Shaving Trunk Question
I took off the "3.2 CL" and "A C U R A" off of my trunk. All of the remaining glue is gone, but now it has an outline of the letters left.
Will this go away after a car wash and wax? Or will I have to do something else to it?
Thanks guys!
Thanks guys!
3.5 psi
Don't be afraid to SEARCH. There's lots of Do It Yourself info on the "official 2nd generation information thread."
Try this:
https://acurazine.com/forums/showthread.php?t=188261
Try this:
Originally Posted by DFoster0
Ive trying rubbing compound to no effect Im gonna def need to wet sand.
i suggest reading up on wet sanding if you do not have any experience. you have to be careful and will still be using compounds to remove the wet sanding scratches. i remember seeing where some idiot polished and burned the paint on his fuel door.
White as night.
Originally Posted by sunnyp43
i used goo gone to remove the remaining glue.
now there is only the outline of the letters
Originally Posted by Corrosion
Just give it time in the sun.
today i got a wash and waxed it but it still remained
i plan on buffing it this weekend
will it fade in, in the sun? i didnt think about that
Originally Posted by 02CLNOS
I used 2000 grit.
White as night.
all of the glue is gone, now its just the outline of where the letters were placed
Originally Posted by lawsofpower48
i have slight outlines of my letters....but it looks like its etched in there a bit? i used wax and the buffing machine..still there....its not glue marks either......is that what everyone else is having? thanks in advanced
Registered Abuser
im having the same problem, seems like some of my clearcoat came off with the adhesive with the lettering
You could just use 1000 grit and then just hit it with a buffer and then use swerl remover to get rid of the buffer marks... finaly use some detailing spray like mothers. It will look sweeeet! But you MUST use a orbital buffer after you wetsand.... doing it my hand looks like shit.
CL-S 6Speed is rarely in
Wet sanding is something I would recommend for more experienced detailer. If you never done it before I personally wouldn't recommend doing it. However if its done right it will look amazing.
A good compound is your best bet. Lighter the color the easier to cover/blend. Use a heat activated compound by machine for best results. Using a different buffer pad, machine easy with a good polish followed by a hard paste wax by hand. When applying your compounds, waxes and polishes try to keep it a minimum of 1/2 and inch away from all edges and remaining badges. This will help not tear up the pad or burn your edges. I can recommend some good stuff to use if your interested in doing it yourself. A good detail shop should be able to do it either way in less than and hour for a reasonable charge.
BoricuaTL
04-08-2016 01:08 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
