Spark Plug DIY
Old Feb 5, 2008 | 10:31 PM
sundevil_CL's Avatar
Spark Plug DIY
I searched but couldn't find a write-up on changing plugs. Does anyone know if there is one around here somewhere?
Old Feb 5, 2008 | 10:39 PM
typeS6S's Avatar
3.2L Vtec
not a diy but something if found that can help you with this
https://acurazine.com/forums/ramblings-12/anyone-ri-nearby-ma-area-144769/
Old Feb 6, 2008 | 09:05 AM
fuzzy02CLS's Avatar
They are spark plugs. Not too hard. Pretty much the same as all spark plug replacements. The front 3 are very easy. The rear are not that hard. Just get some 6 & 10 inch extensions & you should be ok.
The stock strut bar can be remover for more clearance if needed.
Old Feb 6, 2008 | 01:20 PM
Nutshell's Avatar
haha on sparks..come on. here ill help.
1. unplug wires
2. unscrew old ones
3. screw in new ones
4. plug in wires..
snap crackle pop houston we have ignition
Old Feb 6, 2008 | 02:03 PM
LIPPSTUH's Avatar
Unregistered user
use antiseize and boot lub or w/e go toautozone they have it.. small packet
Old Feb 6, 2008 | 02:42 PM
fuzzy02CLS's Avatar
1. unplug wires
2. unscrew old ones
4. plug in wires..
The CL doesn't use wires. It's coil on plug. So it's unbolt coil, then re-bolt coil.
Old Feb 6, 2008 | 11:43 PM
TOPHER33884's Avatar
LMAO......that was great!
Old Feb 7, 2008 | 03:14 AM
Nutshell's Avatar
haha ooo burn. haha sorry ive got a first gen. but good burn
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
