Spark Plugs... Different between Type S and Premium?
Old Nov 18, 2005 | 05:03 PM
CleanCL's Avatar
OK, i searched and now am more confused than I started.
Pepboys sold me NGK Iridiums IX, part #: ZFR5FIX-11.
I have a type S.
Enter confusion: Helms manual states for Type S: NGK - PZFR6E.
So wouldn't I need: ZFR6FIX-11?
Every site I go to, sparkplugs.com and rockauto.com list the plug with the 5 rather than the 6. Is this an error?
Here is what I'm thinking:
NGK Stock Plugs
Type S: PZFR6E
Premium: PZF5F
NGK Iridium IX
Type S: ZFR6FIX
Premium: ZFR5FIX
Can anyone confirm?
Old Nov 18, 2005 | 05:33 PM
Lord Helmet's Avatar
I'm here in spirit...
Ok, when I changed mine, I had the same issue. I ended up putting the "5F" in it and mine's a Type-S too. I was told here that it's no big deal but I am going to change them when I get the chance. BTW, I have not had ANY problems with it since it's had the 5F's in it.
Old Nov 18, 2005 | 06:07 PM
spdy0001's Avatar
I now drive an accord....
Im pretty sure one just burns alittle hotter, but as he said it should be no big deal. Sorry I can't help with which one is correct for the car
Old Nov 18, 2005 | 06:14 PM
RooEng's Avatar
I have a type S.
NGK Stock Plugs
Type S: PZFR6E
Premium: PZF5F
NGK Iridium IX
Type S: ZFR6FIX
Premium: ZFR5FIX
Can anyone confirm?
I looked at the Pep Boys computer and some years show the same plug in both p and s. They didn't carry the 6's when I bought mine so when you ask for a Type S plug they'll just give you a P plug, they don't know the difference.
The higher the number the colder the plug. The S needs a colder plug because of the higher heat it makes from the higher compression than the P. If you use a plug that's too hot it could pre-ignition and loss of power. You'll probably never notice it because the computer pulls timing out until it stops. Same thing happens when you use a lower octane gas.
If you have a Type S get the 6's, unless you don't care about the slight loss of HP.
Old Nov 18, 2005 | 09:47 PM
CleanCL's Avatar
that's what i figured.
i just did a double take, because not only pepboys, but every single website online lists the same plugs for P and S.
i plan on going with the colder plugs.
thanks guys.
Old Nov 18, 2005 | 09:53 PM
When I was searching for them at my local parts stores, every place had to special order the 6's. WTF! That's why I ended up going with the 5's not too mention because I couldn't find a straight answer on the forum.
Old Nov 18, 2005 | 11:10 PM
CleanCL's Avatar
Exactly. The above is confirmed. Along with these:
DENSO (according to helms)
Type S: PKJ20CR-M11) (IK20)
Premium: PKH16CR-L11 (IK16)
BOSCH Platinum +4 (according to bosch website)
Type S: 4417
Premium: 4418
I understand why some would say it does not matter, but there is a reason why there is a difference between models.
Zonian22
Nov 14, 2015 01:20 PM
Sixers12
ILX
15
Oct 30, 2015 05:30 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
