Is the stock cat hi-flow?
As stated before, 1" less back pressure = 1 HP gain, just a general concept but seems to fit in this case. Out catalytic converters have about 1" - 1.5" pressure drop per every 100 CFM. Our cars will flow about 400 CFM max. That is a maximum of 6" back pressure.
If you put in a high flow catalytic converter, say with 50% more flow capability, you can expect to gain a whooping 3 HP...
Just keep to a good brand of gas and retain that same amount of HP.
the main reason i opted for a hi-flow cat was due to the 100 shot. i also have 2-1/2" piping & a 2-1/2" custom y-pipe. the low-end loss is minimal but above 4k rpm in combination w/ headers & my ignition, the output is definitely worth it even if you're not spraying like i am. i hope this helps.
Originally posted by Chris
any thoughts on completely removing the cat? how much HP do you think is gained by taking it out completely and replacing it with a straightpipe? scalbert?
hmm... yah i know if caught i could be in big trouble... but as PimpinWhiteCL-S can confirm as well, when we drive on the freeway and floor it, the pull seems be much better and the car picks up faster; a noticeable difference in power
a buddy of mine did remove it completely for his nitrous w/ a straight pipe all the way back from the headers & had it bolted on to the stock y-pipe.
this definitely makes you lose a lot of back pressure.
my system was constructed w/ keeping the right amount of back pressure in mind. this is why i also welded a resonator to suppress some of that free-flowing sound & to minimize back pressure losses.
-an axle-back exhaust (2 mufflers) will not give you any gains
for $500.
-the greddy cat-back will give you more gains for $800.
-my system is very free-flowing but was all custom mandrel bent for a total of $900 including the HKS mufflers, hi-flow cat, resonator, mandrel-bent 2-1/2" piping & y-pipe, & all labor charges.
there are minimal amounts of torque losses, but definitely huge gains in the higher rpm's. the sound is incredible as well. it all depends on what you're looking for. i would definitely recommend it to anyone looking for gains.
hope that helps.
for $500.
hope that helps.
Originally posted by DG-T-S
a
a
Probably crush bend...mandrel is a specialty shop thing...it requires a special machine that is not cost feasible unless you do a lot of custom exhaust work...the difference is maybe 2-3 hp gain depending on the bends...so, as great as mandrel bent piping is supposed to be...it doesnt offer incredible gains over crush bending. Especially when you consider from the cat back...there is one slight bend...and then the Y-pipe. Keep your cat unless your using fi (nos,sc, turbo). I'm using 2 1/4" right now...and it is big enough over stock that you get a good combination of torque and high end power.
hmm... never knew... thanks for the info
Originally posted by spiroh
Dynos dont lie. Sure I gained HP, but lost a lot of low end torque. Johntypes also dynoed his car with the same results. Just stick with the stock one, unless you have a supercharger.
Does no one listen to you? AHH well, they will learn.
Originally posted by mbeebe
Does anyone know how restrictive the resonators are? Is it worth getting a resonating tip with stock resonators in place?
Ah well...I'll get a new resonator welded back on next week.
i really doubt sportcompact saying that. no catalytic can flow max power while still being carb/emissions legal. i live in florida & we don't have emmissions anymore. if i wanted, i could simply have a straight pipe, but we all need back pressure.
why not
First of all...
I thought the only thing that needed backpressure was desiel engines....
Secondly:
I would think that the headers were designed to provide enough backpressure, because after the headers the rest is just free flowing..
Take a look at the pic... an eletric exhaust cut out... You weld a Y branch off the piping and install this bad boy before the Cat...
I am seriously thinking about since I am getting the SuperCharger... that son of bitch will scream down the track or scare the shit out of some little old grandma at a red light.... you can open it up a little or open it up alot.. open and close within 3 seconds... badass... 188 bucks too...shipped to the door with the switch....
Smitty
Re: why not
Dynoes dont lie. I actually dynoed the car to see the difference. After I installed the cat I noticed that the car felt weaker. I actually paid the money to find out. To my surprise the cat KILLED my torque. The same thing also happened to johntypes.
Originally posted by Smitty
First of all...
Secondly:
Smitty
First of all...
Secondly:
Smitty
Re: why not
First of all...
First of all...
no, all n/a engines need backpressure to perform properly.
most diesel engines are turbo, so the less backpressure the better.
same goes for turbo gas motors.
allmotor would see serious performance gains from running a free flowing (large diameter) exhaust on his car.
thats why he dyno'd so much higher w/ mufflers unbolted.
Re: Re: why not
(confused), here... Are you trying to say that with the CAT REMOVED you lost Torque. You stated in one post that you lost torque with it removed and now your saying with it installed it killed your torque....I think it would seriously be alot of fun and hell of alot easier than unbolting mufflers..
I got a long awaited appt. with my exhaust specialist that does all T304 mandrel bent stainless exhaust work... I want tru duals with the electric cut out... I think it would be awesome for when I get the S/C..
I was thinking 2.5 (eletric cut out 2.5), upgraded stainless Hipo stainless cat.. into 3 inch duals..
We will see what he says..
But the cut out is just an option for you guys when you run track or want to have some fun with the neighbors... you can flip the switch and close it and run back into you stock set up...
before changing cat hp was 224 torque was195.1 put random cat on hp want to 242 but torqe droped to 185 lost to much low end car felt terrible put stock cat back on felt good left it that way.
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
