Steering wheel vibrations only between 55-65 ...
Old Jul 13, 2001 | 01:30 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Otherwise, it seems fine. I speed to 80 and the steeringg is solid, below 45, same nice and soft no vibrations. Only when I am between 55 and 65 crusing speed i feel the steering wheels vibrations.
Is it a Charactertisc of the 235/40/18 tires?
...Wife said your car is not meant to be driven below 80
[ 07-13-2001: Message edited by: Nashua_Night_Hawk ]
Old Jul 13, 2001 | 01:45 PM
langjae's Avatar
do it yourself, !
I've got your same tires and supposedly the tires grip so much that you feel the grooves and tiny bumps on the road. But if you know you are on a ceompletely flat road with no bumps, then you may need an alignment. My wheel was literally shaking spastically at certain speeds and after the alignment it was all good.
-jeremy
Old Jul 13, 2001 | 02:00 PM
fender4's Avatar
Balance the tires, this is the number one failure mode for out of balance tire.
Old Jul 13, 2001 | 02:52 PM
M5 Lite's Avatar
I had the same thing on my M3. 50-60mph the steering wheel shook and below or above that it was solid. Take the car up to around 100 and see if you feel vibration in the wheel.
Either your wheels need balancing or they are bent. All my wheels turned out to be severely bent, just got new wheels.
Old Jul 13, 2001 | 02:56 PM
Happy CL-S Pilot
I called and the tire guys said get it in for a quick look, i.e. "rebalancing"?
What do you mean severely bent? My wheels are less than 2 months old with some 2000 miles only? I did hit nothing lately, So, what is severely bent mean?
Old Jul 13, 2001 | 03:49 PM
xenon7's Avatar
Xe- For Better Hwy Vision
It is a possible to have a "bum" tire that is mot perfectly round due to manuf. defects Been there and done that, esp. with low profiles 55 series and under.
You may want to check it out after a good
ass rebalancing
Old Jul 13, 2001 | 04:01 PM
Achance's Avatar
Coming to a city near you
mine vibrates too, I'm hoping that my tires are just out of balance. I did get a "new" refurbished rim, because the tire shop scratched my old one. So I'm just praying that they got the balancing wrong, because if they gave me a bent rim, I'm going to be pissed.
Old Jul 13, 2001 | 04:58 PM
Dacat's Avatar
Ace rider
Friend had the same problem, tire rack screwed up the balancing (took off all wheel weights), dealer fixed it back. Definitely get it balanced, should fix it right up.
Old Jul 13, 2001 | 05:21 PM
gobridge's Avatar
I got all four wheels on my A4 balanced for about $60. I probably could have had it done for cheaper, but I trust this shop. I had vibrations like you and it turned out that one rim was a little bent and another wheel that I had replaced (got severely bent and blew out a tire) wasn't balanced properly. Even still having the bent rim, the ride is much better after the balancing.
Old Jul 13, 2001 | 05:45 PM
M5 Lite's Avatar
Originally posted by Nashua_Night_Hawk:
<STRONG>I called and the tire guys said get it in for a quick look, i.e. "rebalancing"?
What do you mean severely bent? My wheels are less than 2 months old with some 2000 miles only? I did hit nothing lately, So, what is severely bent mean?</STRONG>
I don't mean to scare ya. I think mine was just a special case (maybe). You could see the bends in my wheels from the inner part of the wheel once it was taken off. Even if yours is a little bent, you can have the guys re-balance "as best they can", which helped me out alot once they did that.
Also, I was riding on a 35 profile in the front and 40 in the rear which contributes to my wheels being bent. Another thing as stated here might be a bad tire. If your steering wheel shakes, its something with your two front wheels/tires. I only had my wheels for about 3000 miles/3 months and messed them up, didn't even ride em hard.
Old Jul 13, 2001 | 05:54 PM
Happy CL-S Pilot
I had 4-Wheel balancing ar Town Fair Tire at NO COST, no question asked!
No more vibrations
Old Jul 13, 2001 | 05:57 PM
M5 Lite's Avatar
congratulations! Welcome to the 'No bad Vibes' club
<STRONG>I had 4-Wheel balancing ar Town Fair Tire at NO COST, no question asked!
No more vibrations </STRONG>
Old Jul 13, 2001 | 07:56 PM
Type S's Avatar
Powered By HONDA
either your rim or tyre is out of shape ..or u need to rebalance the rim..
Old Jul 13, 2001 | 09:21 PM
acura_service's Avatar
www.drippinwet.com
alignment won't make a car shimmy (unless its toe'd in or out like crazy then it plows and chugs, find a dealer that does force balance - it loads the rim and tire and measures radial runout simulates road driving while checking the balance
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
