speed calibration!!!!
i got a new wheels (moda r6 17' w/ 225/45/17) put on yesterday. i know that the speed will be 1.9% too fast. is there any way i could correct this?? can u adjusted the speedometer?? i call the place that could do calibrate the car but they say they only issue written paper saying that the speed is off. should i even worry about it or just leave it alone??? any inputs, would be greatly appreciated....
01 Silver S-type with navigation and spoiler..comtech springs/clear bra (3M)/viper 550 hf with remote start/35%tint/more to come..
I don't know, so give this due weight.
1. Do you have NAVI?
2. Have you tried out the VSA?
I was orignally told by Acura that the 225s would mess things up, but I've seen a lot of people running 225s without trouble.
Are you concerned about the Navi, VSA, or the speedo error. The speedo is off with the stock tires, so as long as you know it is off, do you care about the speedo issue?
There may be a way to see if the Navi is off by "blocking" the Navi antenna, then driving the car for a while with the satelites "blocked".
I haven't tried this, so take this with a grain of salt...
BTW -- what pressure are you running in your tires *and* what is the max pressure that they will take?
2001 Satin Silver Cl-S w/ NAVI
- Mud Guards
- Wheel locks
- Toyo 235/45ZR17-97W* T1S Proxies on Stock 17" CLS wheels
- Gtech 1/8th tank 40F ~=6.1
- Zaino magic
GSXRACER: it may be possible to adjust your speedo but it may take some time for me to find out.On our RL's there was a small trimpot on the instrument panel printed circuit board,turning it slightly corrected the speedometers on those cars that needed it.I will check this out next time i have to get into the instrument panel of a CL.Give me some time to check it out.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
In any case you don't want any written document that says your speedo is incorrect (ie tampered). That will significantly decrease the value of your [purchased] vehicle and there are laws about disclosure.
* 2001 Acura CL Type S * Blk/Blk * Navigator * Spoiler * Moonroof Visor * V1 *
* Since 3/31/2000 *
* Road Warrior *
* 500 posts on h/a.net *** 400 posts "insane poster" on the "old" acura-cl.com *
* Since 3/31/2000 *
* Road Warrior *
Eric-L,
So you're saying that Acura told you not to put any rubber larger than 215's on the CLS, otherwise the VSA will not work properly?
I can understand the speedo being outta wack a little, but why would it affect the VSA?
I'm sure physics is involved somehow (torque, tire weight, revolutions), but the designers should have considered such changes to the tire size evetually over the life of the car.
Any further details you can provide?
Bullet-TypeS
Bullet-TypeS
Probably because the 225/45's are smaller in diamter than the 215/50's. that's why i wanted to go w/ 235/45/17's since they are a closer match to the stock diameters. But now im not certain if it will rub or not since I have springs.
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs. Polarg m-6.
Comptech Headers, Comptech Sways, Eurolite Xenon Crystal high beams.
AEM CAI once they decide to make the dame thing.
235/40/17's or 225/45/17's once I found out which one works for me.
gtech 0-60 6.03 w/ 438 pound load. preheader.
CL-S
09-25-2015 06:14 PM
