Seat heaters
Old Oct 31, 2003 | 08:11 PM
Cruz_msl's Avatar
My Member is Registered
Seat heaters
I thought the driver's side seat heated both bottom and back, is this correct? My back isn't getting warm.
Old Oct 31, 2003 | 08:46 PM
Dan's Avatar
Dan
Confused
Had the same problem AND the dealer had the balls to tell me the seatback was not heated because of the airbag sensor! I told him that applied to the passenger seat only. He grabbed a tech (?) that was walking by and he also said that the drivers seatback was not heated. I walked over to the parts department and got the part # for the heating pad for the drivers seatbach and proceded to tell the advisor & tech that if they make the part, it must be heated. Was fixed under warranty the following week. Everytime I have to deal with the Acura dealer makes me like my wifes Lexus that much more.
Dan
Old Oct 31, 2003 | 09:38 PM
Cruz_msl's Avatar
that's what I thought. Sorry about your hassle :-(
Old Nov 1, 2003 | 05:55 AM
GD196's Avatar
wtf the seatback should heat too? damn i need to get that fixed!!!
Old Nov 1, 2003 | 08:54 AM
Jens H.'s Avatar
retired
Just so you folks are clear on this ,the driver's seat has both a heated back rest and seat bottom ,the passenger seat only has a heated seat bottom .The reason for the lack of a heated back rest is due to the OPDS (Occupant Position Detection System ) in the passenger seatback for the passenger seat side airbag .
Jens
Old Nov 1, 2003 | 02:35 PM
Chief F1 Fan's Avatar
I did not know that Jens, guess 'cuz I never sit on the boring side of my car!
Old Nov 1, 2003 | 05:12 PM
Jens H.'s Avatar
retired
Jens
Old Nov 1, 2003 | 05:21 PM
einsatz's Avatar
I miss my 03 CL-S :(
I think it says it in the manual.
I've noticed that if you use the lumbar adjuster thing at all, that part gets hotter than the rest of the back, and it's actually uncomfortable, so if you use the lumbar support thing all the time, you'll find yourself turning the heaters off manually instead of leaving them in low as the manual says.
Also, I think (unless mine is broken, too), it's just the bottom half of the back that's heated, not the top part so you don't get heat at shoulder level or anything.
Old Nov 1, 2003 | 08:54 PM
Cruz_msl's Avatar
All- thanks for the input, maybe I should actually read the manual before posting next tiime...
Old Nov 1, 2003 | 08:57 PM
darrinb's Avatar
///M POWER
take it to the dealer
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
