Sad news...
Old 11-16-2006 | 03:18 PM
  #41
fuzzy02CLS's Avatar
The cop should have put him in jail.
However you can sue the guy for the $$ to fix your car.
Old 11-16-2006 | 03:20 PM
  #42
BigLizard's Avatar
Moderator Alumnus
Not a bad idea...
good looking out...
Anybody that doesn't have a driver's license or insurance regardless who's at fault should go to jail.
Old 11-16-2006 | 03:21 PM
  #43
brianlin87's Avatar
ASM I.S. Design FTW.
make sure to tell the bodyshop to order all 03 front end parts when they fix your car.
Old 11-16-2006 | 03:22 PM
  #44
BigLizard's Avatar
Moderator Alumnus
I plan on it
Old 11-16-2006 | 04:24 PM
  #45
YeuEmMaiMai's Avatar
Originally Posted by GreenMachine
From the crappy ass weather we've been having up in Washington state, I was in an accident with my CL. I rear ended somebody when they slammed on their brakes from them not paying attention to the traffic in front of them. I was almost 3 car lengths behind the guy but wet slick roads and going below the speed limit doesn't make a difference with a 3500lb car......
driving i n crappy weather and you are only 3 cars behind? sounds like you were a little too close. I am suprised that the officer ticketed you though since he was on the road illegally and it could be argued that if he was not there, there would have not been an accident.
I dunno about you but I find the brakes on my car to be more than able to haul the car down from posted speeds in a hurry and the data from motor trend backs this up (1 year test indicated NO BRAKING PROBLEMS). I was almost rear ended by a guy that could not stop as fast as I could when the person if front of me came almost to a complete stop because they were not paying attention to what was going on in front of them. Thankfully i left enough room in front of me so that I could pull forward before the guy hit me. The stopping distance for a V6 accord btw is 127 ft
POWERTRAIN/CHASSIS
Drivetrain layout Front-engine, fwd
Engine type V-6, SOHC, 4 valves/cyl, aluminum block and heads
Displacement, ci/cc 195.9/3210
Hp @ rpm 260 @ 6100
Torque @ rpm 232 @ 3500
Transmission 5-speed automatic
Suspension, front; rear Upper and lower control arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Brakes, front; rear 11.8-in vented disc; 11.1-in disc, ABS
Wheels 17x7.0 cast aluminum
Tires 215/50R17 93V Michelin MXM4
Traction control Yes
DIMENSIONS
Wheelbase, in 106.9
Length, in 192.0
Width, in 69.2
Height, in 53.3
Curb weight, lb 3510
Seating capacity 5
Cargo capacity, cu ft 13.6
Fuel capacity, gal 17.2
TEST DATA
0-60 mph, sec 6.4
1/4 mile, sec @ mph 14.8 @ 96.5
Braking, 60-0 mph, ft 124
600-ft slalom, mph 63.7
Total mileage 9475
Avg test mpg 23.6
Problem areas Airbag sensor, creaking sunroof
Non-warr cost $0.00
CONSUMER INFO
Base price $30,300
Price as tested $32,810
Current value, $23,835/$26,170
whlse/retail per Kelley Blue Book
Airbags Dual front, front-side
EPA mpg, city/hwy 19/29
Range, city/hwy, miles 327/499
Basic warranty 4 yrs/50,000 miles
Powertrain warranty 4 yrs/50,000 miles
Roadside assistance 4 yrs/50,000 miles
Recalls None
Old 11-16-2006 | 04:58 PM
  #46
DelawareCLS's Avatar
POWERTRAIN/CHASSIS
TEST DATA
0-60 mph, sec 6.4
Recalls None
As I am sure others will point out, those tests were done under perfect conditions (i.e. no rain) and the driver knew he'd be braking for the test - one has to consider reaction time in an emergency stop. 3 car lengths seems sufficient to me...
Acuras/Hondas have a long and well-documented history of undersizing both the brakes and the tires (all OEM). While there have certainly been situations where I could stop my car very quickly, it's certainly not the norm! Takes a lot to haul down a 3500lb car with undersized brakes/tires.
  #47
STypeAcura's Avatar
The Speed Nerd
Hey Buddy,
I know it wasn't your fault- when someone makes a complete stop on a highway or a decent moving road it a lot harder to go to a complete stop and slow down. I know a lot of us (especially those of us with a heavy foot) have been or could've been in your situation.
The ticket sucks and you should fight it if you're up for it. As others have mentioned- the unlicensed driver shouldnt have been on the road and if he wasn't there you wouldn't have hit him.
In terms of the car, hang in there. It sucks but it will all work out in time. And look forward to all those 03 goodies you will get with her now! Let us now what happens with the adjuster.
As well- hope youre feeling better!
Old 11-16-2006 | 05:05 PM
  #48
CleanCL's Avatar
that car is a total loss. i see frame damage and radiator support damage. look for a type S this time.
id say min repair cost 5,000 but i think it will be more bc they need to pull the frame straight, replace the hood, grill, bumper, both headlights, radiator, condensor, possible power steering lines, possible condensor lines, possible front cross beam, possible cross member. not to mention the R&I and paint.
Old 11-16-2006 | 06:11 PM
  #49
GreenMonster's Avatar
Wow that sucks... but it sounds like you're ok, so that's the main thing...
Hopefully, they don't total it....
Old 11-16-2006 | 07:14 PM
  #50
BigLizard's Avatar
Moderator Alumnus
I just back from the doctor and I'll be out of work until next tuesday because my back is messed up. I'll be doing physical therapy when I go back to work. More than likely I'll be on light duty for a while.
If it is totaled out I'm still going to use everything I have.
I'll have an extra BVA just in case. :wink:
Type-S 6 might be in the works if my car is totaled.
Old 11-16-2006 | 07:16 PM
  #51
gc86's Avatar
Advance
Bva?
Old 11-16-2006 | 07:18 PM
  #52
Sun Diego CL-S's Avatar
says "hello to my TLX".
i dare you to do that.
Old 11-16-2006 | 07:25 PM
  #53
BigLizard's Avatar
Moderator Alumnus
Originally Posted by gc86
Bva?
Bypass Valve Actuator
Type-S models have this.
Originally Posted by SN CL-S
I dare you to do that.
How about a double dare?
o O(hehehee)
Old 11-16-2006 | 07:42 PM
  #54
So, maybe we want it to be totalled ??
Always good to have another 6spd member on here...
Old 11-16-2006 | 08:04 PM
  #55
BigLizard's Avatar
Moderator Alumnus
Well, I might just have to join the 6spd club.
But I'm also going to keep my options open for anything else out there that's decent with the same options the CL has. Keep your fingers crossed that I can get her fixed.
Old 11-16-2006 | 08:05 PM
  #56
BigLizard's Avatar
Moderator Alumnus
http://www.autotrader.com/fyc/vdp.js...ice=&cardist=8
Check that out...I've been eyeballing this for a quick minute. I can talk down the price though.
Old 11-16-2006 | 08:08 PM
  #57
CleanCL's Avatar
navi and manual, thats an ok price, im sure you can get them down a little. but id jump on it.
Old 11-16-2006 | 08:10 PM
  #58
BigLizard's Avatar
Moderator Alumnus
I can get that under 18,xxx easily. I know how to deal with dealerships.
EDIT: I already sent them an email. Hopefully they'll get back to me tomorrow.
Old 11-16-2006 | 08:34 PM
  #59
BigLizard's Avatar
Moderator Alumnus
Don't hate but I'm also checking out the 2003 TL Type-S too.
Old 11-16-2006 | 08:45 PM
  #60
Trackruner228's Avatar
Just wondering what year and how many miles where on the car?
Old 11-16-2006 | 08:46 PM
  #61
BigLizard's Avatar
Moderator Alumnus
113,xxx miles
check out the first page and first post.
Old 11-16-2006 | 10:53 PM
  #62
113,xxx miles
I really need to start paying attention to peoples signatures more often....
Old 11-16-2006 | 11:06 PM
  #63
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
well if you happen to venture away from the CL-TL i have 1st dibs on parts.
yes i am a vulture
Old 11-16-2006 | 11:26 PM
  #64
BigLizard's Avatar
Moderator Alumnus
yes i am a vulture
I'll keep you in mind.
More than likely I'm gonna stick with the 2nd gen CL or TL, but Type-S. I'm looking to get one with Navi too.
EDIT: Thats only if it gets totaled out.
Old 11-17-2006 | 12:27 AM
  #65
Lord Helmet's Avatar
I'm here in spirit...
I think you should stick with the CL-S6. I think you'd be happier with it.
Old 11-17-2006 | 12:28 AM
  #66
BigLizard's Avatar
Moderator Alumnus
I've only found that one though...they are a rare bread on the west coast.
Pacific northwest
Old 11-17-2006 | 12:42 AM
  #67
g1underground's Avatar
Cosmic Cowboy
Wow........you worked like a slave on that car modding it, good thing you're OK.
First mods for the pending 6sp......much better tires and a BBK, well worth it.
Old 11-17-2006 | 12:45 AM
  #68
Pacific northwest
I'm a firm believer that it's worth it to travel TO the right car if you can find it.
My stepdad bought a pristine M3 off of ebay in TX and drove it back to FL because he couldn't find one locally. It was probably the nicest '04 I have seen this side of a brand new one. He got a decent deal on it and again, the car was perfect with low miles. I would totally do it.
Old 11-17-2006 | 01:02 AM
  #69
BigLizard's Avatar
Moderator Alumnus
I'll consider it. I'm just going to get a lot of sh*t from my folks though.
Old 11-17-2006 | 01:15 AM
  #70
Rpappi's Avatar
if it makes you happy
Old 11-17-2006 | 01:27 AM
  #71
BigLizard's Avatar
Moderator Alumnus
I just did some prelim adjusting numbers and I noticed that if the costs surpass 6500+ it'll be a loss.
The muscle relaxers are makin g me loopy ...
hoep for the best tomororw
Old 11-17-2006 | 06:40 AM
  #72
cltypeSLOW's Avatar
Don't Mess With Texas
yep. distortedolskool and i flew from texas to damn near canada (northern ohio) to get his SMR/ebony CLS6 and then drove it all the way back. the car was in better condition that we even expected.
i hope you dont get in a 03TLS because you are just gonna have tranny probs.
i would look for another 6spd or jst wait a bit cause parchament makes me vomit when its paired with NHB
Old 11-17-2006 | 10:50 AM
  #73
Blasphemy! All lies!
Old 11-17-2006 | 11:44 AM
  #74
redsly's Avatar
Got DEP???
Sorry to hear about your car Green.
This morning I had to stop suddenly from 40mph and I figured I would never have been able to, but my car surprised me and stopped very fast without the ABS kicking in.
At least you didn't install the new HID's yet, that would have been a waste. That's what happened to me in my integra (the lights) right after installing $130 HL bulbs.
Glad that the airbags don't go off in front end collisions! That makes me feel comfortable!
If the cost gets to high, just buy my car! HA... Tranny only has 4k on it! Same exact car (from the factory that is) as yours.
I remember reading a post about which way slotted rotors should be installed... I wonder if this could be an answer to that. IMO yours should have been installed in the other direction. The gasses and moisture need to be pushed away from the pads, not towards the center.
Any engine damage? It doesn't look like it, but you never know what the radiator support went into and don't forget the hydraulic engine mount that is right behind the radiator support (should be low enough though). I hope that nothing messed up your Type S parts, they probably would only give you CLP parts and you would get stuck with the difference.
Good luck and I hope it gets fixed quickly!
Old 11-17-2006 | 11:54 AM
  #75
redsly's Avatar
Got DEP???
Not a bad idea...
good looking out...
In Massachusetts, it is illegal and the law is that a unlicensed person will be arrested for operating a motor vehicle.
Old 11-17-2006 | 12:00 PM
  #76
GM#2, can you get pics of the damage? I'm curious.
Old 11-17-2006 | 12:37 PM
  #77
Jared03CLS's Avatar
Luckiest Man on Earth.
The pics are on the first page of the thread, I think halfway down the page....
Old 11-17-2006 | 12:54 PM
  #78
Geez, I can't believe I missed that!
Look like a potential total loss GM. I hope not though, I really liked that car. So much time and effort.
Old 11-17-2006 | 04:12 PM
  #79
BigLizard's Avatar
Moderator Alumnus
Talking
I have really good news!
Market value for my car is worth over $11 grand.
The total damage estimate came to $6136.xx with some change. She's getting fixed!
Oh and BTW, '03 headlamps are coming.
EDIT: If the shop finds any more damage they will let the adjuster know, so I still have a couple grand to play with if it comes to it.
Old 11-17-2006 | 04:17 PM
  #80
Tyler23's Avatar
Sorry to hear about your accident. As a fellow Washingtonian, I know what the weather's been like and it could have been a lot worse.
I would guess, too, that this will be a total. After having to replace both the HID inverter ($400) and a lense ($180) on my '01 CL-S, you would be looking at $1,160 right there, plus a couple of new bulbs at $120 each (or so), and that's $1,300 just for headlights. After frame, bumper, and hood repair, paint, etc., well, you know.
On the bright side, someone totalled by Maxima and I was able to get into the CL-S (which I love.... other than the cost of the damn headlight components ). So you might be able to get something you love even more.
Edit: Well, shows you how much I know. Missed you by 5 min. Damn! :-)
