SImple question
Old Aug 4, 2003 | 08:35 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
SImple question
I was just wondering if the H & R OE sport springs are just as good in ride quality as the comptechs. I also want to know if the H & R's are just a bit lower then the comptechs.
Thanks a lot------ guys :P
Old Aug 4, 2003 | 08:40 PM
Hobes's Avatar
Comptech drops your car 1.5" in the front and 1" in the back
H&R don't make springs specifically for 2003 CLs but they drop 1.75 in the front and 1.5 in the back (i think)...
Apparently, the Comptech and the Eibachs are pretty close to stock ride
Old Aug 5, 2003 | 12:22 PM
italiaCLs's Avatar
the Eibach pro kit?
Old Aug 5, 2003 | 12:33 PM
juniorbean's Avatar
Originally posted by italiaCLs
the Eibach pro kit?
I think he meant H&R
Just to clear up his reply... the H&R OE springs only drop your car .75" front and rear. The drop specs he's talking about is for the H&R Sport kit. I have the H&R Sports and the drop is more like 1.75" front and rear as it's a pretty even drop.
The Comptech kit gets you the best drop and the best ride. If you go with the H&R OE, the ride will be close to stock.. but the drop is minimal. The H&R Sport is more of a drop then Comptech, thus the ride is a tad stiffer. Comptech is right in the middle
Hope that helps
Old Aug 5, 2003 | 12:38 PM
Hobes's Avatar
thanks juniorbean
to add to that, if you are thinking about the Eibach pro kit as well, it drops 2 in the front and 1.6 in the rear.
For both the Eibach and the H&R Sport, you will probably need a camber kit in the rear for sure, a maybe one in the front...whether you need them in the front will ultimately depend on your alignment afterwards...it varies with every car.
Long story short, your best bet is with the Comptechs
Sound right juniorbean?
Old Aug 5, 2003 | 12:46 PM
italiaCLs's Avatar
wow a camber kit in the front and back... I better just stick with the comtechs o well. Ill have to find used ones.
Old Aug 5, 2003 | 12:49 PM
CrockPot's Avatar
i just got my h&r sports installed over the weekend. the ride quality is very soft, i actually wish it was a little more stiffer. here's how it looks:
http://acura-cl.com/forums/showthrea...hreadid=110182
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
