SRS Turned ON
SRS Turned ON
For some odd reason this morning when I woke up and got into my car, the SRS light is on. It's lite red and red usually is bad
The light is on the top right hand corner above the fuel meter.
I did a search and couldn't find anything. Does anyone know what it means?
I own a 2001 CL (non type S) with 98,XXX miles. It's on it's 2nd transmission.
It means that there's an issue with your SRS (safety restraint system), so the airbags may not function properly...
Some SRS issues may also be covered under an extended warranty:
https://acurazine.com/forums/showthread.php?t=179416
If its the red SRS light it has nothing to do with the side air bag light or something being in the seat wrong. I would bring it in to the dealer to have diagnosed. It may be one of the issues covered. When that light is on none of the airbags work
w202 on carlssons
Originally Posted by aznboi2424
but for me the "side airbag" light flashes every 2 sec or so when i put something in the passenger seat.
Originally Posted by o1s
disconnect your battery to reset the ecu. if it comes back on, take it somwhere and get a code scanner thrown on it.
Moderator Alumnus
With the higher mileage CLs I wouldn't be surprised if the SRS light had anything to do with the Seatbelt Restraint System (those are covered under warranty).
Which reminds me I still need to get mine fixed.
Some links on resetting the SRS light via the little connector under Drv. dash
Yep, mine just came on today and the following turned it off.
No pending error codes were captured on my scan tool, but the following worked for now:
http://www.geocities.com/myintegra96/srs.html?20078
http://www.geocities.com/myintegra96/SRSResetPics.pdf
http://www.geocities.com/myintegra96/SRSResetTXT.pdf
Humble suggestion:
Try using a couple of small paper clips to stick into the connector. If you use a couple that are slightly bent, you can "make" and "break" a connection with one hand (the other hand can operated the ignition switch). The timing is a bit tricky and if the clips are bent "just so", the connection to SRS connection (2 pins) "made" and "broken" with one hand.
The above presumes that you have the right size paper clip (about 1" long).
The dealer wanted $100 to do the diagnostic.
It had been off (working correctly) for 7 years -- until today
Humble suggestion:
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Uses turn signals in my
Mine went on, the dealership took care of it under the lifetime seat belt warranty, replaced the seat belt its self and where it clicks in (can't think of the name right now) and I believe a sensor as well.
Bringing this thread back....
My SRS light just came on yesterday, it stays on after car is started and I'm trying to find out whats wrong with it. The previous post gave me hope that the dealer might take care of it. This what happened before that light came on. I move the passenger seat back a little bit, then pressed the lever where it automatically comes forward, clicked it back into position and thats it, I did also go over a very hard bump. Any suggestions I can do, I checked the connectors under the passenger seat..and everything seemed to be connected...I'm going to have somebody sit in the passenger seat and see what happens. Any insight would help, thanks.
BTW I own a 2003 clp
My SRS light came on last year and didn't turn off. Dealer replaced one of those seat bult latching thingamajgs (don't know the correct term) free of charge and it fixed the problem. Basically the car didn't know that I had buckled my seatbelt.
Originally Posted by sayfulhaqq
See its kinda odd, my seatbelt light will go away if I buckle my seatbelt, however the SRS light still stays lit
The SRS system has a way of knowing if the buckle is informing the system of latching or not. This is why when the car beeps when you first turn it on without buckling your belt and stops beeping when you do; however, the light still blinks for a little bit and goes away after a few seconds.
So, if the buckle malfunctions the SRS light is triggered.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Well I have an appointment with the dealer tomorrow. They said that if the SRS light is triggered by the warranty issue its free of charge, if not they want like 110 dollars for a diagnostic fee....crazy....any input?
BTW, I was right, it was the passenger side seatbelt buckle. When i reset it, i can get it to turn back on again by simply buckling in the passenger seatbelt. took care of it last year, replaced for free by a local acura dealer because acura has a lifetime seatbelt warranty.
Originally Posted by dondos2
im having the same damn issue.....this will be the 5th time i take it to the dumbasses at esserman acura. its upsetting i dont know why it keeps lighting up
friend of fast
ive had mine on for a 100k miles. i use it as a good luck charm since i haven't had a wreck in my car yet. knock on wood. haha. the dealer told me 400 bucks for a new sensor since they said it was "maybe" the passanger seat sensor. i said...bs. and they wouldnt fix it under warranty cuz i was t 56k miles. what bastards. oh well, at least i know my car ignition is on. haha.
Had to reschedule my dealer with the appointment. I had a friend sit in the car and had him buckle the seatbelt and I buckled mine. The light for the seat belt went away but the SRS still remained on. The side airbag light stayed off, so I'm hoping its warranty related, so I have to pay,haha. Any suggestions before I reschedule the appointment with the dealer?
SidhuSaaB
05-30-2020 12:40 AM
