Still getting Misfire code
Old Dec 3, 2007 | 08:00 PM
RKeatF1's Avatar
I have had this ongoing problem for a few weeks.
I got a check engine code for the #1 cylinder.
I changed the plug and put a new coil in.
The code is back again!
Anyone with ideas on what to do next?
Old Dec 3, 2007 | 08:28 PM
NEVERSUMMER's Avatar
EVERYTHING IS FOR SALE!
Well that sounds good compared to my (1,2,3,4,5,6 random misfire - random multi misfire - fuel train - codes that I got about a month ago)
Not sure what your problem could be. Mine was a poorly installed neo
Good Luck, Hope you figure it out
Old Dec 3, 2007 | 09:52 PM
mclarenf3387's Avatar
Maybe a bad injector.
Old Dec 3, 2007 | 10:04 PM
srehmat02's Avatar
You might have bent a valve.. go get a compression test done and report back.
Old Dec 3, 2007 | 10:20 PM
Where do you get a compression test? (Preferably beside acura... Do to the sheer fact I dont want to get robbed $$$)
Old Dec 3, 2007 | 10:21 PM
And if it could be a dirty injector.... Get some BGK44
Old Dec 4, 2007 | 04:17 PM
RKeatF1's Avatar
still getting misfire code
If I can find it somewhere I will try it.
I just dumped about 8-9 oz of Lucas in the tank.
That is what I use on a regular basis, when I change the oil.
Old Dec 4, 2007 | 04:19 PM
RKeatF1's Avatar
still getting misfire code.
I wil have try that over the weekend
Old Dec 4, 2007 | 06:45 PM
srehmat02's Avatar
A compression tester can be had for 20-30 bucks, all you need to do is take out all your plugs and screw in the tester to each cylinder. Very simple procedure.
Old Dec 7, 2007 | 11:12 AM
horsepowercrzy18's Avatar
well worth the compression test, haha
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
