Short Ram Intake
Ultra Negro
but yes the hum is very noticeable but who cares, the car sounds amazing once you hit v tec with it.
Skuuuurrrrrt!
Actually if i recall there is a book out there that shows the difference between short ram intakes and cold air, a short ram will have less flow restriction than a cold air would, and short rams make more power in the high rpm areas, besides i rock a short ram intake its all i ever used never really saw the use for a cold air intake, and it was easier to do.
Whats up with RDX owners?
Never heard that. Honestly, it's a difficult thing to measure. A dyno doesn't have the air flowing around the car that you would have doing say 80mph on the highway (Camaros with ram air only start to benefit from it at highway speeds, down low it's pointless, similar predicament). A short ram does improve throttle response slightly. In either case, you will make more power, but my vote goes with the cold air intake. Colder air = more air = more fuel = more power.
Received 1,080 Likes
Just remove the resonator from the OEM intake. You'll have a slight performance gain and you'll get the sound that you'd get from a short ram.
Oh and it's free.
Oh and it's free.
Is a chargin mah lazar in
I spent money on a short ram. Loved for about 2 weeks, then wanted to take it out, then it broke. I gave it away for free.
Go CAI/Res Delete+Drop In or don't even bother.
Or you can get a bypass valve or a pre-filter so you don't get hydrolocked..
I'd personally stay away from short ram intakes. I'll bet they're even worse than the stock air intake. I'm sure it brings in hotter air into the engine than the stock intake does.
Resonator delete and drop in is a great choice, and its free and easily reversible..Your stock intake is just fine, if you want sound save up for exhaust. If you want performance just go with some headers when a reputable company comes around and starts making them for cheap lol..or save up for comptech or DC..
Tokin up in
Short Ram good for Sound, -resonator and u got some major sound!. But lets lots of Hot Engine Air in. Had a short am On my 96 TL cyl, Car sounded like a Dam Subaru with exhaust. She was mad Loud when i step on her, And kiked like a mother in higher RPM's. Was looking to do the CAI on her but killed her i got a chance. I would go CAI my
Skuuuurrrrrt!
btw rapture, bypass valves only work if the intake is totaly submerged in water which you souldn't even be driving out if water is that high. Big puddle upsplash has been proved to hydrolock an engine aswell. and NO a SRI is NOT worse than the stock box... Otherwise, there would be no SRIs...
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Save the $100-something dollars and either save up for CAI, or put it into something more useful, like getting a decent set of rotors that won't warp, or SS lines to help the feel of your brake pedal. Or hell, even a set of racing pedals that are more comfortable on your feet and if you're 6MT, easier to heel-toe etc.
Fuck intakes, just turbo the bitch.
the filter is much closer to the engine then the stock airbox. when i removed my intake resonator, the air being drawn in is behind the headlight and below the airbox. the area below the airbox is between the road lamp/front bumper and splashguard/wheelwell. the air is much cooler there.
Do your homework. SRI's are HORRIBLE in regards to heatsoak while the car is sitting still. At speed obviously it doesn't matter, but you're still sucking in hot air from the engine bay as opposed to by the bumper where the colder, denser air masses. If you live in a place where outside temps reach over 80 and drive in city traffic alot SRI's are an unwise choice imo. I wouldn't go as far to say they are worse than the stock box, just less efficient. Sure you're sucking up gobs of air, but its all hot crappy air, how is that more efficient than the stock box that engineers specifically designed for the car? The performance gain over the stock box is marginal, but sure, whatever helps you justify owning one.
If it ain't broke, don't fix it.
Save the $100-something dollars and either save up for CAI, or put it into something more useful, like getting a decent set of rotors that won't warp, or SS lines to help the feel of your brake pedal. Or hell, even a set of racing pedals that are more comfortable on your feet and if you're 6MT, easier to heel-toe etc.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Well if the bypass valve doesn't work against hydrolock, then I guess the best alternative would be to buy an Injen, which people should do in the first place.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
An SRI has aluminum piping, right? And it's sucking in hot air like 5 inches away from the engine, right? So it's doing nothing but sucking in 90+ degree air. The stock air box has plastic pipes. Plastic pipes won't fall victim to heatsoak, so it's still bringing in colder air into the intake (not quite as cold as a CAI would) which should improve performance, no? and I'm sure there are plenty of other mods out there that are worse or do nothing, so that point is kind of invalid. That tornado fuel saver thing comes to mind...
Maybe you shouldn't be so quick to post that noob emoticon next time
Plastic pipes...reminds me of my old Iceman on my Civic. Too bad they don't make them anymore.
lowrd on tein CS biatch
lol what a debate between the two. Here's my 2 cents.
I just got the injen a month ago (the car 2 months ago).
Brand new cost 300 with s/h and duties (gotta love canada), but it's a true showpiece and it does more than it appears.
installing it is kind of a joke, removing the front bumper isn't everyone's cup of tea for such a typically easy mod but it's necessary, and oh my god does it look nice when the bumper is off intake is just installed and you see that air filter poking behind the drivers side headlight/ and above the splash-guard. There's a TON of room for air to get to it, and more importantly nothing HEATING up right beside it make cold air deceased. ALSO the area is quite well contained and CONSIDER THIS.
Most puddles for on the sides of the road (the passenger side) the air is suck in from the drivers side, so unless you PUMMEL through a dirty up puddle, there's no way hydo locking should be an issue.
I think lock up only happens to the careless drivers who know but don't think that veering 4 ft to the left would change their predicament. I'm not trying to point fingers but common, this is something that can easily be avoiding with SLIGHT caution.
Anyways, SRI cannot be better, the physics of hydraulics will tell you the longer something runs through something the more speed it picks up.
EG. look at a sniper gun? LONG ASS BARREL it's there for a reason.
CAI baby all the way... SRIs imo are just for looks and to save money from buying a whole new stock intake system
The air does not speed up going through a cold air intake. If you believe that, you should get one of these:
http://www.tornadoair.com/
There is no pump pushing the air through the air filter, only the engine sucking it in. The air will only go as fast as the engine can pull in. Long pipe or short, it will suck in the same amount. The difference is throttle response.
The air from a cold air intake is better because it is denser. An SRI does not bring in cold air. All the hot air produced by the engine and radiator are sucked up by an SRI, so it will make less power because the are less air molecules mixing with the fuel.
P.S.-I was pretty damn sure sniper rifles have a long muzzle for accuracy, but w/e.
P.P.S.-To those about to do the install, it is NOT necessary to remove the bumper to install a CAI. Just pull back the driver side wheel well liner. You have access to everything right there.
believe me or not, it's ok. yes cold air.. ur right i didn't mention that's the big diff, but as for longer=faster speed, that is tru also. (too an extent) also the same reason why SRI gets faster response is cause it's just sucking air in from shorter. So then that'd mean a SRI is better when you floor it, and CAI is better for WOT runs.
I'm no genieus but, that's how it is from my experience. I've done both/seen both on other cars including my past one, and that's what I've learnt.
Any intake, unless it's plastic will retain heat from the engine bay no matter what because it's metal. Air can't be thaat cold
there's less turbulence when it hits the manifold... kinda like a tb spacer. longer = straighter = faster (like the sniper analogy) only too an extent OBV.
But it's still apples to oranges.. SRIs are safer nomatter what. very rarely can u get the best of both worlds
Lets agree to disagree.
Skuuuurrrrrt!
Skuuuurrrrrt!
The hydroshield pre-filter is pretty resistant against water.
Maybe you shouldn't be so quick to post that noob emoticon next time![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
From the words of an OG mod.... "I only call you a n00b cuz I care."
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I did do my homework. I stand by my statement. SRIs are not worse than stock boxes. Get technical if you will but I can defiantly feel much better throttle response with the SRI. Hot air or not, there is still a little gain over the stock box even if it is marginal. I do live in the city that reaches well over 80 and usually around 100 in summer but there is no way I would ever risk a hydrolock. It has happened to a first genner and he wishes he would have gone with the SRI and saved a couple of grand in engine work. Of course he ended up just selling his CL for a few hundred dollars of course and probably drives some beater right now till he can recoup the money he lost because of a risky move he wishes he didn't do. I don't want to risk that situation. And like I said, I feel the difference from stock box to SRI and the difference is all good and I don't have to worry about a hydro lock. That's all that matters to me.
