Service Bulletins for 2001Acura CL-S Automatic
Below are a list of Service Bulletins. If you have a consistent problem, it is probaly listed below. There is over 150 problems. My brake light stays on all the time for no reason, then I found this article.
Component Description:
1. EQUIPMENT:ELECTRICAL
Bulletin Number: 090105
Bulletin Date: SEP 2005
Vehicle: 2001 Acura CL
Summary:
HOMELINK WON'T PROGRAM WITH AFTERMARKET REMOTES. ( NHTSA ITEM NUMBER - 10018109 )
2. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 09012005
Summary:
DON'T INVITE PROBLEMS DOING 2ND GEAR INSPECTION. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10018044 )
3. ELECTRICAL SYSTEM
Bulletin Number: 07012005
Bulletin Date: JUL 2005
Summary:
SPEEDOMETER SHOPS CAN TRANSFER ODOMETER MILEAGE. ACURA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10018038 )
4. SUSPENSION:FRONT:STABILIZER BAR
Bulletin Number: 05015
Bulletin Date: JUN 2005
Summary:
REAR STABILIZER LINK IS BROKEN. ( NHTSA ITEM NUMBER - 10017506 )
5. POWER TRAIN
Bulletin Number: 505
Bulletin Date: MAY 2005
Summary:
CANON A75 DIGITAL CAMERA REPLACEMENT. ( NHTSA ITEM NUMBER - 10016261 )
6. ENGINE AND ENGINE COOLING:ENGINE
Summary:
CRANKS WON'T START, IMMOBILIZER LIGHT FLASHES. ( NHTSA ITEM NUMBER - 10016260 )
7. SEATS
Bulletin Number: 04006
Bulletin Date: APR 2005
Summary:
SEAT-BACK PANEL IS LOOSE OR DETACHED. ( NHTSA ITEM NUMBER - 10017507 )
8. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 01162005
Bulletin Date: JAN 2005
Summary:
REPLACEMENT OR UPDATED NAVIGATION DVD DISKS. ( NHTSA ITEM NUMBER - 10014774 )
9. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
P1706 A/T SWITCH SHORT OR OPEN. ( NHTSA ITEM NUMBER - 10014766 )
10. VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
Bulletin Number: 04035
Bulletin Date: NOV 2004
Summary:
ACCELERATOR PEDAL HARD TO PRESS. ( NHTSA ITEM NUMBER - 10013622 )
11. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 04020
Summary:
SAFETY RECALL: CL AND TL AUTOMATIC TRANSMISSION SECOND GEAR INSPECTION. ( NHTSA ITEM NUMBER - 10010763 )
12. EQUIPMENT
Bulletin Number: 10012004
Bulletin Date: OCT 2004
Summary:
CAMERA FIXTURE RETAINER KNOBS NOW AVAILABLE. ( NHTSA ITEM NUMBER - 10013930 )
13. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
A/T SOLENOID REPLACEMENT CRITERIA. ( NHTSA ITEM NUMBER - 10013911 )
14. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
HOW TO REMOVE A STUBBORN ATF FILLER BOLT. ( NHTSA ITEM NUMBER - 10013909 )
15. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
HOW TO REPLENISH ATF ON VEHICLES WITH A/T OIL JET KITS. ( NHTSA ITEM NUMBER - 10013905 )
16. EQUIPMENT
Bulletin Number: 09012004
Bulletin Date: SEP 2004
Summary:
REPLACING NAVIGATION SYSTEM DVD'S CAN CAUSE DVD DISK ERROR. ( NHTSA ITEM NUMBER - 10013845 )
17. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 904
Summary:
AUTOMATIC TRANSMISSION SOLENOID REPLACEMENT CRITERIA. ACURA TECH LINE SUMMARY FOR DEALER DISTRIBUTION. ( NHTSA ITEM NUMBER - 10013745 )
18. FUEL SYSTEM, OTHER
Summary:
POOR FUEL ECONOMY. ACURA TECH LINE SUMMARY FOR DEALER DISTRIBUTION. ( NHTSA ITEM NUMBER - 10013743 )
19. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
AUTOMATIC TRANSMISSION FLUID (ATF) FILLER PLUG STUCK IN CASE. ACURA TECH SUMMARY LINE FOR DEALER DISTRIBUTION. ( NHTSA ITEM NUMBER - 10013746 )
20. EQUIPMENT
Summary:
THE BEVERAGE HOLDER LID DOESN'T CLOSE EVENLY. ( NHTSA ITEM NUMBER - 10013871 )
21. ELECTRICAL SYSTEM
Bulletin Number: 804
Bulletin Date: AUG 2004
Summary:
NAVIGATION ERROR MESSAGE-DVD DISK READ ERROR. ( NHTSA ITEM NUMBER - 10014093 )
22. POWER TRAIN
Summary:
CANON DIGITAL CAMERA LOAN PROGRAM. ( NHTSA ITEM NUMBER - 10014133 )
23. VISIBILITY:WINDSHIELD
Bulletin Number: 00025
Summary:
DEFORMED WINDSHIELD MOLDING. ( NHTSA ITEM NUMBER - 10012636 )
24. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 08012004
Summary:
USING THE CORRECT FLASH SETTING FOR DIGITAL INSPECTION PHOTOS. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10009270 )
25. OTHER
Summary:
STORE DIGITAL INSPECTION PHOTOS FOR WARRANTY CLAIMS FOR SERVICE BULLETIN (S/B) 04-013, SAFETY RECALL, AUTOMATIC TRANSMISSION SECOND GEAR INSPECTION AND S/B 04-020, SAFETY RECALL, CL AND TL AUTOMATIC TRANSMISSION SECOND GEAR INSPECTION. ACU ( NHTSA ITEM NUMBER - 10009268 )
26. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 704
Bulletin Date: JUL 2004
Summary:
NAVIGATION SYSTEM WON'T MAP MATCH OR GETS LOST. ACURA TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10013727 )
27. POWER TRAIN
Bulletin Number: 07012004
Summary:
CAMPAIGN ANNOUNCEMENT AND STOP SALE ORDER UPDATE. VOLUNTARY RECALL OF LIGHT TRUCK MODELS FOR A POTENTIAL TRANSMISSION DEFECT. ( NHTSA ITEM NUMBER - 10008889 )
28. ELECTRICAL SYSTEM
Bulletin Number: 604
Bulletin Date: JUN 2004
Summary:
IF NAVIGATION SYSTEM INTERMITTENTLY DISPLAYS THE MESSAGE, DATABASE OLD SEE YOUR DEALER, APPLY THE NAVIGATIONAL SYSTEM OPERATING SYSTEM SOFTWARE PATCH. ( NHTSA ITEM NUMBER - 10014049 )
29. EQUIPMENT:ELECTRICAL:ANTI-THEFT DEVICES
Bulletin Number: 05012004
Bulletin Date: MAY 2004
Summary:
AUDIO UNIT AND NAVI ANTI-THEFT CODES AVAILABLE ON IN. ACURA SERVICENEWS. MAY 2004. ( NHTSA ITEM NUMBER - 10009002 )
30. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 105
Summary:
DIAGNOSTIC TROUBLE CODE P0780 AFTER SOLENOID OR TRANSMISSION R&R. TECH LINE SUMMARY. ACURA. ( NHTSA ITEM NUMBER - 10009013 )
31. EQUIPMENT:ELECTRICAL
Summary:
USE THE HONDA DIAGNOSTIC SYSTEM TO READ SRS DIAGNOSTIC TROUBLE CODES. ACURA SERVICENEWS. MAY 2004. ( NHTSA ITEM NUMBER - 10009005 )
32. ELECTRICAL SYSTEM
Bulletin Number: 02015
Bulletin Date: APR 2004
Summary:
SRS INDICATOR COMES ON WITH SRS DIAGNOSTIC TROUBLE CODE. ( NHTSA ITEM NUMBER - 10012658 )
33. AIR BAGS
Bulletin Number: 04012004
Summary:
SRS INDICATOR ON AFTER BODY SHOP REPAIR. CHECK FOR SRS DIAGNOSTIC TROUBLE CODES. ACURA SERVICENEWS. APRIL 2004. ( NHTSA ITEM NUMBER - 10009036 )
34. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
DON'T TEST-DRIVE WITH THE MALFUNCTION INDICATOR LAMP OR D INDICATOR ON. ACURA. SERVICENEWS. APRIL 2004. ( NHTSA ITEM NUMBER - 10009042 )
35. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
REPAIRING ATF LEAKS UNDER WARRANTY. ACURA. SERVICENEWS. APRIL 2004. ( NHTSA ITEM NUMBER - 10009040 )
36. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Number: 01041
Bulletin Date: FEB 2004
Summary:
V6 ENGINE OIL LEAKS. ( NHTSA ITEM NUMBER - 626267 )
37. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 020204
Summary:
BROKEN HEAD BOLT(S). REQUEST FOR PARTS. ( NHTSA ITEM NUMBER - 10006742 )
38. POWER TRAIN
Bulletin Number: 012012003
Bulletin Date: DEC 2003
Summary:
ATF (AUTOMATIC TRANSMISSION FLUID) LEAKS FROM COOLER LINE BANJO BOLT. ( NHTSA ITEM NUMBER - 10014344 )
39. POWER TRAIN
Summary:
DON'T REUSE OLD ATF FLUID) WARMER ON REMAN A/T (AUTOMATIC TRANSMISSION) ( NHTSA ITEM NUMBER - 10014334 )
40. VISIBILITY
EFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING
Bulletin Number: 1003
Bulletin Date: OCT 2003
Summary:
HEATER BLOWER MOTOR OVERHEATS OR BLOWS FUSE. ( NHTSA ITEM NUMBER - 10004960 )
41. POWER TRAIN
Summary:
HUMMING, GROWLING SOUND FROM TRANSMISSION. ( NHTSA ITEM NUMBER - 10004957 )
42. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 03028
Summary:
NAVIGATION SYSTEM DISPLAYS U.S. POST OFFICE PHONE NUMBERS INCORRECTLY. VARIOUS MODELS INCLUDING 2003 RL. ( NHTSA ITEM NUMBER - 10004804 )
43. SERVICE BRAKES, HYDRAULIC
Bulletin Number: 03029
Summary:
BRAKE SYSTEM INDICATOR COMES ON AND GOES OFF. ( NHTSA ITEM NUMBER - 10004801 )
44. TIRES
Bulletin Number: 090103
Bulletin Date: SEP 2003
Summary:
TIRE NOISE AND/OR WIND NOISE CAN MASQUERADE AS A PROBLEM WITH AUTOMATIC TRANSMISSION GEARS. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005068 )
45. ENGINE AND ENGINE COOLING:COOLING SYSTEM
Summary:
UNDERSTANDING OUTSIDE AIR TEMPERATURE INDICATOR LOGIC. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005067 )
46. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Bulletin Number: 03017
Summary:
POWERTRAIN CONTROL MODULE (PCM) REPLACEMENT. ( NHTSA ITEM NUMBER - 10004691 )
47. POWER TRAIN
Bulletin Number: 903
Summary:
WARRANTY EXTENSION TRANSMISSION DIAGNOSIS. TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10005014 )
48. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 091603
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P0128 OR P1486, THERMOSTAT RANGE/PERFORMANCE. TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10005012 )
49. EQUIPMENT:ELECTRICAL
Bulletin Number: 03015
Bulletin Date: AUG 2003
Summary:
REMOTE AUDIO CONTROLS DO NOT WORK PROPERLY. ( NHTSA ITEM NUMBER - 10003057 )
50. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 080103
Summary:
CHECKING FOR A HOLE BEFORE INSTALLING A REMANUFACTURED TRANSMISSION. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005119 )
51. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 02027
Summary:
WARRANTY EXTENSION - 3.2TL AND 3.2CL AUTOMATIC TRANSMISSION. ( NHTSA ITEM NUMBER - 10003054 )
52. ELECTRICAL SYSTEM
Bulletin Number: 603
Bulletin Date: JUN 2003
Summary:
A FAULTY AFT TEMPERATURE SENSOR OR A PROBLEM WITH THE ATF TEMPERATURE SENSOR CIRCUIT CAN CAUSE DIAGNOSTIC TROUBLE CODE (DTC) P0710. ( NHTSA ITEM NUMBER - 10003195 )
53. ELECTRICAL SYSTEM
Summary:
IF DIAGNOSTIC TROUBLE CODES P0758, P0763 OR P1758 ARE RETAINED OR THE SHIFTING IS ERRATIC AFTER INSTALLING A REMANUFACTURED TRANSMISSION, REFER TO THE ETM AND CHECK THE GROUND G151. ( NHTSA ITEM NUMBER - 10003196 )
54. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary:
INFORMATION ON REMEMBERING NAVIGATION SYSTEM PERSONAL IDENTIFICATION NUMBER (PIN). ( NHTSA ITEM NUMBER - 10003198 )
55. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
Bulletin Number: 060103
Summary:
INFORMATION ON FINDING A VEHICLE'S EMISSION TYPE OR GROUP. ( NHTSA ITEM NUMBER - 10002692 )
56. ENGINE AND ENGINE COOLING:ENGINE
Summary:
ENGINE RUNS ROUGH FROM 40 TO 70 MPH WITH DIAGNOSTIC TROUBLE CODES P0301 THRU P0306, P1399, P0133 SET - SERVICE TIPS. ( NHTSA ITEM NUMBER - 10002693 )
57. ELECTRICAL SYSTEM
Summary:
MULTIPLE DIAGNOSTIC TROUBLE CODES AFTER TRANSMISSION REMOVAL AND REPLACEMENT. ( NHTSA ITEM NUMBER - 10002696 )
58. ELECTRICAL SYSTEM
Summary:
DIAGNOSTIC TROUBLE CODE P0710 (AFT TEMPERATURE SENSOR) SET - TROUBLESHOOTING TIPS. ( NHTSA ITEM NUMBER - 10002698 )
59. SERVICE BRAKES, HYDRAULIC
Bulletin Number: 01017
Bulletin Date: MAY 2003
Summary:
BRAKE PEDAL, STEERING WHEEL, OR VEHICLE VIBRATES WHILE BRAKING. ( NHTSA ITEM NUMBER - 10001602 )
60. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
POWERTRAIN CONTROL MODULE (PCM) REPLACEMENT. ( NHTSA ITEM NUMBER - 10001603 )
61. EXTERIOR LIGHTING:HEADLIGHTS
Bulletin Number: 030003
Bulletin Date: APR 2003
Summary:
HEADLIGHT HOUSING MAY BREAK OFF IN A MINOR ACCIDENT. ( NHTSA ITEM NUMBER - 10001573 )
62. EXTERIOR LIGHTING:HEADLIGHTS
Bulletin Number: 040103
Summary:
USING AN AUXILIARY HEADLIGHT BRACKET AFTER AN ACCIDENT - INFORMATION. ( NHTSA ITEM NUMBER - 10002784 )
63. SERVICE BRAKES, HYDRAULIC
Summary:
BRAKE PEDAL, STEERING WHEEL, OR VEHICLE VIBRATES WHILE BRAKING. ( NHTSA ITEM NUMBER - 10001571 )
64. POWER TRAIN
Summary:
DIAGNOSTIC TROUBLE CODE (DTC) P1656 OR DTC 83-1 AFTER DOING SERVICE BULLETIN 03-002. ( NHTSA ITEM NUMBER - 10002791 )
65. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Date: FEB 2003
Summary:
AUTOMATIC TRANSMISSION WARRANTY EXTENSION. ( NHTSA ITEM NUMBER - 10001450 )
66. AIR BAGS
Bulletin Number: 010103
Bulletin Date: JAN 2003
Summary:
SRS INDICATOR COMES ON AFTER BODY SHOP REPAIR. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005122 )
67. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 011303
Summary:
INSPECTION OF AUTOMATIC TRANSMISSIONS WITH DATA TROUBLE CODE P0710 DISPLAYED. ( NHTSA ITEM NUMBER - 10000987 )
68. FUEL SYSTEM, OTHER
Bulletin Number: 03001
Summary:
MALFUNCTION INDICATOR LAMP COMES ON WITH DIAGNOSTIC TROUBLE CODE P1457 EVAP BYPASS SOLENOID VALVE FAILURE. ( NHTSA ITEM NUMBER - 10000991 )
69. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 03002
Summary:
THE 3RD GEAR CLUTCH PACK IN THE AUTOMATIC TRANSMISSION MAY BE WORN. ( NHTSA ITEM NUMBER - 10000992 )
70. SEATS:FRONT ASSEMBLY:POWER ADJUST
Bulletin Number: 1202
Bulletin Date: DEC 2002
Summary:
POWER SEAT NOISY OR MOVES SLOWLY. ( NHTSA ITEM NUMBER - 10002584 )
71. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
STRAINING THE AUTOMATIC TRANSMISSION FLUID TO DIAGNOSE AUTOMATIC TRANSMISSIONS. ( NHTSA ITEM NUMBER - 10002583 )
72. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 110102
Bulletin Date: NOV 2002
Summary:
AIR CONDITIONING (A/C) COMPRESSOR CONTROL LOGIC. ACURA SERVICE NEWS. ( NHTSA ITEM NUMBER - 10005860 )
73. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Bulletin Number: 1102
Summary:
TROUBLESHOOTING ABS OR TCS DIAGNOSTIC TROUBLE CODE 51 AND/OR 53. ( NHTSA ITEM NUMBER - 10014061 )
74. ELECTRICAL SYSTEM
Summary:
CEILING LIGHT, IGNITION KEY BEEPER FOIL KEYLESS ENTRY. ( NHTSA ITEM NUMBER - 10005865 )
75. ELECTRICAL SYSTEM
Summary:
ODOMETER ACCURACY. ( NHTSA ITEM NUMBER - 10014071 )
76. ELECTRICAL SYSTEM
Summary:
SRS WARNING LIGHT ON AFTER BODY SHOP REPAIR. ( NHTSA ITEM NUMBER - 10014075 )
77. STEERING:HYDRAULIC POWER ASSIST:PUMP
Summary:
POWER STEERING BELT TENSION ADJUSTMENT. ( NHTSA ITEM NUMBER - 10014065 )
78. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 100102
Bulletin Date: OCT 2002
Summary:
POOR AIR CONDITIONER COOLING ON HARD ACCELERATION. ACURA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005950 )
79. EQUIPMENT:ELECTRICAL
Bulletin Number: 1002
Summary:
KEYLESS REMOTE TRANSMITTER INOPERATIVE, . CHECK KEYLESS, CEILING LIGHT, IGNITION KEY REMINDER BEEPER BEFORE TROUBLESHOOTING KEYLESS REMOTE SYSTEM. OCTOBER TECH LINE INFORMATION. ( NHTSA ITEM NUMBER - 10009255 )
80. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
A/C COMPRESSOR CONTROL LOGIC. OCTOBER TECH LINE INFORMATION. ( NHTSA ITEM NUMBER - 10009254 )
81. POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
AUTOMATIC TRANSMISSION WARRANTY EXTENSION. ( NHTSA ITEM NUMBER - 10000255 )
82. SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
Summary:
THE COMPACT ABS/TCS (MODULATOR, PUMP, AND ACCUMULATOR ALL IN ONE) SYSTEM DOES A SELF-CHECK (A BRIEF GRUNT OR GROAN) WHEN BACKING OUT OF THE GARAGE OR DRIVE FORWARD AFTER THE VEHICLE'S BEEN SITTING. THE NOISE IS NORMAL. OCTOBER TECH LINE I ( NHTSA ITEM NUMBER - 10009252 )
83. SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
CLEARING ANTILOCK BRAKING SYSTEM DIAGNOSTIC TROUBLE CODES. OCTOBER TECH LINE INFORMATION. ( NHTSA ITEM NUMBER - 10009253 )
84. EQUIPMENT
Bulletin Number: 01043
Summary:
LOWER CONSOLE COMPARTMENT LID DOES NOT STAY LATCHED. ( NHTSA ITEM NUMBER - 10000252 )
85. AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Summary:
INTERMITTENT SRA DIAGNOSTIC TROUBLE CODE 1-1 TO 1-5, DRIVER'S AIRBAG INFLATOR CIRCUIT. OCTOBER TECH LINE INFORMATION. ( NHTSA ITEM NUMBER - 10009256 )
86. ENGINE AND ENGINE COOLING:COOLING SYSTEM
Bulletin Number: 09012002
Bulletin Date: SEP 2002
Summary:
OUTSIDE TEMPERATURE INDICATOR LOGIC. ACURA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10009287 )
87. OTHER
Bulletin Number: 010802
Bulletin Date: AUG 2002
Summary:
SUBJECT REGARDING FAULTY BEVERAGE HOLDER COVERS. ( NHTSA ITEM NUMBER - 637406 )
88. ELECTRICAL SYSTEM
Bulletin Number: 107
Bulletin Date: JUL 2002
Summary:
INFORMATION ON DIAGNOSING SRS DIAGNOSTIC TROUBLE CODE 6-7 AND / OR 7-2 INTERNAL FAILURE OF SRS UNIT. ( NHTSA ITEM NUMBER - 637638 )
89. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Bulletin Number: 010702
Summary:
SUBJECT REGARDING TORQUE SPECIFICATIONS MISSING FOR TIMING BELT TENSIONER. ( NHTSA ITEM NUMBER - 636799 )
90. EQUIPMENT
Summary:
SUBJECT REGARDING SYNCHRONIZING CUP HOLDER COVERS. ( NHTSA ITEM NUMBER - 637647 )
91. AIR BAGS
Summary:
SUBJECT REGARDING SRS INDICATOR ON WITH SRS DIAGNOSTIC TROUBLE CODES 15-1, 15-2, AND 15-3. REPLACES 01-013 AS WELL. ( NHTSA ITEM NUMBER - 633350 )
92. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Number: 602
Bulletin Date: JUN 2002
Summary:
SUBJECT REGARDING PGM TESTER MISFIRE COUNTER. ( NHTSA ITEM NUMBER - 637621 )
93. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Summary:
SUBJECT REGARDING TIMING BELT TENSIONER BOLT TORQUE SPECIFICATION. ( NHTSA ITEM NUMBER - 637623 )
94. POWER TRAIN:AUTOMATIC TRANSMISSION
Bulletin Number: 502
Bulletin Date: MAY 2002
Summary:
CONCERNS WITH AUTOMATIC TRANSMISSION FLUID LEAK AT AXLE SEALS, ROARING NOISE, ERRATIC SHIFTING. ( NHTSA ITEM NUMBER - 638045 )
95. POWER TRAIN:MANUAL TRANSMISSION
Summary:
INFORMATION ON SERVICING ERRATIC SHIFTING, SLIPPING, AND FLARE AT UPSHIFTS. ( NHTSA ITEM NUMBER - 638024 )
96. OTHER
Bulletin Number: 402
Bulletin Date: APR 2002
Summary:
INFORMATION ON SERVICING THE ODOMETER, SPORT SHIFT INDICATOR ILLUMINATION INOPERATIVE. ( NHTSA ITEM NUMBER - 637938 )
97. VISIBILITY:SUN ROOF ASSEMBLY
Bulletin Number: 00032
Summary:
INFORMATION REGARDING SQUEAKS HEARD FROM THE MOONROOF SEAL WHILE DRIVING WITH THE GLASS CLOSED AND THE SUNSHADE OPEN. ( NHTSA ITEM NUMBER - 633359 )
98. SEATS
Bulletin Number: B020008
Bulletin Date: MAR 2002
Summary:
INFORMATION REGARDING SEAT BACK PANEL REPAIR KIT. ( NHTSA ITEM NUMBER - 631772 )
99. ELECTRICAL SYSTEM:IGNITION:MODULE
Bulletin Number: 010302
Summary:
INFORMATION ON TROUBLE SHOOTING MULTIPLE MISFIRE DIAGNOSTIC TROUBLE CODES P0301 THRU P0306. ( NHTSA ITEM NUMBER - 636764 )
100. SEATS
Bulletin Number: 02006
Summary:
VEHICLES MAY EXPERIENCE SEAT BACK PANEL BECOMING LOOSE OR DETACHED. ( NHTSA ITEM NUMBER - 631968 )
101. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Number: 302
Summary:
SOME 2000 MDX MODELS AS WELL AS OTHER MODELS MAY EXHIBIT BRIEF HESITATION WHEN ACCELERATING AT HIGH ENGINE SPEED. ( NHTSA ITEM NUMBER - 631035 )
102. ELECTRICAL SYSTEM:IGNITION:MODULE
Bulletin Number: 102
Bulletin Date: JAN 2002
Summary:
INFORMATION ON TROUBLESHOOTING DIAGNOSTIC TROUBLE CODES P1705, P1768, P0753, P0758. ( NHTSA ITEM NUMBER - 629322 )
103. VISIBILITY
Bulletin Number: 061201
Bulletin Date: DEC 2001
Summary:
INFORMATION REGARDING THE HEATER VALVE CABLE SOMETIMES DISCONNECTS AT THE AIR MIX CONTROL LINKAGE. ( NHTSA ITEM NUMBER - 627072 )
104. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Date: NOV 2001
Summary:
INFORMATION REGARDING NAVIGATION DISPLAY NOT CENTERED. ( NHTSA ITEM NUMBER - 627275 )
105. ELECTRICAL SYSTEM
Bulletin Date: OCT 2001
Summary:
SUBJECT REGARDING CRANKS, WON'T START WITH TYPE II IMMOBILIZER SYSTEM. ( NHTSA ITEM NUMBER - 626635 )
106. SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS
ISC:PADS
Summary:
BRAKE PEDAL PULSE. ( NHTSA ITEM NUMBER - 626239 )
107. POWER TRAIN:MANUAL TRANSMISSION
Summary:
SUBJECT REGARDING SPEED SENSOR PLUG MISSING. ( NHTSA ITEM NUMBER - 626590 )
108. AIR BAGS
Summary:
SUBJECT REGARDING SAFETY RESTRAINT SYSTEM DIAGNOSTIC TROUBLE CODE 5-1 THROUGH 8-3, INTERNAL SAFETY RESTRAINT SYSTEM UNIT FAILURE. ( NHTSA ITEM NUMBER - 626607 )
109. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
Bulletin Number: 901
Bulletin Date: SEP 2001
Summary:
SUBJECT REGARDING DRIVER'S POWER WINDOW AUTO-DOWN INOPERATIVE. ( NHTSA ITEM NUMBER - 626524 )
110. OTHER
Bulletin Number: 01016
Summary:
SUBJECT PERTAINING TO MALFUNCTION INDICATOR LAMP COMES WITH DIAGNOSTIC TROUBLE CODE P0128 OR P1486. ( NHTSA ITEM NUMBER - 626144 )
111. EXTERIOR LIGHTING
Bulletin Number: 01031
Summary:
VEHICLES MAY EXPERIENCE BURNED OUT ROAD LAMP BULB. ( NHTSA ITEM NUMBER - 626151 )
112. AIR BAGS
Summary:
SUBJECT REGARDING SRS LIGHT ON AFTER OPDS CONTROL UNIT REPLACEMENT. ( NHTSA ITEM NUMBER - 626530 )
113. AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Bulletin Number: 01072001
Bulletin Date: AUG 2001
Summary:
SUBJECT REGARDING SRS DIAGNOSTIC TROUBLE CODE. ( NHTSA ITEM NUMBER - 623461 )
114. STRUCTURE
Bulletin Number: 070801
Summary:
CUSTOMERS MAY COMPLAIN OF SQUEAK AND RATTLE COMPLAINTS. ( NHTSA ITEM NUMBER - 623271 )
115. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:MANIFOLD/HEADER/MUFFLER/TAIL PIPE
Bulletin Number: 99051
Summary:
EXHIBITING MUFFLER PAINT PEELING. ( NHTSA ITEM NUMBER - 623238 )
116. VISIBILITY:GLASS, SIDE/REAR
Bulletin Number: 701
Bulletin Date: JUL 2001
Summary:
SUBJECT REGARDING WITH NAVIGATION SKYSTEM - REAR WINDOW TINT APPLICATION TIPS. ( NHTSA ITEM NUMBER - 626550 )
117. VISIBILITY:WINDSHIELD WIPER/WASHER
Bulletin Number: 01004
Summary:
VEHICLES MAY EXPERIENCE WIPERS STREAKING OR SMEARING THE WINDSHIELD. ( NHTSA ITEM NUMBER - 623220 )
118. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin Number: 01062001
Bulletin Date: JUN 2001
Summary:
SUBJECT REGARDING CLIMATE CONTROL DISPLAY CHANGES INTERMITTENTLY. ( NHTSA ITEM NUMBER - 623529 )
119. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
Summary:
SUBJECT REGARDING THE DRIVER'S POSITION MEMORY POSITION SYSTEM,DPMS, CAN RECALL TWO DIFFERENT DRIVER'S POWER SEAT AND POWER MIRROR SETTINGS. ( NHTSA ITEM NUMBER - 623652 )
120. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Summary:
THE FRONT AND REAR MOTOR MOUNTS MAKE A THUMP NOISE WHEN THE ENGINE IS FIRST STARTED AFTER SITTING FOR SEVERAL HOURS. THIS NOISE IS A NORMAL CHARACTERISTIC. REPLACING MOTOR MONTS MAY ELIMINATE THIS NOISE TEMPORARILY, BUT THE NOISE WILL REC ( NHTSA ITEM NUMBER - 623640 )
121. SERVICE BRAKES, ELECTRIC
Summary:
122. SERVICE BRAKES, ELECTRIC
Summary:
SUBJECT REGARDING SRS DTC 15-3, FAULTY OPDS SENSOR CODE. ( NHTSA ITEM NUMBER - 623649 )
123. OTHER
Summary:
CONCERNS WITH MALFUNCTION INDICATOR LAMP COMING ON WITH DIAGNOSTIC TROUBLE CODE. ( NHTSA ITEM NUMBER - 623202 )
124. OTHER
Summary:
SUBJECT REGARDING S/M FIX: VSA NEUTRAL POSITION MEMORIZATION. ALL MODELS. ( NHTSA ITEM NUMBER - 623523 )
125. ELECTRICAL SYSTEM:BATTERY
Bulletin Number: 300501
Bulletin Date: MAR 2001
Summary:
AMERICAN HONDA, HONDA OF AMERICA MANUFACTURING, AND DELPHI WILL CONDUCT THE RETURN OF CERTAIN DELPHI BATTERIES. THE BATTERIES INVOLVED ARE DELPHI FREEDOM GROUP SIZE 35, CCA 440. ( NHTSA ITEM NUMBER - 619878 )
126. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 010301
Summary:
INFORMATION ON THE NAVIGATION SYSTEM 4-DIGIT SECURITY CODE. ( NHTSA ITEM NUMBER - 619907 )
127. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary:
INFORMATION ON TROUBLESHOOTING NAVIGATION SYSTEM DVD READ ERROR MESSAGE. ( NHTSA ITEM NUMBER - 619908 )
128. ENGINE AND ENGINE COOLING:ENGINE
Bulletin Number: 160301
Summary:
INFORMATION ON VEHICLES EXHIBITING DIAGNOSTIC TROUBLE CODE P1486 AND / OR P0128 THERMOSTAT PERFORMANCE. ( NHTSA ITEM NUMBER - 619902 )
129. POWER TRAIN:CLUTCH ASSEMBLY:PEDAL/LINKAGE
Summary:
SUBJECT REGARDING AUTOMATIC TRANSAXLE CLUTCH PRESSURE SWITCH. ( NHTSA ITEM NUMBER - 619900 )
130. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
SUBJECT REGARDING TRACTION CONTROL SYSTEM (TCS) OPERATION. ( NHTSA ITEM NUMBER - 619896 )
131. STEERING
Summary:
STABILITY ASSIST ACTIVATING TOO SOON. ( NHTSA ITEM NUMBER - 619906 )
132. AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Bulletin Number: 01013
Summary:
THE SRS INDICATOR IS ON AND DIAGNOSTIC TROUBLE CODE 15-3 (FAULTY OPDS SENSOR) IS SET. ( NHTSA ITEM NUMBER - 619881 )
133. VISIBILITY:WINDSHIELD WIPER/WASHER
Bulletin Number: 010201
Bulletin Date: FEB 2001
Summary:
SUBJECT REGARDING CURRENT VARIABLE INTERMITTENT WIPERS SPEED SENSITIVE. ( NHTSA ITEM NUMBER - 619886 )
134. ENGINE AND ENGINE COOLING:COOLING SYSTEM:FAN
Bulletin Number: 01011
Summary:
ON SOME VEHICLES, THE RADIATOR FAN AND / OR THE CONDENSER FAN RUNS CONTINUOUSLY; OR, IF THE FAN(S) RAN CONTINUOUSLY WHEN THE ENGINE WAS OFF, THE BATTERY MAY BE DISCHARGED. ( NHTSA ITEM NUMBER - 618754 )
135. OTHER
Summary:
INFORMATION ON TROUBLESHOOTING DIAGNOSTIC TROUBLE CODE P0138. ( NHTSA ITEM NUMBER - 619888 )
136. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 010101
Bulletin Date: JAN 2001
Summary:
BRIEF INFORMATION REGARDING BLANK NAVIGATION DISPLAY CONDITION. ( NHTSA ITEM NUMBER - 617701 )
137. SEAT BELTS:FRONT:ANCHORAGE
Summary:
INFORMATION ON REPLACING SEAT BELT TENSIONERS AFTER DEPLOYMENT. ( NHTSA ITEM NUMBER - 617697 )
138. VISIBILITY:WINDSHIELD WIPER/WASHER
Summary:
TECH LINE SUMMARY REGARDING THE INTERMITTENT WIPER FEATURE. ( NHTSA ITEM NUMBER - 617695 )
139. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary:
TECH LINE SUMMARY REGARDING THE TRACTION CONTROL SYSTEM. ( NHTSA ITEM NUMBER - 617694 )
140. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Summary:
TECH LINE SUMMARY REGARDING AIR CLEANER SEVERE CONDITIONS MAINTENANCE SCHEDULE. ( NHTSA ITEM NUMBER - 617690 )
141. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Number: 01001
Summary:
SOME VEHICLES WITHIN CERTAIN VIN RANGES MAY EXHIBIT EXCESSIVE CRANKING TO START THE ENGINE AFTER THE VEHICLE IS DRIVEN AND THEN PARKED (WITH THE ENGINE OFF) FOR ABOUT 15 TO 20 MINUTES. ( NHTSA ITEM NUMBER - 617703 )
142. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Bulletin Number: 011100
Bulletin Date: NOV 2000
Summary:
INFORMATION ON THE NAVIGATION SYSTEM COVERAGE AREA FOR 2001 3.2CL, 2001 MDX, 2000 - 2001 3.2TL AND 2000 - 2001 3.5RL MODELS. ( NHTSA ITEM NUMBER - 615748 )
143. SEAT BELTS
Bulletin Number: 00033
Summary:
SOME 2000 3.2TL AND 2001 3.2CL MODEL VEHICLES MAY EXHIBIT THE SRS LIGHT ON WITH DIAGNOSTIC TROUBLE CODE 15-1 (FAULTY OCCUPANT POSITION DETECTION SYSTEM UNIT) STORED. ( NHTSA ITEM NUMBER - 615580 )
144. EQUIPMENT
Summary:
ON SOME VEHICLES, THE PGM TESTER DOES NOT RECOGNIZE SIDE AIRBAGS. ( NHTSA ITEM NUMBER - 615751 )
145. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM)
Summary:
SUBJECT PERTAINING TO THE LATEST NAVIGATION SYSTEM DVD SOFTWARE FOR 2001 3.2CL, 2001 MDX, 2000 - 2001 3.2TL, AND 2000 - 2001 3.5RL MODELS. ( NHTSA ITEM NUMBER - 615747 )
146. STRUCTURE:BODY
Summary:
ON ALL 1999-01 3.2TL, 2001 3.2CL AND 2001 MDX MODEL VEHICLES, THE MOONROOF SEAL SQUEAKS AGAINST THE ROOF WHEN THE GLASS IS CLOSED AND THE SUNSHADE IS OPEN. ( NHTSA ITEM NUMBER - 615579 )
147. VISIBILITY:WINDSHIELD WIPER/WASHER
Bulletin Number: 011000
Bulletin Date: OCT 2000
Summary:
INFORMATION ON WINDSHIELD WIPER SMEARING AND STREAKING. ( NHTSA ITEM NUMBER - 615758 )
148. ELECTRICAL SYSTEM
Summary:
SUBJECT REGARDING ETM FIX - KEYLESS RECEIVER LOCATION. ( NHTSA ITEM NUMBER - 618768 )
149. ENGINE AND ENGINE COOLING
Summary:
ON SOME VEHICLES, FAULTY FRONT AND REAR WATER PASSAGE GASKETS AT THE FRONT CYLINDER HEAD CAN CAUSE A COOLANT LEAK NEXT TO THE EGR VALVE. ( NHTSA ITEM NUMBER - 618766 )
150. ENGINE AND ENGINE COOLING:ENGINE
Summary:
SUBJECT REGARDING P1259 AFTER BARE BLOCK REPLACEMENT FOR 2001 3.2CL, 2001 MDX, 1999 - 2001 3.2TL AND 1997 - 1999 3.0CL MODEL VEHICLES. ( NHTSA ITEM NUMBER - 615753 )
151. EQUIPMENT
Bulletin Number: 010200
Bulletin Date: FEB 2000
Summary:
INFORMATION ON PROGRAMMING THE IMMOBILIZER KEYS. ( NHTSA ITEM NUMBER - 618762 )
152. ENGINE AND ENGINE COOLING:COOLING SYSTEM
Summary:
BRIEF INFORMATION ON TROUBLESHOOTING THE ENGINE COOLANT TEMPERATURE (ECT) SENSOR. ( NHTSA ITEM NUMBER - 618757 )
sloojoe
Summary:
Summary:
Summary:
Summary:
5. POWER TRAIN
Summary:
Summary:
7. SEATS
Summary:
Summary:
Summary:
Summary:
Summary:
12. EQUIPMENT
Summary:
Summary:
Summary:
Summary:
16. EQUIPMENT
Summary:
Summary:
Summary:
Summary:
20. EQUIPMENT
Summary:
Summary:
22. POWER TRAIN
Summary:
Summary:
Summary:
25. OTHER
Summary:
Summary:
27. POWER TRAIN
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
33. AIR BAGS
Summary:
Summary:
Summary:
Summary:
Summary:
38. POWER TRAIN
Summary:
39. POWER TRAIN
Summary:
40. VISIBILITY
Summary:
41. POWER TRAIN
Summary:
Summary:
Summary:
44. TIRES
Summary:
Summary:
Summary:
47. POWER TRAIN
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
64. POWER TRAIN
Summary:
Summary:
66. AIR BAGS
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
84. EQUIPMENT
Summary:
Summary:
Summary:
87. OTHER
Summary:
Summary:
Summary:
90. EQUIPMENT
Summary:
91. AIR BAGS
Summary:
Summary:
Summary:
Summary:
Summary:
96. OTHER
Summary:
Summary:
98. SEATS
Summary:
Summary:
100. SEATS
Summary:
Summary:
Summary:
103. VISIBILITY
Summary:
Summary:
Summary:
Summary:
Summary:
108. AIR BAGS
Summary:
Summary:
110. OTHER
Summary:
Summary:
112. AIR BAGS
Summary:
Summary:
114. STRUCTURE
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
123. OTHER
Summary:
124. OTHER
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
131. STEERING
Summary:
Summary:
Summary:
Summary:
135. OTHER
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
143. SEAT BELTS
Summary:
144. EQUIPMENT
Summary:
Summary:
146. STRUCTURE:BODY
Summary:
Summary:
Summary:
Summary:
Summary:
151. EQUIPMENT
Summary:
Summary:
sloojoe
thats nice that you have listed what u listed and all... but uh... what does this all mean? what the hell does a canon camera being replaced have to do with my car?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Head Duck
What, you didn't get your free digital camera with each transmission replacement?
Seriously, the camera was probably provided by Acura to its dealers to take digital photos of warranty inspections (such as those in the transmission recall program) for documentation purposes.
These are not necessarily free (warranty) repair items. Sometimes service bulletins are sent out for certain repair problems to help the dealer locate and repair certain things. Each item may or may not be covered under a special warranty.
Serice Bulletin Update
Alright, duckman2000 is right. I called Acura and they told me Technical Service Bulletins are for technicians to diagnose problems. Basically, if any of the problems above occur with your car, Acura technicians already know how to correct the problem. It just gives you the upper hand when going to the dealership and they try some bullshit line about, " this has never happened and we need to charge you more". In addition, most if not all of the mentioned problems are not covered by warranty or recalls. It's just a list of the most common problems with 2001 CL's. If someone knows an Acura Technician, they can probally print out the fixes to all of these problems so we can either take our car somewhere else or fix it ourselves. I have no connection in the Acura service department, but someone out there does.
Sloojoe
Sloojoe
08_UA7_Gr33k
02-11-2016 02:17 PM
