SilverKnight or other Sound Install Guru's
Old Jul 23, 2001 | 02:25 PM
fbazakos's Avatar
on bin laden
I checked the archives ... looks like SilverKnight has a good install template.
http://www.acura-cl.com/cgi-bin/ulti...&f=16&t=000039
but the pics are down.
I'm just trying to add BASS to the stock BOSE system. I have the components listed in my sig. I bought a MA amp kit, and a Monster Cable Factory Linx FXSB 100 in-line converter. I got them both for $90, been waiting for a good deal.
Any install tips? SilverKnights aren't quite what I'm looking for I dont think.
Old Jul 23, 2001 | 03:17 PM
spiroh's Avatar
Foti,
Does your Amp have speaker level inputs? You shoudl run the wire from the drivers side. The panels by the door are easy to remove. Use a coat hanger to get to the back of the car.
Spiro
Old Jul 23, 2001 | 05:37 PM
fbazakos's Avatar
on bin laden
Spiro,
I'm doing the install right now. I just have to run the power to the amp from the battery (haven't been able to get thru the firewall yet), and i need to tap the speaker lines to get the sound. everything else is ready.
Originally posted by spiroh:
<STRONG>Foti,
Spiro</STRONG>
Old Jul 23, 2001 | 05:48 PM
SilverKnight's Avatar
Retired. Not available.
Originally posted by fbazakos:
<STRONG>I checked the archives ... looks like SilverKnight has a good install template.
Any install tips? SilverKnights aren't quite what I'm looking for I dont think.</STRONG>
check the link in my sig.
Old Jul 23, 2001 | 08:16 PM
fbazakos's Avatar
on bin laden
ok here is where i'm at.
i got everything hooked up.
i'm trying to figure out two things. which wires to tap for the sound, and which wire to tap for the amp turn-on.
i found an old post from AthenaCLTypeS. are these the correct wires to tap?
So:
1) yellow/white (5) is the radio switch that you used for the sony amp power on switch.
2) then you tapped the rear right speaker:
black (7)(-) & blue (20) (+)
3) and the rear left speaker:
green (9)(-) & red (22) (+)
Look at the Shawn S schematic to see the wires numbers. Let me know if they are correct.
Old Jul 23, 2001 | 09:14 PM
fbazakos's Avatar
on bin laden
well i hooked everything up as listed above. the stock system works fine, but i cannot get the amp to turn on. what is the best way to "debug" this problem. i hope to GOD there is nothing wrong with my amp.
Old Jul 23, 2001 | 09:18 PM
SidVicious's Avatar
Ambidextrous Masturbator
<STRONG>well i hooked everything up as listed above. the stock system works fine, but i cannot get the amp to turn on. what is the best way to "debug" this problem. i hope to GOD there is nothing wrong with my amp.</STRONG>
I'd check the fuse in the amp as well as the in-line fuse from the battery.
Old Jul 23, 2001 | 09:57 PM
spiroh's Avatar
Check your ground.
Old Jul 23, 2001 | 10:10 PM
fbazakos's Avatar
on bin laden
Originally posted by SidVicious:
<STRONG>
I'd check the fuse in the amp as well as the in-line fuse from the battery.</STRONG>
WOHOOO. I finally FUCKING got it. I just double checked all the connections, re-did the ground, and BAM it works. sorry, i'm just excited. Didn't quite take me 11 hours right amir????
now i just gotta put my damn car back together.
Old Jul 24, 2001 | 12:06 AM
is it ready yet? is it? is it
Old Jul 24, 2001 | 12:43 AM
fbazakos's Avatar
on bin laden
Originally posted by SilverKnight:
<STRONG>is it ready yet? is it? is it </STRONG>
yeah it is as a matter of fact.
now if i only had enough spare time on my hands to create a website about it and help others
thanks for all your help my man. car audio just isn't my thing, so the fact that it actually works is exciting to me.
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
james357
Feb 13, 2016 02:37 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Skirmich
Sep 15, 2015 06:41 PM
