storage question
Old Sep 28, 2007 | 08:20 AM
FFEMTSHAFER's Avatar
Combat Medic
storage question
Hey guys, I got orders to go to Ft. Riley, Kansas then to Iraq. The CL will be going into storage for no more than 18 months. What are some things I should do beforehand, ie engine, tires?
Old Sep 28, 2007 | 08:36 AM
fuzzy02CLS's Avatar
Less then 1/8 tank gas. Pump up your tires to max PSI, disconnect your battery, & wash it good before you put it away.
Nothing else really needed on such a new car.
When you get back your likely have to drain the fuel & charge the battery, then start it up. You may want to put all 4 corners on jack stands to get the tires off the ground so they don't flat spot.
Old Sep 28, 2007 | 10:02 AM
ms_cls's Avatar
Only CL in town!
not much more to do beside bring it to mississippi to me
Old Sep 28, 2007 | 10:46 AM
OrngeAc3.2's Avatar
bring that shit to iraq, paint it camo, and put a big red cross on the front of it!!! good luck over there guy, be careful!!
Old Sep 28, 2007 | 10:58 AM
SuperTrooper169's Avatar
In the Mid-South meow
Isn't there a fuel stabilizer that you can use so you won't have to drain the fuel after storing it?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
dirleton
20
Oct 16, 2015 01:48 PM
Desert Ridge
Sep 27, 2015 02:37 PM
