short ram vs. CAI
Old Jan 18, 2001 | 03:36 PM
CLpower's Avatar
teh Senior Instigator
short ram vs. CAI
the short ram is ALOT louder...but you can feel a difference esp. late night early morning...the CAI has a lil more pull
pays to be young and crazy
-99 acura 3.0 CL
-58 Caddy Eldorado Biarritz
-55 chevy suburban (chopped dropped tubbed)
Old Jan 18, 2001 | 06:59 PM
tw1112's Avatar
I will take my CAI apart tonight and make it a short ram. So you're saying that I will hear more but feel less right??
Tw1112
CL 3.0 '98 - Cleared bumper, hiper/piaa bulbs all around, PIAA 1700x fogs, and AEM CAI.
Old Jan 18, 2001 | 08:07 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by tw1112:
</font>
thats what i'm sayin
-99 acura 3.0 CL
Old Jan 18, 2001 | 11:49 PM
scalbert's Avatar
It'll have to do with temp and conditions. The CAI will be less prone to heat soak. When in traffic the Short will start ingesting warm air sooner and will take longer to cool.
But on a cold start or having been on the highway for a few minutes, there will be little to no difference.
Old Jan 19, 2001 | 03:51 AM
tw1112's Avatar
Made the switch tonight to make my CAI into a short ram. Haven't had a chance to drive on it, but it sounds very mean!!
Tw1112
Old Jan 19, 2001 | 05:24 AM
[VTEC]TL's Avatar
RWD convert
Made a CAI out of my Short ram yesterday with some 2.5" piping, a couple of clamps and an intake coupler. Sounds sweet and I noticed a pretty nice differnce in power over the original short ram setup. Why r u guys all converting to short ram???
Y2K Satin Silver/Ebony 3.2TL
Performance:
AEM Short Ram induction | Magnaflow axle-back quad exhaust | Modified Downpipe | Neuspeed sport springs(2" drop)
Exterior Styling:
Acura Wing | Acura Moonroof visor(coming) | Mesh grill | "Euro" Headlight finishers | Acura Indiglo Emblem | Type S badge | 20%/35% Llumar Platinum tint
Interior:
Ractive CF Shift knob | Carbon/alloy pedals | Escort Passport 7500
Up next: WW or Acura OE body kit, 18" or 19"rims/tires
Old Jan 19, 2001 | 05:37 AM
MikeS's Avatar
My understanding is the CAI gives you more power in the upper end range of RPM & a shortram gives you more power in the lower range of RPM's. Is this correct and if so, would you prefer to have more power in the low range or high range. My instinct says low end, more power off the line. What do you think?
00' Laguna Green TL w/ Navi, Rear Spoiler & Tint. Soon to have Comptech Suspension, Sways, Exhaust and 17" or 18" Wheels & Tires.
Old Jan 19, 2001 | 06:39 PM
[DWI]'s Avatar
If what you say is right that a ram is low end and a CAI is high range I'll take the low range. After all that is what gears are for (to drop the RPM back down into the lower range) and I doubt that you'll get to speeds that would get you into the high RPM range w/o the ability to upshift. However What was said before that a CAI is better because it cools faster and so on makes sense.
Old Jan 20, 2001 | 12:25 AM
tw1112's Avatar
Do your intakes whistle and stuff while driving slowly? I mean as I accelerate the noise is gone, but when I am just cruising, my intake makes a whistling sound? I just wasn't sure if this was normal. It is really loud and annoying if my windows are down, and it makes me feel like I am making my car sound cheaper to other people...am I doing something wrong? I have no problems with it myself, but I don't want other people to not buy a CL just because they hear my car
Tw1112
Old Jan 20, 2001 | 04:34 AM
Xephyr2K's Avatar
TW1112,
The "Whistleing.." may be easily fixed by checking the couplers and verifying that they are sealed air tight... A whistle is usually the vacuum sucking air through a crack or gap in the induction tubing. The only other real possibility is the filter that you are using... I use the K&N RF-1007 its a 7" cone with chrome cap... My CAI is virtually indetectable at idle or cruising ranges aside from and ever so slight "sucking" .."Whooosh" sound.. It Screams at VTECH RPM's ... as I think you heard on my website... But for now check all your induction seals amd possibly switch the filter....
2001 Nighthawk Black CLS Type S - Custom Chromed Aluminum Cold Air Intake, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, Custom Aftermarket Paint Etching On Driver Door &lt;a href="http://types.50megs.com/index.html"&gt;My Nighthawk&lt;/a&gt;
Old Jan 20, 2001 | 04:39 AM
Xephyr2K's Avatar
LOL or you could buy one of mine that has none LOL
2001 Nighthawk Black CLS Type S - Custom Chromed Aluminum Cold Air Intake, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, Custom Aftermarket Paint Etching On Driver Door &lt;a href="http://types.50megs.com/index.html TARGET=_blank"&gt;My Nighthawk&lt;/a&gt;
Old Jan 20, 2001 | 04:45 AM
tw1112's Avatar
HAHA......Maybe I will if I can't figure out this noise. I am going to go check on the installation like you said, hopefully it will fix it. Thanks!
Tw1112
Old Jan 20, 2001 | 04:51 AM
Xephyr2K's Avatar
Good luck hope it works out for you Post here or email me if you need any help
2001 Nighthawk Black CLS Type S - Custom Chromed Aluminum Cold Air Intake, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, Custom Aftermarket Paint Etching On Driver Door http://types.50megs.com/index.html
Old Jan 20, 2001 | 05:45 AM
tw1112's Avatar
Thank you Xephyr2K, btw, when you turn your car off, do you notice a sound coming from the intake? Im not sure if you can hear it with windows up, but with my door open, I can hear the intake stop breathing.....letting out a....I guess 'sigh'??
Tw1112
Old Jan 20, 2001 | 05:47 AM
FDao's Avatar
MikeS,
The difference between the "Popsicle on a stick" Short Ram and the CAI is that the Short Ram will most likely make more power at high RPM vs the CAI which will make more power in the mid to high RPM; mainly more in the midrange. The reason why this is true is that it's due to the length of the tubing. The shorter the tubing the higher the RPM at which a resonance will occur, leading to a bump in HP; thus if you look at most of the Dynos for a CAI and underhood Short Ram, most of the HP is in the midrange for the CAI and upper range for the Short Ram. The longer tubing will have a lower RPM at which a resonance occur leading to a HP bump in the midrange.
Frank
01-S White/Parchment
Comptech Sways & Springs
Old Jan 20, 2001 | 05:53 AM
Xephyr2K's Avatar
TW1112,
Yes that is the the case with all CAI's as mentioned in the post above what you hear after you shut it down is the "vacuum" effect of the CAI induction tube starting to get positive pressure... in short... same noise as the vacuum cleaner after you turn it off
Old Jan 20, 2001 | 02:36 PM
CLpower's Avatar
tw112 turn off your AC and it won't whistle anymore
-99 acura 3.0 CL
Old Jan 20, 2001 | 02:47 PM
tw1112's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CLpower:
</font>
Yeah yeah.....but it gets hot! I used to always drive with windows down, but then someone told me that the less I use my AC, the more it will smell. I really don't want to pay 99 bucks for that AC cleaner thing at the dealer.
Tw1112
Old Jan 20, 2001 | 04:10 PM
CLpower's Avatar
</font>
it's alot better to fart with the windows down and the ac off then with it on...because with it on the smell gets stuck in the AC
-99 acura 3.0 CL
Old Jan 20, 2001 | 04:50 PM
tw1112's Avatar
Good point...Im gonna go roll down my windows now!
Tw1112
Old Jan 20, 2001 | 05:01 PM
Jayru's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Xephyr2K:
</font>
Xephyr2k, I am intrested in an intake. My stock one was destroyed in my accident, and I'll need something to replace it with when the car gets out of the shop. Do you make custom CAI's for the Type-s? If so, what are your prices and do you have a pic I can see?
Thanks!
Old Jan 20, 2001 | 10:23 PM
tw1112's Avatar
Jayru, here is the post that he put up with pictures of his intake.
http://www.acura-cl.com/ubb/Forum1/HTML/000417.html
Good luck....it looks pretty awesome!
Tw1112
Old Jan 20, 2001 | 11:47 PM
Xephyr2K's Avatar
Tw1112 & Jayru,
Thanks for the vote of confidence Its been sounding and performing consistently better in the past week... I attribute that to the fuel mappings being optimized for the increase in airflow and density... BUT my damned GTECH still hasnt arrived !!! I ordered monday and its still not here
Jayru send me an email if you are interested
Old Jan 21, 2001 | 12:17 AM
spiroh's Avatar
Nothing will beat CAI. Dyno Proven. On integra, everybody who had short ram intake dynoed least throughout the whole powerband then a CAI setup.
Old Jan 22, 2001 | 03:23 AM
tw1112's Avatar
Thank you Xephyr2K for helping with the whistling noise! I think it is virtually gone!
Tw1112
Old Jan 22, 2001 | 03:30 AM
Xephyr2K's Avatar
TW1112,
Thats why I love our forum damnit... Aside from the occasional jackass posts everyone tries and help Im glad to hear its helped you
Jul 16, 2017 07:33 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
h22lude
Sep 27, 2015 06:22 PM
AcuraKidd
Sep 25, 2015 11:18 PM
