shredded S/C belt
Old 05-12-2009 | 04:15 PM
cls6's Avatar
shredded S/C belt
I'm not that mechanically inclined but how hard should this be to replace? It seems like it should be pretty simple but I cant seem to get it. The tensioner pully was put on really tight and I can get those two little bolts loose. Does the pulley come off the shaft?
Old 05-12-2009 | 07:10 PM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
loosen the two tensioner plate bolts and the tensioner pulley slides right up. then just slide the new belt in and hold the tensioner as hard as you can while you tighten the tensioner plate bolts back up. and to answer your question, yes the pulley comes off the shaft with a size 19 wrench and a 1 1/2 wrench.
Old 05-12-2009 | 08:32 PM
cls6's Avatar
Thanks for the reply. I think those two plate bolts were torqued way too much. How exactly does the pulley come off? I used a socket and wrench to get the nut off the end but then what?
Old 05-12-2009 | 10:56 PM
Allout's Avatar
Blown is Best
You shouldn't need to take off the pulley to change the belt. If you do, you're doing something wrong. Just because you can take the pulley off doesn't mean you should. In the case you do pull off the pulley, don't loose the key.
Old 05-13-2009 | 12:40 AM
Allout's Avatar
Blown is Best
Here are the instructions to the SC. Page 9 has the instructions for installing the belt. Hope this helps.
http://photos.imageevent.com/allout/...stallation.pdf
Right Click the link above and "Save As"
Old 05-13-2009 | 03:18 PM
cls6's Avatar
ok thanks. I didn't think I should need to take the pulley off. I wasn't aware I needed a key either so I guess it's a good thing I didn't try to force it off. Problem is that I rounded off one of the bolts and not sure how to get it loose now.
Old 05-13-2009 | 05:38 PM
cls6's Avatar
nevermind. I found my vise grips, messed the bolt up some more but it eventually came loose.
08KBP_VA
10-22-2019 01:55 PM
brboy
10-05-2015 11:34 AM
Jboat
09-30-2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: shredded S/C belt
