Starting Your Cl Or Any Car Question?
Chapter Leader (NY/NJ)
Have A Question, I Already Got My Tune Up About 1k Miles Ago, Changed The Plugs, Oil, Transmission. But How Come When I Start My Car Sometimes It Seems To Hesitate Especially When Its Cold, I Have 01 Cl-s W/ 85k. Its Not As Smooth To Start It. Could It B The Starter Or Alternator? Thanks
666 Speed
1 Post
Damn dude you capitalized every beggining letter in that post...
It hesitates because it needs more gas to start is considering its getting cold now. Every car that i have ever had has done it.
it's getting colder here but I have not noticed any major changes in how long it takes the car to start. it has been down in the 20's when I have started my car
In the Mid-South meow
Originally Posted by GreenMachine
turn your key over for a few seconds to let your fuel injection charge...then start...should start in one crank
Moderator Alumnus
Originally Posted by CLariSe-169
Probably the best advice on starting a car . My father taught me this a long time ago and I swear by doing it everytime I start my car. Not only for the fuel injection to get primed but also for the oil pump to pump an inital amount of oil for start-up. It erks me when people just put the key in and turn to start without pausing for two seconds.
This is the best method for starting EFI cars.
MP90 uninstalled
Agreed. Wait a second or two then hit the starter. Should work fine. As injectors age they can lose pressurization when not run for a few hours. Give the fuel system time to pressurize and you should be fine. All of the cars I have owned have done this with age.
Mmmmmm, Beer.....
Originally Posted by PacoCLType-S
Why would the oil pump be pumping if the motor isn't running? What, is Acura using an electric oil pump or something? Every car I've ever worked on has had a mechanical oil pump that only pumps when the motor is turning.
Mmmmmm, Beer.....
I thought for some reason there was an electric primer that brought an inital amount of oil from the pan to the top of the motor.
That would be a good idea though - I don't know why car companies haven't come-up with anything like this. Then again, they really don't want our cars running for 300K miles because we might buy less new cars!
tman570
06-11-2019 07:56 AM
