slight sputtering on acceleration?
Old May 28, 2008 | 07:16 AM
  #81
fliplyricist1's Avatar
Staggered 1st Gen
wow super weird
I have had the exact same problem in my 97 3.0 for the past 4 months or so. However, I am an auto tranny, so most likely my tranny is on it's way out (though I hope it isn't). Basically it's exactly as described, happens at low rpms when I'm just 'slowly accellerating'...the car appears to 'hesitate' in transition to 2nd gear to 3rd...almost like it's stuck in neutral? This occurs typically at ~2500 rpms. If I let off the accelleration during this time the rpm's seem to momentarily jump and it appears as though it shifted into 3rd gear, though I'm not sure. It's like the car all the sudden has lost it's power and appears confused. Interestingly enough, back when my second alternator was on its way out, the 'battery' light on the dash would flash during this moment of hesitation...and turn off once the car shifted or was given more gas. Odddddd.
However, if I gun it or give it more gas during this time, it revs all the way up to 3k and shifts as normal. I have a tranny cooler installed and all that jazz. I'm really hoping it's not the tranny and just something else, but I'm going to have it inspected by the dealer during my next oil change. I suppose I should seafoam it just for shits and giggles since the car is approaching 105k miles now, but pretty much everything was replaced/tuned during the 100k tuneup so I dunno whatsup.
Old May 28, 2008 | 12:05 PM
  #82
Harrisonk531616's Avatar
CL-SEXY SIX (=
i wish the answer to all our problems is seafoam lol!
Old Jul 9, 2008 | 07:44 AM
  #83
cb717cls's Avatar
03 Boosted CLS
well i hope that will be the answer to my problem im gonna try that this weekend. along with cleanin the throttle body. also seafoam in the oil we will see. ill post if any changes occur.
Old Jul 9, 2008 | 10:20 AM
  #84
dasuddith33's Avatar
Airborne MP 16th Unit
hmmmmmm well i had the same problem and just got a new tps sensor try that and my prblem went away ....
Old Jul 10, 2008 | 05:04 PM
  #85
cb717cls's Avatar
03 Boosted CLS
is there any way to clean it because acura doesnt sell the tps alone and they said i have to get the whole throttle body for like $400
Old Jul 10, 2008 | 05:07 PM
  #86
Sly Raskal's Avatar
some companies sell the TPS alone, but you have to drill out the old one since it's riveted on the TB as far as I know and attach the new one. I don't know anyone that has done that.
or you can buy one online for cheaper at:
http://www.acuraoemparts.com/
Old Jul 10, 2008 | 06:19 PM
  #87
cb717cls's Avatar
03 Boosted CLS
hey just went on the site and the portion where the tps is on is not listed for sale alone am i right its where the number 9 is pointing?
Old Jul 10, 2008 | 08:30 PM
  #88
Sly Raskal's Avatar
Acura does not sell the TPS sensor separately, it is riveted on the TB.
There are aftermarket companies that sell TPS sensors that you can custom fit on your throttle body, just requires extra work.
Or you can buy a whole new throttle body from the site I linked to above as their prices are typically 20-25% lower than most dealers.
Old Jul 10, 2008 | 10:56 PM
  #89
cb717cls's Avatar
03 Boosted CLS
oh i c what ur gettin at ok well im gonna try to clean it and if not im gonna try to find a friends throttle body to test to c if it fix;s it.
Old Jan 12, 2019 | 09:00 AM
  #90
matt palumbo's Avatar
I'm having the same problem with my 2002 rsx I replaced my o2 sensors just the other day and my rpms started sputtering around 2500-3000 and I scanned the car it popped up as a engine coolant sensor and the knock sensor nothing about a misfire or bad injectors so now I'm thinking could it be the knock sensor that's causing this problem with the rpm sputtering new to this rsx stuff could use some help thank you
Old Dec 14, 2023 | 03:54 AM
  #91
Ryansullivan5's Avatar
Originally Posted by fliplyricist1
wow super weird
i have the same problem with my 2001 tl its like ill be driving and all of a sudden my rpm will drop down to like 1000 and it will feel as though im in neutral for a second or two then its fine
Old Dec 15, 2023 | 12:08 AM
  #92
whitetiger5's Avatar
No check engine light? how old is the fuel pump?
Old Dec 15, 2023 | 12:33 AM
  #93
no the check engine light was on but that was only for an evap leak that i fixed and id assume the fuel pump is original
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
