Stalling problem
Old Sep 27, 2008 | 02:23 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
Stalling problem
Now the new problem... SRS light lit up on the dash. Called Acura, they wanted $99 for a "diagnosis" ... read up on Azine, it was due to a weak battery (battery was bad). Replaced the battery this morning, reset the SRS light. Now anytime I come to a complete stop, the car shudders and nearly dies if I don't give it some gas. Pretty sure it'll die completely if I have the AC running (taking more power) Any ideas? All advice would be greatly appreciated.
Old Sep 27, 2008 | 02:27 PM
poisx7's Avatar
FPR
bad gas (run injector cleaner) seafoam
how bad are ur wires, plugs etc
or just give in and do a diagnostic check
Old Sep 27, 2008 | 03:24 PM
FPR? Always kept 93 octane in it, but I'll run a bottle of injector cleaner in it when the tank gets closer to empty sometime this week. Plugs... I believe they were changed about 2 years ago, but I haven't gotten 'em out to check. How hard is it to get the back 3 plugs out? space is pretty cramped...
Old Sep 27, 2008 | 03:55 PM
fuzzy02CLS's Avatar
IAC valve or vacuum leak.
fuzzy02CLS's Avatar
poisx7
No wires on the CLS, Coil on plug design.
Old Sep 27, 2008 | 04:18 PM
idle air controller & vacuum leak... how can I check these? Never even heard of an IAC valve :-\
Old Sep 27, 2008 | 07:09 PM
poisx7's Avatar
Originally Posted by fuzzy02CLS
poisx7
thanks i know but I stand corrected.
Old Sep 28, 2008 | 03:44 AM
m733l's Avatar
i would clean out the iac valve first. mine did that and i clean the valve out . now she running just fine. search iac valve. it will show up. pretty straight forward. remove it spray some carb cleaner and wipe it clean.
Old Sep 28, 2008 | 06:18 PM
quicksilver10101's Avatar
my car acts like that when one of the 02 sensors is on its way out...usually a even a few weeks before i get a cel
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
