Sluggish Acceleration on CL-P
I spent the past month trying to figure out what exactly is wrong with the engine and I am officially stumped. There are no codes and all the data looks ok based on the service manual and some additional online reading. The main issues are the sluggish acceleration and a rumbling in the cabin when the engine is under load.
At cold start there is also a puffing sound coming from the bottom of the engine - sounds like it's purging some air every 15 seconds or so.
Here's what I've done/checked so far:
So any thoughts or suggestions on what to do next?
- replaced valve cover gasket (done by a shop)
- Checked cylinders
- compression is around 250psi. much higher than what it should be according to manual
- some oil on the spark plug tips, replaced them
- scraped the bottom with a small screwdriver and got some black stuff (carbon?). Need a borescope to inspect
- Replaced PS pump due to wobbly pulley
- fixed intake hose leak
- replaced purge solenoid and PCV
- Replaced all mounts except the rear
- Ran a bottle of seafoam through the gas tank
- Vacuum test passed
A few notes on the video: you can hear the puffing early on when camera is on the driver side. it's like a pff-pff sound. Also can hear the air being sucked into the engine, it seemed unusually high to me but it does die down once it's up to temperature.
whitetiger5 (10-12-2022)
Maybe check the cat. converter next?
Hmm...I expected a CEL if the cat was bad.
according to this article though it's worth looking into. I do get a blast of unusually hot air from under the passenger door when I'm down there - not sure about the smoke or smell but I'll check again when I get home.
thanks!
thanks!
I am dumb
thanks!
thanks!
I didn't have the same symptoms as you though. The honey comb had completely crumbled, but I could still hit VTEC perfectly fine.
Test pipe's are relavtively cheap. Although wouldn't recommend it, the raw exhaust smell can be pretty bad.
In fact that's why the one on the cls was quickly removed. Like to be able to pull up to a drive thru without gassing people out. lol
619rcr (10-11-2022)
mikulskn
12-15-2022 08:08 AM
lemmy28
01-06-2020 12:42 PM
K927
06-12-2014 04:15 PM
