for you in minutes and for nearly nothing and they are pros in stealing cars and taking wheels off, locks or no locks...
neuronbob
23
07-16-2019 10:48 AM
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
