SRS light came on. HELP
Old Aug 1, 2004 | 03:55 PM
Akim711's Avatar
dynamic Duo!
I knew the battery died, because I also had to enter the radio Code. Anyone know why this light might have come on? The dealer says they have to charge just to see whats causing the problem....
Old Aug 2, 2004 | 10:20 PM
SFLA_Type-S's Avatar
Sold 12/29/04 :-(
The same thing happened to me. Any ideas on how to reset this guys?
Old Aug 2, 2004 | 10:24 PM
oonowindoo's Avatar
_____________________
when the SRS light on , basically all of ur airbags are sleeping. there could be a lot of reasons to cause this. the most frequent ones are : If you have aftermarket sound system. the wires might be close to the sensors or might be interupt with some of them sensors. OR if u put a cellphone or digital camara or other electirc devices on your passenger seat or near your center console that might cause it to come on too.
There is really not a final solution to it as far as i know. Dealer might replace the sensor and reset the SRS light. But sooner or later it is gonna be on again.
Old Aug 2, 2004 | 10:26 PM
Sold 12/29/04 :-(
I did have a problem with the instrument panel fuse. When I replaced it, the SRS light came on. I will just have to bring it to the dealer to have it reset.
Old Aug 2, 2004 | 11:19 PM
Dan's Avatar
Dan
Confused
You can find the answer here; http://www.google.com/search?q=srs+l...utf-8&oe=utf-8
My battery got weak with VERY slow/no cranking, and when it was replaced the SRS light was on. Followthe directions on how to reset it and if there is some other problem in the SRS system, it will come back on. 99% chance it was caused by the voltage drop from the bad battery.
Dan
Old Aug 3, 2004 | 12:50 AM
Akim711's Avatar
dynamic Duo!
shoot, thanks for all your help guys.... my thread was dying, so i was worried that no one knew.
Old Aug 3, 2004 | 11:36 AM
Linner's Avatar
Dan
I went to PAA less then 2 weeks ago to get my srs sensor reset, they said it was bc my battery had a weak voltage count. I replaced the battery and 2 days later my srs light came on again. Ill be giving them a call this week for another rescedule. Thanks for that site
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
